Is seems that when I turn on the plug in domoticz, it turn on then off 1 to 3 times :
I try with a timer but it doesn t help.
It is like the status comming from the plug sent to domoticz make domoticz sending a switch command to the same plug in a loop
Here is the log :
2019-03-16 09:52:57.472 (zigate1) onHeartbeat - busy = False
2019-03-16 09:52:57.964 Delaying switch [zigate1 - Plug 4 -84182600000c7707-03] action (On) for 2 seconds
2019-03-16 09:52:57.963 Status: User: Admin initiated a switch command (161/zigate1 - Plug 4 -84182600000c7707-03/On)
2019-03-16 09:53:00.032 (zigate1) onCommand - unit: 8, command: On, level: 0, color:
2019-03-16 09:53:00.032 (zigate1) onCommand called for Devices[8].Name: zigate1 - Plug 4 -84182600000c7707-03 SwitchType: 0 Command: On Level: 0 Color:
2019-03-16 09:53:00.032 (zigate1) mgtCommand - NWKID = 270d
2019-03-16 09:53:00.032 (zigate1) mgtCommand : found Device : 161 in Ep 03 Plug
2019-03-16 09:53:00.032 (zigate1) mgtCommand - List of TypeName : ['Plug']
2019-03-16 09:53:00.032 (zigate1) mgtCommand - DeviceType : Plug
2019-03-16 09:53:00.033 (zigate1) mgtCommand : Found Ep 03 for Device 161 Cluster 0006
2019-03-16 09:53:00.033 (zigate1) EPout = 03
2019-03-16 09:53:00.033 (zigate1) UpdateDevice_v2 for : 8 Battery Level = {} Signal Level = 100
2019-03-16 09:53:00.033 (zigate1) UpdateDevice_v2 for : 8 RSSI = 5
2019-03-16 09:53:00.033 (zigate1) UpdateDevice - (zigate1 - Plug 4 -84182600000c7707-03) 1:On
2019-03-16 09:53:00.034 (zigate1) Update Values 1:'On:' (zigate1 - Plug 4 -84182600000c7707-03)
2019-03-16 09:53:00.034 (zigate1 - Plug 4 -84182600000c7707-03) Updating device from 0:'Off' to have values 1:'On'.
2019-03-16 09:53:00.043 (zigate1) Sending 21 bytes of data
2019-03-16 09:53:00.044 (zigate1) 01 02 10 92 02 10 02 16 bf 02 12 27 02 1d 02 11 02 13 02 11 ...�....�..'........
2019-03-16 09:53:00.044 (zigate1) 03 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .
2019-03-16 09:53:00.144 (zigate1) Received 47 bytes of data
2019-03-16 09:53:00.144 (zigate1) 01 80 02 10 02 10 02 15 63 02 10 74 02 10 92 02 10 03 01 81 .�......c..t..�....�
2019-03-16 09:53:00.144 (zigate1) 02 12 02 10 02 1e db 02 13 27 02 1d 02 13 02 10 02 16 02 10 ......�..'..........
2019-03-16 09:53:00.144 (zigate1) 02 10 02 10 10 02 10 .. .. .. .. .. .. .. .. .. .. .. .. .. .......
2019-03-16 09:53:00.144 (zigate1) Received 6 bytes of data
2019-03-16 09:53:00.144 (zigate1) 02 11 02 11 6a 03 .. .. .. .. .. .. .. .. .. .. .. .. .. .. ....j.
