I have just reinstalled my system, and now the scripts seems not to work. I got a lot of help when I asked this question, and everything worked perfect. I do have a backup, so it's not a big problem. Here is my previous question about how to do this. https://www.domoticz.com/forum/viewtopi ... 59&t=27392
My scripst look like this:
on = { timer = { 'every minute' } },
execute = function(domoticz)
local Sensor = domoticz.devices(1) -- Temperature
local SETPOINT = domoticz.devices(13) -- SetPoint
SETPOINT.updateSetPoint(SETPOINT.setPoint) -- This will refresh the setPoint with current value
if (Sensor.temperature <= (SETPOINT.setPoint - 0.2)) then -- turn on heat
domoticz.devices(7).switchOn().checkFirst()
elseif (Sensor.temperature >= (SETPOINT.setPoint + 0.2)) then -- turn off heat
domoticz.devices(7).switchOff().checkFirst()
-- within hysteresis range
I observe that the temperatures are updated on the Dashboard. I can also turn the relays connected to the GPIO device if I use the switch manually, but the scripts will not turn on / off went the setPoint is +- .2 degrees.
Only difference I know about is that I did not install a MQTT broker on the new installation - have been using Mosqyitto broker on the other system, since I also was running Node-Red.
If you want, I can post the whole installation procedure.
Best regards
Ulf
Cannot make dzVents work after reinstall
SweetPants
Re: Cannot make dzVents work after reinstall
Did you enable the event system in Setup->Settings->Others?
Sometimes it got disabled after update
ulfh2018
Thank you for providing me with this inforatio. Alas that did no solve the problem. I'm noe going to check the history on the system working and see if I can dig out some information
