Qubino 0-10v Flush Dimmer
Sjefke
Post by Sjefke »
Hi folks,
I have a Qubino flush dimmer that has a 0-10v output as well as an input. I would like to start an event when the input voltages changes. It constantly sends the voltage on the input every few seconds, but I just want to switch the output when the input voltages changes in value.
Otherwise I want to make the output follow a set timer, this is not a problem, but how do I make it respond once the input is changed?
Thanks for the help.
Re: Qubino 0-10v Flush Dimmer
Can you please help me understand your question better ?
What is the type / subtype of this dimmer in domoticz ? (look at the devices tab)
What do you see in domoticz when the input changes ?