2019-03-16 09:53:00.145 (zigate1) ZigateRead - decoded data : 018000000563007400920003 lenght : 24
2019-03-16 09:53:00.145 (zigate1) ZigateRead - MsgType: 8000, MsgLength: 0005, MsgCRC: 63, Data: 00740092; RSSI: 00
2019-03-16 09:53:00.145 (zigate1) ZigateRead - MsgType 8000 - reception status : 018000000563007400920003
2019-03-16 09:53:00.145 (zigate1) Decode8000_v2 - MsgData lenght is : 8 out of 8
2019-03-16 09:53:00.145 (zigate1) Decode8000_v2 - status: Success SEQ: 74 Packet Type: 0092
2019-03-16 09:53:00.146 (zigate1) ZigateRead - decoded data : 018102000edb03270d030006000000100001016a03 lenght : 42
2019-03-16 09:53:00.146 (zigate1) ZigateRead - MsgType: 8102, MsgLength: 000e, MsgCRC: db, Data: 03270d03000600000010000101; RSSI: 6a
2019-03-16 09:53:00.146 (zigate1) ZigateRead - MsgType 8102 - Report Individual Attribute response : 018102000edb03270d030006000000100001016a03
2019-03-16 09:53:00.146 (zigate1) Decode8102 - Individual Attribute response : [270d:03] ClusterID: 0006 AttributeID: 0000 Status: 00 Type: 10 Size: 0001 ClusterData: >01<
2019-03-16 09:53:00.146 (zigate1) DeviceExist - Found in ListOfDevices with status = inDB
2019-03-16 09:53:00.146 (zigate1) Decode8102 : Attribute Report from 270d SQN = 03 ClusterID = 0006 AttrID = 0000 Attribute Data = 01
2019-03-16 09:53:00.146 (zigate1) Not the good Domoticz level for Touch
2019-03-16 09:53:00.147 (zigate1) Device : 270d MacCapa : 8e updating SQN to 03
2019-03-16 09:53:00.147 (zigate1) ReadCluster - MsgData lenght is: 26 out of 24+
2019-03-16 09:53:00.147 (zigate1) DeviceExist - Found in ListOfDevices with status = inDB
2019-03-16 09:53:00.147 (zigate1) ReadCluster - 0006 NwkId: 270d Ep: 03 AttrId: 0000 AttyType: 10 Attsize: 0001 Status: 00 AttrValue: 01
2019-03-16 09:53:00.147 (zigate1) MajDomoDevice - Device ID : 84182600000c7707 - Device EP : 03 - Type : 0006 - Value : 01 - Hue : - Attribute_ :
2019-03-16 09:53:00.147 (zigate1) ClusterSearch - Cluster: 0006, ProfileID: , ZDeviceID: , create: False
2019-03-16 09:53:00.147 (zigate1) MajDomoDevice - Type = Switch
2019-03-16 09:53:00.147 (zigate1) MajDomoDevice - NWKID = 270d IEEE = 84182600000c7707 Unit = 161
2019-03-16 09:53:00.148 (zigate1) MajDomoDevice - {'0004': {}, '1000': {}, '0006': '00', 'ClusterType': {'161': 'Plug'}, '0003': {}, 'Type': 'Plug', '0005': {}, '0019': {}, '0000': {}}
2019-03-16 09:53:00.148 (zigate1) MajDomoDevice - We have 1 EPs with ClusterType
2019-03-16 09:53:00.148 (zigate1) MajDomoDevice - NWKID: 270d SwitchType: 0, DeviceType: Plug, ClusterType: Switch, old_nVal: 1 , old_sVal: On
2019-03-16 09:53:00.148 (zigate1) UpdateDevice_v2 for : 8 Battery Level = {} Signal Level = 106
2019-03-16 09:53:00.148 (zigate1) UpdateDevice_v2 for : 8 RSSI = 5
2019-03-16 09:53:00.148 (zigate1) ReadCluster - ClusterId=0006 - reception General: On/Off: 01
2019-03-16 09:53:02.052 (zigate1) onCommand - unit: 8, command: Off, level: 0, color:
2019-03-16 09:53:02.052 (zigate1) onCommand called for Devices[8].Name: zigate1 - Plug 4 -84182600000c7707-03 SwitchType: 0 Command: Off Level: 0 Color:
2019-03-16 09:53:02.052 (zigate1) mgtCommand - NWKID = 270d
2019-03-16 09:53:02.052 (zigate1) mgtCommand : found Device : 161 in Ep 03 Plug
2019-03-16 09:53:02.052 (zigate1) mgtCommand - List of TypeName : ['Plug']
2019-03-16 09:53:02.052 (zigate1) mgtCommand - DeviceType : Plug
2019-03-16 09:53:02.052 (zigate1) mgtCommand : Found Ep 03 for Device 161 Cluster 0006
2019-03-16 09:53:02.052 (zigate1) EPout = 03
2019-03-16 09:53:02.053 (zigate1) UpdateDevice_v2 for : 8 Battery Level = {} Signal Level = 106
2019-03-16 09:53:02.053 (zigate1) UpdateDevice_v2 for : 8 RSSI = 5
2019-03-16 09:53:02.053 (zigate1) UpdateDevice - (zigate1 - Plug 4 -84182600000c7707-03) 0:Off
2019-03-16 09:53:02.053 (zigate1) Update Values 0:'Off:' (zigate1 - Plug 4 -84182600000c7707-03)
2019-03-16 09:53:02.053 (zigate1 - Plug 4 -84182600000c7707-03) Updating device from 1:'On' to have values 0:'Off'.
