someone has already got successfully a BME680 connected to the Domoticz i2c interface on Raspberry Pi 3+?
Thanks for the help in advance
#!/usr/bin/env python
import bme680
import time
import urllib2
idx_bme680 = IDX_Created_in_Domoticz
domoticz1_url = "http://domoticz-ip:port"
try:
sensor = bme680.BME680(bme680.I2C_ADDR_PRIMARY)
except IOError:
sensor = bme680.BME680(bme680.I2C_ADDR_SECONDARY)
# These oversampling settings can be tweaked to
# change the balance between accuracy and noise in
# the data.
sensor.set_humidity_oversample(bme680.OS_2X)
sensor.set_pressure_oversample(bme680.OS_4X)
sensor.set_temperature_oversample(bme680.OS_8X)
sensor.set_filter(bme680.FILTER_SIZE_3)
sensor.set_gas_status(bme680.ENABLE_GAS_MEAS)
sensor.set_gas_heater_temperature(320)
sensor.set_gas_heater_duration(150)
sensor.select_gas_heater_profile(0)
# start_time and curr_time ensure that the
# burn_in_time (in seconds) is kept track of.
start_time = time.time()
curr_time = time.time()
burn_in_time = 300
burn_in_data = []
average = 60
average_value = 0
try:
# Collect gas resistance burn-in values, then use the average
# of the last 50 values to set the upper limit for calculating
# gas_baseline.
while curr_time - start_time < burn_in_time:
if sensor.get_sensor_data() and sensor.data.heat_stable:
gas = sensor.data.gas_resistance
burn_in_data.append(gas)
#//print('Gas: {0} Ohms'.format(gas))
time.sleep(1)
gas_baseline = sum(burn_in_data[-50:]) / 50.0
# Set the humidity baseline to 40%, an optimal indoor humidity.
hum_baseline = 40.0
# This sets the balance between humidity and gas reading in the
# calculation of air_quality_score (25:75, humidity:gas)
hum_weighting = 0.25
while True:
gas_offset = gas_baseline - gas
hum = sensor.data.humidity
hum_offset = hum - hum_baseline
# Calculate hum_score as the distance from the hum_baseline.
if hum_offset > 0:
hum_score = (100 - hum_baseline - hum_offset)
hum_score /= (100 - hum_baseline)
hum_score *= (hum_weighting * 100)
else:
hum_score = (hum_baseline + hum_offset)
hum_score /= hum_baseline
# Calculate gas_score as the distance from the gas_baseline.
if gas_offset > 0:
gas_score = (gas / gas_baseline)
gas_score *= (100 - (hum_weighting * 100))
else:
gas_score = 100 - (hum_weighting * 100)
# Calculate air_quality_score.
air_quality_score = hum_score + gas_score
average_value = average_value + air_quality_score
average = average - 1
if average < 1:
url_data1 = '/json.htm?type=command¶m=udevice&idx='
url_data2 = '&nvalue=0&svalue='+str(average_value/60)
url1 = domoticz1_url+url_data1+str(idx_bme680)+url_data2
req1 = urllib2.Request(url1)
response1 = urllib2.urlopen(req1)
print(response1)
average = 60
average_value = 0
time.sleep(1)
except KeyboardInterrupt, e:
logging.info("Stopping...")
pass
[Unit]
Description=BME680 Air Quality Service
After=multi-user.target
[Service]
Type=simple
ExecStart=/usr/bin/python /home/pi/BME680_AIQ.py
Restart=on-abort
[Install]
WantedBy=multi-user.target
sudo chmod 644 /lib/systemd/system/BME680_AIQ.service
chmod +x /home/pi/BME680_AIQ.py
sudo systemctl daemon-reload
sudo systemctl enable BME680_AIQ.service
sudo systemctl start BME680_AIQ.service
sudo service BME680_AIQ start
sudo service BME680_AIQ status
sudo journalctl -f -u BME680_AIQ
import bme680
import time
import urllib2
import logging
try:
except IOError:
