How to get Lux value using bash curl command Topic is solved
All kinds of 'OS' scripts
vidin
Post by vidin »
hello I have problem with get Lux value
for example for voltage I use
curl -s 'http://192.168.9.4:8080/json.htm?type=devices&rid=11' | jq .result[0].Voltage | sed 's/\"//g' | awk '{ print $1 }'
for Lux I try
curl -s 'http://192.168.9.4:8080/json.htm?type=devices&rid=17' | jq .result[0].Lux | sed 's/\"//g' | awk '{ print $1 }'
curl -s 'http://192.168.9.4:8080/json.htm?type=devices&rid=17' | jq .result[0].Value | sed 's/\"//g' | awk '{ print $1 }'
curl -s 'http://192.168.9.4:8080/json.htm?type=devices&rid=17' | jq .result[0].VALUE | sed 's/\"//g' | awk '{ print $1 }'
curl -s 'http://192.168.9.4:8080/json.htm?type=devices&rid=17' | jq .result[0].LightLevel | sed 's/\"//g' | awk '{ print $1 }'
and command always return "null"
Re: How to get Lux value using bash curl command
vidin wrote: Tuesday 16 April 2019 18:21 hello I have problem with get Lux value
Try
curl -s 'http://192.168.9.4:8080/json.htm?type=devices&rid=17' | grep Data | awk '{ print $3 }' | cut -b2-
vidin
Post by vidin »
It works fine, thanks