2019-03-16 09:53:02.063 (zigate1) Sending 21 bytes of data
2019-03-16 09:53:02.063 (zigate1) 01 02 10 92 02 10 02 16 be 02 12 27 02 1d 02 11 02 13 02 10 ...�....�..'........
2019-03-16 09:53:02.063 (zigate1) 03 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .
2019-03-16 09:53:02.163 (zigate1) Received 18 bytes of data
2019-03-16 09:53:02.163 (zigate1) 01 80 02 10 02 10 02 15 62 02 10 75 02 10 92 02 10 03 .. .. .�......b..u..�...
2019-03-16 09:53:02.164 (zigate1) ZigateRead - decoded data : 018000000562007500920003 lenght : 24
2019-03-16 09:53:02.164 (zigate1) ZigateRead - MsgType: 8000, MsgLength: 0005, MsgCRC: 62, Data: 00750092; RSSI: 00
2019-03-16 09:53:02.164 (zigate1) ZigateRead - MsgType 8000 - reception status : 018000000562007500920003
2019-03-16 09:53:02.164 (zigate1) Decode8000_v2 - MsgData lenght is : 8 out of 8
2019-03-16 09:53:02.164 (zigate1) Decode8000_v2 - status: Success SEQ: 75 Packet Type: 0092
2019-03-16 09:53:02.465 (zigate1) onHeartbeat - busy = False
2019-03-16 09:53:08.739 (zigate1) ZigateRead - MsgType: 8140, MsgLength: 0005, MsgCRC: 83, Data: 01200001; RSSI: 67
2019-03-16 09:53:08.740 (zigate1) ZigateRead - MsgType 8140 - Reception Attribute discovery response : 018140000583012000016703
2019-03-16 09:53:08.740 (zigate1) ZigateRead - decoded data : 018140000581012100026703 lenght : 24
2019-03-16 09:53:08.740 (zigate1) ZigateRead - MsgType: 8140, MsgLength: 0005, MsgCRC: 81, Data: 01210002; RSSI: 67
2019-03-16 09:53:08.740 (zigate1) ZigateRead - MsgType 8140 - Reception Attribute discovery response : 018140000581012100026703
2019-03-16 09:53:08.741 (zigate1) ZigateRead - decoded data : 0181400005b1011000036703 lenght : 24
2019-03-16 09:53:08.741 (zigate1) ZigateRead - MsgType: 8140, MsgLength: 0005, MsgCRC: b1, Data: 01100003; RSSI: 67
2019-03-16 09:53:08.741 (zigate1) ZigateRead - MsgType 8140 - Reception Attribute discovery response : 0181400005b1011000036703
2019-03-16 09:53:08.742 (zigate1) ZigateRead - decoded data : 0181400005be011800046703 lenght : 24
2019-03-16 09:53:08.742 (zigate1) ZigateRead - MsgType: 8140, MsgLength: 0005, MsgCRC: be, Data: 01180004; RSSI: 67
2019-03-16 09:53:08.742 (zigate1) ZigateRead - MsgType 8140 - Reception Attribute discovery response : 0181400005be011800046703
2019-03-16 09:53:08.742 (zigate1) Sending 31 bytes of data
2019-03-16 09:53:08.742 (zigate1) 01 02 11 40 02 10 02 1c 81 02 12 27 02 1d 02 11 02 13 02 10 ...@....�..'........
2019-03-16 09:53:08.742 (zigate1) 19 02 10 02 10 02 10 02 10 ff 03 .. .. .. .. .. .. .. .. .. .........�.
2019-03-16 09:53:08.842 (zigate1) Received 39 bytes of data
2019-03-16 09:53:08.842 (zigate1) 01 80 02 10 02 10 02 15 46 02 10 82 02 11 40 02 10 03 01 81 .�......F..�..@....�
2019-03-16 09:53:08.843 (zigate1) 02 11 02 10 02 17 78 82 02 13 02 10 19 02 1c 02 11 6a 03 .. ......x�.........j.
