Hi, i have 4 chinese camera on my house but never succeed on configure them with domoticz
now i see this video:
https://www.youtube.com/watch?v=G4tN2nWY9s4
around minute 40:50 i see that he use a software telerik fiddler but i do not understan well how if works
someone has try with good results?
thanks
discover url for chinese ipcam with telerik fiddler
megamarco83
joostnl
Re: discover url for chinese ipcam with telerik fiddler
Try ispy software
megamarco83
Yes, i use it and i'm able to see my camera (onvif) on ispy software and also on ispy web server like in the video that i linked.
I'm also able to catch the string sniffing the net like in the video, but when i copy and paste the sting in domoticz it doesn't work
- JHO01
- Domoticz version: Stable
Have you tried this: https://www.domoticz.com/forum/viewtopi ... 35&t=23719 ?
RPI-3, Z-stick Gen5, RFlink, Zigbee2mqtt, 1-wire DS18B20, Fibaro switches, various RF-433 sockets, BMP018, Somfy, Wemos, Tradfri.
megamarco83
hi yes i see your post, and i try.
but when i make test i receive error message: is not possible to find snapshot
other solutions?
there are a list on china cheap cam that are compatible with domoticz?
how you close the camera comunication to "home China" ?
other solutions?
wvries
- Domoticz version: latest B
are these camera's ONVIF ? Then it is an RTSP stream which is not compatible with Domoticz.
Solutions for this would require an intermediate system that transcodes the stream to a format for Dz.
I use a separate RPI3B+ to run Motion. (https://motion-project.github.io/)
Added advantage is that you have motion detection, screen captures and video recording etc in this app. And also, it spits out a stream per cam that is compatible with DZ if you want.
I am now at a point that I am not using the camera part of DZ anymore and run it all from Motion, with an integration of DZ (to let Motion know when to enable motion detection etc..) through remote scripts, adjusting the Motion configuration files.
Does take some time to set it up correctly (minimise false motion triggers etc) but does run well.
to close the "call home" from the Chinese cams, make sure outgoing communication from the IP's of the camera are blocked in your router / firewall.
that is the only way to kill the communication back from the camera to China.
- EdwinK
- Domoticz version: BETA
How easy is the install on Raspberry? Just the apt-get thing or do you have to be a 'genius' on Linuxwvries wrote: Thursday 02 May 2019 17:07 are these camera's ONVIF ? Then it is an RTSP stream which is not compatible with Domoticz.
poudenes
- Domoticz version: 3.8993
https://motion-project.github.io/motion_build.htmlEdwinK wrote: Saturday 01 June 2019 12:17How easy is the install on Raspberry? Just the apt-get thing or do you have to be a 'genius' on Linuxwvries wrote: Thursday 02 May 2019 17:07 are these camera's ONVIF ? Then it is an RTSP stream which is not compatible with Domoticz.
I use a separate RPI3B+ to run Motion. (https://motion-project.github.io/)![]()
Here how to install
