Ubuntu 19.04 & Domoticz
Prutsium
Post by Prutsium »
As my wife hitted by accident the upgrade function for Ubuntu from 18.04 > 19.04 the system got upgraded.
(Yes she pressed every yes button and so on :))
But now i end up with an non working Domoticz ..... anybody have some tips?
When starting manual i get:
media@media-N61Vg:~/domoticz$ ./domoticz
./domoticz: error while loading shared libraries: libssl.so.1.0.0: cannot open shared object file: No such file or directory
trying to get libssl results in:
media@media-N61Vg:~/domoticz$ sudo apt-get install libssl1.0.0
Reading package lists... Done
Building dependency tree
Reading state information... Done
Package libssl1.0.0 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'libssl1.0.0' has no installation candidate
Help :)
Justino
Domoticz version: 4.10548
Re: Ubuntu 19.04 & Domoticz
Post by Justino »
Hi there,
Some are having the same issue, see https://www.domoticz.com/forum/viewtopic.php?t=18793
Like they tell in this topic, you'll need to manually install it. (link in the topic is outdated)
Pi:
wget http://ftp.nl.debian.org/debian/pool/main/o/openssl/libssl1.0.0_1.0.1t-1+deb8u8_armhf.deb
sudo dpkg -i libssl1.0.0_1.0.1t-1+deb8u8_armhf.deb
In your case it will be (if i'm correct)
64-Bit:
wget http://ftp.nl.debian.org/debian/pool/main/o/openssl/libssl1.0.0_1.0.1t-1+deb8u8_amd64.deb
sudo dpkg -i libssl1.0.0_1.0.1t-1+deb8u8_amd64.deb
-- or --
32-Bit
http://ftp.nl.debian.org/debian/pool/main/o/openssl/libssl1.0.0_1.0.1t-1+deb8u8_i386.deb
sudo dpkg -i libssl1.0.0_1.0.1t-1+deb8u8_i386.deb
Source link:
After that, reboot your Domoticz and you should be up and running again
vamp
Post by vamp »
Same problem, but after i install libssl i can not login and the web login interface is sometime available sometime not... I think a another problem is exist not only libssl.
