Replacing native wunderground interface  [Solved]
Number8
Domoticz version: 2022.1
Post by Number8 »
In the quest to replace the native wunderground interface since wunderground policy change, I'm trying to get a dzvents script interprating the json value returned by the new api
item.json
returns this string
{"observations":{{["country"]="FR", ["metric"]={["elev"]=15, ["windGust"]=13, ["windChill"]=12, ["heatIndex"]=12, ["precipRate"]=0, ["temp"]=12, ["pressure"]=1017.61, ["precipTotal"]=0.25, ["dewpt"]=12, ["windSpeed"]=5}, ["lon"]=-2.34702134, ["lat"]=46.72182846, ["winddir"]=193, ["obsTimeLocal"]="2019-03-31 11:00:24", ["softwareType"]="weatherlink.com 1.10", ["obsTimeUtc"]="2019-03-31T09:00:24Z", ["humidity"]=97, ["qcStatus"]=-1, ["stationID"]="IPAYSDEL120", ["epoch"]=1554022824, ["neighborhood"]="Ile d'yeu port-joinville"}}}
item.json.observations
returns
{{["lon"]=-2.34702134, ["neighborhood"]="Ile d'yeu port-joinville", ["stationID"]="IPAYSDEL120", ["epoch"]=1554024628, ["obsTimeLocal"]="2019-03-31 11:30:28", ["softwareType"]="weatherlink.com 1.10", ["lat"]=46.72182846, ["metric"]={["windGust"]=19, ["precipRate"]=0, ["windSpeed"]=5, ["pressure"]=1017.61, ["elev"]=15, ["windChill"]=12, ["heatIndex"]=12, ["temp"]=12, ["precipTotal"]=0.25, ["dewpt"]=12}, ["humidity"]=95, ["country"]="FR", ["winddir"]=150, ["qcStatus"]=-1, ["obsTimeUtc"]="2019-03-31T09:30:28Z"}}
How to I get for instance temp value and lon value?
Thank you
Debian buster on NUC and three RPi with buster.
Re: Replacing native wunderground interface
Number8 wrote: Sunday 31 March 2019 11:34 Hello,
item.json
returns this string
returns
Thank you
Happy to help if you send me the original call to wunderground via PM. The strings you supplied here are not interpreted by dz.utils.JSON as valid so I cannot test properly.
Number8
Re: Replacing native wunderground interface  [Solved]
Post by Number8 »
Thanks @waaren. In the meantine I found the solution. I did not know that json table index starts at 1 and not 0
So the code is the following
domoticz.log (item.json.observations[1].humidity)
domoticz.log (item.json.observations[1].metric.temp)
domoticz.log (item.json.observations[1].metric.pressure)
Snowtiger
Domoticz version: 4.10915
Post by Snowtiger »
Not to spoil your fun or interfere with what your doing, but ......
In the current Bèta WU is back again using the new api.
Just for your information.
Number8
Post by Number8 »
Yeap thank you but for the time beeing I'm far from upgrading. My system is in production (3 Domoticz instances) and I will upgrade at summer time when any problem that might arise during the process is not critical. I posted the whole script in examples folder.
