Selector switch & Inverted blind
najtram
Domoticz version: v4.9700
Post by najtram »
Can some help me with the Close or off. Both doesn't seem to work.
This is my first (self made) Lua script and I set it to "device".
So the state "Open" works. But "Close" or "Off" doesn't!
R1 is inverted blind switch
R2 is selector switch
if devicechanged['RolgordijntestR1'] == 'Close' then
      commandArray['RolgordijntestR2']='Set Level: 10'
if devicechanged['RolgordijntestR1'] == 'Open' then --Inverted blind switch
      commandArray['RolgordijntestR2']='Set Level: 20' -- Works!
if devicechanged['RolgordijntestR1'] == 'Off' then
      commandArray['RolgordijntestR2']='Set Level: 30'
RFLink Gateway → 433Mhz/KAKU switches
Z-Wave → Z-Stick Gen5+
ZigBee → ConBee II
Bluetooth → Soma Smart Shades
Opentherm Gateway → Remeha iSense - Tzerra boiler
ESP8266+CC1101 → ITHO ecofan RFT
P1 cable → DSMR 2.2+ Landys +gyr E350
LAN → Enphase Envoy
tozzke
Domoticz version: Stable
Re: Selector switch & Inverted blind
Post by tozzke »
Try 'Closed' ;)
najtram
Post by najtram »
You are a genius! Thanks.
ZigBee → ConBee II
LAN → Enphase Envoy
