to describe my problem and then the solution:
Problem: when someone rang the doorbell, I wanted to popup the image from my foscam on a tablet mounted on the wall.
The concept worked with the "blocks[IDX]['openpopupOn'] = {}" block.
But my problem was: the image was to big for the popup. The camera I use is a 1080p camera.
Solution: I stepped back from the popup thing and placed a big block on a second screen.
Then when the doorbell rings a dummy switch is triggered and "blocks[IDX]['gotoslideOn'] = 2;" is activated.
Then "config['slide_effect']".
Screen 2 fades in. The image in the block is refreshed every second. That's enough for me.
Then we swipe back to screen 1 after 30 seconds with:
config['auto_swipe_back_to'] = 1;
config['auto_swipe_back_after'] = '30';
This did the trick.
I hope this can be useful for others, that's why I wanted to share this
Camera Feed on doorbell, my solution
sieth
- Domoticz version: 2020.2
- screen1.jpg (303.05 KiB) Viewed 1435 times
- screen2.jpg (359.13 KiB) Viewed 1435 times
pvm
- Domoticz version: 4.10538
Re: Camera Feed on doorbell, my solution
Using similar setup over here.
Small image on home screen, when motion detected (foscam camera attached to synology nas for recording and motion detection), dashticz moves to 3th screen showing full screen camera feed.
Dave47
- Target OS: -
- Domoticz version: 2023.1
Hello what do i need to make visible in dashticz when someone rings the bell?
which push button?
and how can I receive this signal in Dashticz?
How connect the doorbell with Dashticz?
What do i need?
Transmitter?
which push button?
What do i need?
Transmitter?
pvm
Do you have a working camera and the push button in domoticz?