2019-03-16 09:53:08.844 (zigate1) ZigateRead - decoded data : 018000000546008201400003 lenght : 24
2019-03-16 09:53:08.844 (zigate1) ZigateRead - MsgType: 8000, MsgLength: 0005, MsgCRC: 46, Data: 00820140; RSSI: 00
2019-03-16 09:53:08.844 (zigate1) ZigateRead - MsgType 8000 - reception status : 018000000546008201400003
2019-03-16 09:53:08.844 (zigate1) Decode8000_v2 - MsgData lenght is : 8 out of 8
2019-03-16 09:53:08.844 (zigate1) Decode8000_v2 - status: Success SEQ: 82 Packet Type: 0140
2019-03-16 09:53:08.844 (zigate1) ZigateRead - decoded data : 018101000778820300190c016a03 lenght : 28
2019-03-16 09:53:08.844 (zigate1) ZigateRead - MsgType: 8101, MsgLength: 0007, MsgCRC: 78, Data: 820300190c01; RSSI: 6a
2019-03-16 09:53:08.845 (zigate1) ZigateRead - MsgType 8101 - Default Response: 018101000778820300190c016a03
2019-03-16 09:53:08.845 (zigate1) Decode8101 - Default response - SQN: 82, EP: 03, ClusterID: 0019 , DataCommand: 0c, - Status: [01] Incorrect Parameters
2019-03-16 09:53:08.845 (zigate1) Sending 32 bytes of data
2019-03-16 09:53:08.845 (zigate1) 01 02 11 40 02 10 02 1c 98 02 12 27 02 1d 02 11 02 13 02 10 ...@....�..'........
2019-03-16 09:53:08.845 (zigate1) 02 10 02 10 02 10 02 10 02 10 ff 03 .. .. .. .. .. .. .. .. ..........�.
2019-03-16 09:53:08.945 (zigate1) Received 18 bytes of data
2019-03-16 09:53:08.945 (zigate1) 01 80 02 10 02 10 02 15 47 02 10 83 02 11 40 02 10 03 .. .. .�......G..�..@...
2019-03-16 09:53:08.945 (zigate1) Received 168 bytes of data
2019-03-16 09:53:08.945 (zigate1) 01 81 40 02 10 02 15 82 02 11 20 02 10 02 10 67 03 01 81 40 .�@....�.......g..�@
2019-03-16 09:53:08.945 (zigate1) 02 10 02 15 83 02 11 20 02 10 02 11 67 03 01 81 40 02 10 02 ....�.......g..�@...
2019-03-16 09:53:08.946 (zigate1) 15 80 02 11 20 02 10 02 12 67 03 01 81 40 02 10 02 15 81 02 .�.......g..�@....�.
2019-03-16 09:53:08.946 (zigate1) 11 20 02 10 02 13 67 03 01 81 40 02 10 02 15 e4 02 11 42 02 ......g..�@....�..B.
2019-03-16 09:53:08.946 (zigate1) 10 02 14 67 03 01 81 40 02 10 02 15 e5 02 11 42 02 10 02 15 ...g..�@....�..B....
2019-03-16 09:53:08.946 (zigate1) 67 03 01 81 40 02 10 02 15 e6 02 11 42 02 10 02 16 67 03 01 g..�@....�..B....g..
2019-03-16 09:53:08.946 (zigate1) 81 40 02 10 02 15 95 02 11 30 02 10 02 17 67 03 01 81 40 02 �@....�..0....g..�@.
2019-03-16 09:53:08.946 (zigate1) 10 02 15 a0 02 11 10 02 10 12 67 03 01 81 40 02 10 02 15 a0 ...�......g..�@....�
2019-03-16 09:53:08.946 (zigate1) 02 11 42 40 02 10 67 03 .. .. .. .. .. .. .. .. .. .. .. .. [email protected].
