multiple domoticz devices as local ..
dizzeenl
Post by dizzeenl »
I'm facing some problems with adding multiple domoticz devices under a 'local'.
I want to make a single script to handle all my notifications and need (at the moment) 3 seperate groups for this (doors/windows, motion sensors and lights) to display the right message for each group.
Unfortunately only the first listed devices will work with the code below.
i didn't see any other script with this kind a code so i think that's the reason it's not working :lol:
I tried to convert
-- Send message when sensor triggered
    devices = {
        'Voordeur',
        'Keukendeur',
        'Slaapkamerraam',
        'Voordeursensor',
        'Achtertuinsensor',
        'Voordeurlamp',
        'Achtertuinverlichting',
        'TESTdoor',
        'TESTmotion'
       local tijd = os.date("%X")
       local MAGNOmodus = domoticz.devices('MAGNOmodus')
       local lights = domoticz.devices('Voordeurlamp','Achtertuinverlichting','Woonkamer Spot')
       local DWsensors = domoticz.devices('Voordeur','Keukendeur','Slaapkamerraam','TESTdoor')
       local MOsensors = domoticz.devices('Voordeursensor','Achtertuinsensor','TESTmotion')
       domoticz.log(item.name.." triggerd")
    if MAGNOmodus.state == 'Standaard' then
        if (DWsensors.active) then
         	domoticz.notify(item.name,"Geopend om "..tijd,domoticz.PRIORITY_NORMAL)
	    if (lights.active) then
         	domoticz.notify(item.name,"Ingeschakeld om "..tijd,domoticz.PRIORITY_NORMAL)
    if MAGNOmodus.state == 'Afwezig' then
         	domoticz.notify(item.name,"Is geopend om "..tijd.."!",domoticz.PRIORITY_EMERGENCY)
	    if (MOsensors.active) then
         	domoticz.notify(item.name,"Beweging gedetecteerd om "..tijd.."!",domoticz.PRIORITY_MODERATE)
I also tried the .filter function but don't understand how it works jet, any idea how to solve this? :roll:
DEBUG with TESTdoor switched
---- Start internal script: 04 SEN_NOTIFYv1: Device: "TESTdoor (VIRTUAL)", Index: 779
2019-04-15 18:43:07.184 Status: dzVents: Debug: Processing device-adapter for MAGNOmodus: Switch device adapter
2019-04-15 18:43:07.186 Status: dzVents: Debug: Processing device-adapter for Voordeurlamp: Switch device adapter
2019-04-15 18:43:07.188 Status: dzVents: Debug: Processing device-adapter for Voordeur: Switch device adapter
2019-04-15 18:43:07.189 Status: dzVents: Debug: Processing device-adapter for Voordeursensor: Switch device adapter
2019-04-15 18:43:07.189 Status: dzVents: Info: TESTdoor triggerd
2019-04-15 18:43:07.189 Status: dzVents: Info: ------ Finished 04 SEN_NOTIFYv1
Before i used the difference in device.state == "ON" and device.state == "Open" but because the motion and light devices has the same value i need a different approach.
Re: multiple domoticz devices as local ..
dizzeenl wrote: Monday 15 April 2019 18:44 I'm facing some problems with adding multiple domoticz devices under a 'local'.
Version with filter and forEach (too complicated for this purpose?)
    devices = {
        'Voordeur',
        'Keukendeur',
        'Slaapkamerraam',
        'Voordeursensor',
        'Achtertuinsensor',
        'Voordeurlamp',
        'TESTdoor',
        'TESTmotion'
       local tijd = domoticz.time.rawTime
       local lights = domoticz.devices().filter({'Voordeurlamp','Achtertuinverlichting','Woonkamer Spot' })
       local DWsensors = domoticz.devices().filter({'Voordeur','Keukendeur','Slaapkamerraam','TESTdoor'})
       local MOsensors = domoticz.devices().filter({'Voordeursensor','Achtertuinsensor','TESTmotion'})
            DWsensors.forEach(function(device)
                if device.active then
                    domoticz.notify(device.name,"Geopend om "..tijd,domoticz.PRIORITY_NORMAL)
            end)
            lights.forEach(function(device)
                    domoticz.notify(device.name,"Ingeschakeld om "..tijd,domoticz.PRIORITY_NORMAL)
            end)
                    domoticz.notify(device.name,"Is geopend om "..tijd.."!",domoticz.PRIORITY_EMERGENCY)
            end)
            MOsensors.forEach(function(device)
            end)
Version with switchType
return  {
        on =    {
            devices =   {
                        'Voordeur',
                        'Keukendeur',
                        'Slaapkamerraam',
                        'Voordeursensor',
                        'Achtertuinsensor',
                        'Voordeurlamp',
                        'TESTdoor',
                        'TESTmotion'
            if item.switchType == 'Door Contact' and item.active then
            elseif  item.switchType ~= 'Motion Sensor' and item.switchType ~= 'Door Contact' and item.active then
        elseif MAGNOmodus.state == 'Afwezig' then
            elseif item.switchType == 'Motion Sensor' and item.active then
dizzeenl
Post by dizzeenl »
Thanks a lot, i didn't knew the switchType function jet.
I changed the light type to 'On/Off' and works perfect also.
The filter and foreach function are clear now but indeed, a bit to much for this script. I hope to use it in the future.
