Problem with opening URL using dzvents
doh
Post by doh »
I'm trying to move a script from old LUA to dzvents.
The script basically calls on the Tado API to get temperature from my heating control.
On the old LUA script it calls curl to do this, like this:
os.execute('curl -s "https://auth.tado.com/oauth/token" -d client_id=public-api-preview -d client_secret=4HJGRffVR8xb3XdEUQpjgZ1VplJi6Xgw -d grant_type=password -d password=' .. tado_pwd .. ' -d scope=home.user -d username=' .. tado_user)
Using dzVents I'm trying this:
domoticz.openURL({
	url = 'https://auth.tado.com/oauth/token',
	method = 'POST',
	callback = 'tadoauthcallback',
	postData = {
		client_id = "public-api-preview",
		client_secret = "4HJGRffVR8xb3XdEUQpjgZ1VplJi6Xgw",
		grant_type = "password",
		password = tado_pwd,
		scope  = "home.user",
		username  = tado_user
With the old approach, it works fine, but with the dzvents approach I'm getting an unauthorised response back from the tado web site.
Any ideas why? They look equivalent to me.
doh
Re: Problem with opening URL using dzvents
Post by doh »
Found it!
The tado website doesn't like the content-type of application/json and was expecting a content type of application/x-www-form-urlencoded
By forcing the content type to application/x-www-form-urlencoded and setting the postData to be of the format below, it now works.
postData="field1=value1&field2=value2..."
Thorgal789
Post by Thorgal789 »
Good to know, thx.
I want to do same on my scripts, but there is an advantage to use dz-event instead of os.execute and curl ? If it's local command no prb with asynchronous request.
