I did the following:
- wrote debian wheezy image to micro sd from http://www.cubieforums.com/index.php/topic,528.0.html
- setup wheezy using the cubieboard-config script
- transfer rootfs and kernel to flash as explained here http://www.cubieforums.com/index.php/topic,511.0.html
I attached a 16 gig ssd, which is auto mounted at boot in /data. The idea is to run domoticz and it's log on /data (the ssd) to minimize writes on the nand. The nand should be on par with ssd but since it's not replacable I want to go easy on it. So far I've compiled domoticz (compile time 15 minutes, not faster than a raspberry sadly) and tested it. The webinterface is a *lot* faster running on the dual core chip
Now to see if usb and the rfxcom work.