# These oversampling settings can be tweaked to change the balance between accuracy and noise in the data.
# start_time and curr_time ensure that the burn_in_time (in seconds) is kept track of.
burn_in_time = 300
burn_in_data = []
average = 60
average_value = 0
try:
# Collect gas resistance burn-in values, then use the average of the last 50 values to set the upper limit for
# calculating gas_baseline.
time.sleep(1)
hum_baseline = 40.0
# This sets the balance between humidity and gas reading in the calculation of air_quality_score (25:75,
# humidity:gas)
while True:
if hum_offset > 0:
else:
if gas_offset > 0:
else:
if average < 1:
try:
print(response1)
except:
logging.info("Socket error.")
pass
average = 60
average_value = 0
time.sleep(1)
pass
pip install statistics
git clone https://github.com/rstoermer/bsec_bme680_python
cd bsec_bme680_python/
./make.sh
python bsec_bme680.py
import subprocess
from statistics import median
import urllib2
import json
import logging
idx_bme680_IAQ = 1
idx_bme680_THB = 2
domoticz_url = 'http://raspberrypi:8080'
url_data_base = '/json.htm?type=command¶m=udevice&idx='
url_data1 = '&nvalue='
#Open C File
proc = subprocess.Popen(['/home/pi/bsec_bme680_python/bsec_bme680'], shell=True, stdout=subprocess.PIPE)
listIAQ_Accuracy = []
listPressure = []
listGas = []
listTemperature = []
listIAQ = []
listHumidity = []
listStatus = []
for line in iter(proc.stdout.readline, ''):
lineJSON = json.loads(line.decode("utf-8")) # process line-by-line
lineDict = dict(lineJSON)
#Avoid to collect the valies with low IAQ score (IAQ score from 0=low to 3=high)
if int(lineDict['IAQ_Accuracy']) > 1:
listIAQ_Accuracy.append(int(lineDict['IAQ_Accuracy']))
listPressure.append(float(lineDict['Pressure']))
listGas.append(int(lineDict['Gas']))
listTemperature.append(float(lineDict['Temperature']))
listIAQ.append(float(lineDict['IAQ']))
listHumidity.append(float(lineDict['Humidity']))
listStatus.append(int(lineDict['Status']))
if len(listIAQ_Accuracy) == 20:
#generate the median for each value
IAQ_Accuracy = median(listIAQ_Accuracy)
Pressure = median(listPressure)
Gas = median(listGas)
Temperature = median(listTemperature)
IAQ = median(listIAQ)
Humidity = median(listHumidity)
Status = median(listStatus)
#clear lists
del listIAQ_Accuracy[:]
del listPressure[:]
del listGas[:]
del listTemperature[:]
del listIAQ[:]
del listHumidity[:]
del listStatus[:]
#Temperature Offset
Temperature = Temperature + 2
if Humidity < 40:
HUM_STAT = '2'
elif Humidity < 60:
HUM_STAT = '1'
else:
HUM_STAT = '3'
url1 = domoticz_url+url_data_base+str(idx_bme680_IAQ)+url_data2+str(round(IAQ, 0))
url2 = domoticz_url+url_data_base+str(idx_bme680_THB)+url_data2+str(round(Temperature, 1))+";"+str(round(Humidity, 1))+";"+HUM_STAT+";"+str(round(Pressure, 1))+";0"
try:
logging.info("Transmitting.")
print("Transmitting.")
print(url1)
print(url2)
logging.info(url1)
logging.info(response1)
req2 = urllib2.Request(url2)
response2 = urllib2.urlopen(req2)
logging.info(url2)
logging.info(response2)
except:
pass
[Unit]
[Service]
Type=simple
ExecStart=/usr/bin/python bsec_bme680.py
WorkingDirectory=/home/pi/bsec_bme680_python
Restart=on-abort
[Install]
Users browsing this forum: lost and 1 guest