2019-03-16 09:53:08.946 (zigate1) ZigateRead - decoded data : 018000000547008301400003 lenght : 24
2019-03-16 09:53:08.947 (zigate1) ZigateRead - MsgType: 8000, MsgLength: 0005, MsgCRC: 47, Data: 00830140; RSSI: 00
2019-03-16 09:53:08.947 (zigate1) ZigateRead - MsgType 8000 - reception status : 018000000547008301400003
2019-03-16 09:53:08.947 (zigate1) Decode8000_v2 - MsgData lenght is : 8 out of 8
2019-03-16 09:53:08.947 (zigate1) Decode8000_v2 - status: Success SEQ: 83 Packet Type: 0140
2019-03-16 09:53:08.947 (zigate1) ZigateRead - decoded data : 018140000582012000006703 lenght : 24
2019-03-16 09:53:08.947 (zigate1) ZigateRead - MsgType: 8140, MsgLength: 0005, MsgCRC: 82, Data: 01200000; RSSI: 67
2019-03-16 09:53:08.948 (zigate1) ZigateRead - MsgType 8140 - Reception Attribute discovery response : 018140000582012000006703
2019-03-16 09:53:08.948 (zigate1) ZigateRead - decoded data : 018140000583012000016703 lenght : 24
2019-03-16 09:53:08.948 (zigate1) ZigateRead - MsgType: 8140, MsgLength: 0005, MsgCRC: 83, Data: 01200001; RSSI: 67
2019-03-16 09:53:08.948 (zigate1) ZigateRead - MsgType 8140 - Reception Attribute discovery response : 018140000583012000016703
2019-03-16 09:53:08.949 (zigate1) ZigateRead - decoded data : 018140000580012000026703 lenght : 24
2019-03-16 09:53:08.949 (zigate1) ZigateRead - MsgType: 8140, MsgLength: 0005, MsgCRC: 80, Data: 01200002; RSSI: 67
2019-03-16 09:53:08.949 (zigate1) ZigateRead - MsgType 8140 - Reception Attribute discovery response : 018140000580012000026703
2019-03-16 09:53:08.949 (zigate1) ZigateRead - decoded data : 018140000581012000036703 lenght : 24
2019-03-16 09:53:08.949 (zigate1) ZigateRead - MsgType: 8140, MsgLength: 0005, MsgCRC: 81, Data: 01200003; RSSI: 67
2019-03-16 09:53:08.950 (zigate1) ZigateRead - MsgType 8140 - Reception Attribute discovery response : 018140000581012000036703
2019-03-16 09:53:08.950 (zigate1) ZigateRead - decoded data : 0181400005e4014200046703 lenght : 24
2019-03-16 09:53:08.950 (zigate1) ZigateRead - MsgType: 8140, MsgLength: 0005, MsgCRC: e4, Data: 01420004; RSSI: 67
2019-03-16 09:53:08.950 (zigate1) ZigateRead - MsgType 8140 - Reception Attribute discovery response : 0181400005e4014200046703
2019-03-16 09:53:08.951 (zigate1) ZigateRead - decoded data : 0181400005e5014200056703 lenght : 24
2019-03-16 09:53:08.951 (zigate1) ZigateRead - MsgType: 8140, MsgLength: 0005, MsgCRC: e5, Data: 01420005; RSSI: 67
2019-03-16 09:53:08.951 (zigate1) ZigateRead - MsgType 8140 - Reception Attribute discovery response : 0181400005e5014200056703
2019-03-16 09:53:08.951 (zigate1) ZigateRead - decoded data : 0181400005e6014200066703 lenght : 24
2019-03-16 09:53:08.951 (zigate1) ZigateRead - MsgType: 8140, MsgLength: 0005, MsgCRC: e6, Data: 01420006; RSSI: 67
2019-03-16 09:53:08.952 (zigate1) ZigateRead - MsgType 8140 - Reception Attribute discovery response : 0181400005e6014200066703
2019-03-16 09:53:08.952 (zigate1) ZigateRead - decoded data : 018140000595013000076703 lenght : 24
2019-03-16 09:53:08.952 (zigate1) ZigateRead - MsgType: 8140, MsgLength: 0005, MsgCRC: 95, Data: 01300007; RSSI: 67
2019-03-16 09:53:08.952 (zigate1) ZigateRead - MsgType 8140 - Reception Attribute discovery response : 018140000595013000076703
2019-03-16 09:53:08.953 (zigate1) ZigateRead - decoded data : 0181400005a0011000126703 lenght : 24
2019-03-16 09:53:08.953 (zigate1) ZigateRead - MsgType: 8140, MsgLength: 0005, MsgCRC: a0, Data: 01100012; RSSI: 67
2019-03-16 09:53:08.953 (zigate1) ZigateRead - MsgType 8140 - Reception Attribute discovery response : 0181400005a0011000126703
2019-03-16 09:53:08.953 (zigate1) ZigateRead - decoded data : 0181400005a0014240006703 lenght : 24
2019-03-16 09:53:08.953 (zigate1) ZigateRead - MsgType: 8140, MsgLength: 0005, MsgCRC: a0, Data: 01424000; RSSI: 67
2019-03-16 09:53:08.954 (zigate1) ZigateRead - MsgType 8140 - Reception Attribute discovery response : 0181400005a0014240006703
2019-03-16 09:53:09.705 (zigate1) Received 35 bytes of data
2019-03-16 09:53:09.705 (zigate1) 01 81 02 12 02 10 02 1e d0 02 14 27 02 1d 02 13 02 10 02 16 .�......�..'........
