How to add device schedule in dzvents (addtimer)
OlivierFR
Post by OlivierFR »
I'm trying to add a schedule to a device from within a dzvents script.
Here is the API of the command :
../json.htm?type=command&param=addtimer&idx=DeviceRowID&active=true&timertype=2&hour=0&min=20&randomness=false&command=0&days=1234567
I thought about using SendCommand() but it does not seem to work.
What is the right way to do this?
Olivier
Re: How to add device schedule in dzvents (addtimer)
OlivierFR wrote: Wednesday 24 April 2019 17:59 I'm trying to add a schedule to a device from within a dzvents script.
I would use a dzVents function for this.
local function addSchedule(idx,action,hour,minute)
    local command = 0 -- On
    if action:lower() == "off" then
        command = 1 -- Off
    local jsonString  = "/json.htm?type=command&param=addtimer&idx=" .. idx ..
                         "&active=true&timertype=2&hour=" .. hour ..
                         "&min=" .. minute ..
                         "&randomness=false&command=" .. command ..
                         "&days=1234567"
    domoticz.openURL( domoticz.settings["Domoticz url"] .. jsonString )
addSchedule(xxx,"On",hh,mm) -- replace xxx with your device number, hh with the hour and mm with the minute. Only  "On" and "Off" can be used in this function
OlivierFR
Post by OlivierFR »
This works perfectly.