2019-03-16 09:53:09.705 (zigate1) 02 10 02 10 02 10 10 02 10 02 11 02 10 67 03 .. .. .. .. .. .............g.
2019-03-16 09:53:09.706 (zigate1) ZigateRead - decoded data : 018102000ed004270d030006000000100001006703 lenght : 42
2019-03-16 09:53:09.706 (zigate1) ZigateRead - MsgType: 8102, MsgLength: 000e, MsgCRC: d0, Data: 04270d03000600000010000100; RSSI: 67
2019-03-16 09:53:09.706 (zigate1) ZigateRead - MsgType 8102 - Report Individual Attribute response : 018102000ed004270d030006000000100001006703
2019-03-16 09:53:09.706 (zigate1) Decode8102 - Individual Attribute response : [270d:03] ClusterID: 0006 AttributeID: 0000 Status: 00 Type: 10 Size: 0001 ClusterData: >00<
2019-03-16 09:53:09.706 (zigate1) DeviceExist - Found in ListOfDevices with status = inDB
2019-03-16 09:53:09.706 (zigate1) Decode8102 : Attribute Report from 270d SQN = 04 ClusterID = 0006 AttrID = 0000 Attribute Data = 00
2019-03-16 09:53:09.706 (zigate1) Not the good Domoticz level for Touch
2019-03-16 09:53:09.707 (zigate1) Device : 270d MacCapa : 8e updating SQN to 04
2019-03-16 09:53:09.707 (zigate1) ReadCluster - MsgData lenght is: 26 out of 24+
2019-03-16 09:53:09.707 (zigate1) DeviceExist - Found in ListOfDevices with status = inDB
2019-03-16 09:53:09.707 (zigate1) ReadCluster - 0006 NwkId: 270d Ep: 03 AttrId: 0000 AttyType: 10 Attsize: 0001 Status: 00 AttrValue: 00
2019-03-16 09:53:09.707 (zigate1) MajDomoDevice - Device ID : 84182600000c7707 - Device EP : 03 - Type : 0006 - Value : 00 - Hue : - Attribute_ :
2019-03-16 09:53:09.707 (zigate1) ClusterSearch - Cluster: 0006, ProfileID: , ZDeviceID: , create: False
2019-03-16 09:53:09.707 (zigate1) MajDomoDevice - Type = Switch
2019-03-16 09:53:09.707 (zigate1) MajDomoDevice - NWKID = 270d IEEE = 84182600000c7707 Unit = 161
2019-03-16 09:53:09.708 (zigate1) MajDomoDevice - {'0004': {}, '1000': {}, '0006': '01', 'ClusterType': {'161': 'Plug'}, '0003': {}, 'Type': 'Plug', '0005': {}, '0019': {}, '0000': {}}
2019-03-16 09:53:09.708 (zigate1) MajDomoDevice - We have 1 EPs with ClusterType
2019-03-16 09:53:09.708 (zigate1) MajDomoDevice - NWKID: 270d SwitchType: 0, DeviceType: Plug, ClusterType: Switch, old_nVal: 0 , old_sVal: Off
2019-03-16 09:53:09.708 (zigate1) UpdateDevice_v2 for : 8 Battery Level = {} Signal Level = 103
2019-03-16 09:53:09.708 (zigate1) UpdateDevice_v2 for : 8 RSSI = 5
2019-03-16 09:53:09.708 (zigate1) ReadCluster - ClusterId=0006 - reception General: On/Off: 00
2019-03-16 09:53:12.463 (zigate1) onHeartbeat - busy = True
2019-03-16 09:53:12.463 (zigate1) Skip LQI, ConfigureReporting and Networkscan du to Busy state: Busy: True, Enroll: False
2019-03-16 09:53:12.467 (zigate1) updateNotificationWidget - Zigate-02- 2 nValue: 1, sValue: Ready/Busy
2019-03-16 09:53:12.467 (zigate1 - Zigate Status 2) Updating device from 3:'Busy' to have values 1:'Ready'.
2019-03-16 09:53:17.479 (zigate1) onHeartbeat - busy = False
