Python Plugin: Chromecast Topic is solved
- Dnpwwo
Re: Python Plugin: Chromecast
@Ewaldharmsen,
I couldn't get 'Chromecast.start()' to work either in my plugin and could not work it out.
I used 'Chromecast.socket_client.start()' instead and it did the trick. Still don't know why though...
I think the best thing you can do is:
sudo rm -r /home/pi/domoticz/plugins/ChromecastPlugin/
sudo pip3 uninstall pychromecast
cd domoticz/plugins
git clone https://github.com/Tsjippy/ChromecastPlugin
sudo pip3 install pychromecast
sudo pip3 show pychromecast
make sure cd /usr/local/lib/python3.5/dist-packages/pychromecast/ exists.
- Domoticz version: 2020.2
something is still going wrong after reinstall, these are the switches it made:
You have made a paste error. I think you usedsnellejellep wrote: ↑Tuesday 26 March 2019 15:38 something is still going wrong after reinstall, these are the switches it made:
as a Chromecasts name in hardware settingscd /usr/local/lib/python3.5/dist-packages/pychromecast/
- Domoticz version: latest B
followed the instructions and when enabling the plugin, again it starts respawning.Ewaldharmsen wrote: ↑Tuesday 26 March 2019 11:04I think the best thing you can do is:
cd domoticz/plugins
ps -ef | grep domoticz
root 690 1 16 15:48 ? 00:00:16 /home/pi/domoticz/domoticz -daemon -www 8900 -sslwww 443
root 912 690 0 15:48 ? 00:00:00 /home/pi/domoticz/domoticz -daemon -www 8900 -sslwww 443
root 1259 690 0 15:49 ? 00:00:00 /home/pi/domoticz/domoticz -daemon -www 8900 -sslwww 443
2019-03-26 15:50:18.088 (Chromecast) Setting device 22 as timed out
2019-03-26 15:50:18.091 (Chromecast) Setting device 23 as timed out
2019-03-26 15:50:18.097 (Chromecast) Setting device 24 as timed out
2019-03-26 15:50:18.101 Status: (Chromecast) Disconnecting from 'Living Room speaker'
2019-03-26 15:50:23.078 (Chromecast) 'Living Room speaker' is disconnected.
2019-03-26 15:50:23.078 (Chromecast) Setting device 51 as timed out
2019-03-26 15:50:23.079 Status: (Chromecast) Disconnecting from 'Living Room mini'
2019-03-26 15:50:23.078 Error: (Chromecast) Error on line 846 Error is 6
2019-03-26 15:50:27.472 (Chromecast) 'Living Room mini' is disconnected.
2019-03-26 15:50:27.472 (Chromecast) Setting device 41 as timed out
2019-03-26 15:50:27.472 Status: (Chromecast) Disconnecting from 'Living Room TV'
2019-03-26 15:50:27.472 Error: (Chromecast) Error on line 846 Error is 5
2019-03-26 15:50:32.261 (Chromecast) 'Living Room TV' is disconnected.
but also see the following error in the log:
2019-03-26 15:50:12.350 Error: (Chromecast) Error on line 846 Error is 8
can you update to version 4.0.1?
my bad... indeed i did that wrong.Ewaldharmsen wrote: ↑Tuesday 26 March 2019 15:52You have made a paste error. I think you usedsnellejellep wrote: ↑Tuesday 26 March 2019 15:38 something is still going wrong after reinstall, these are the switches it made:
now it shows all my devices and it seems to work. thank you!
git pull => Already up to date.
Can you post your version info?
Python, Domoticz etc.
HW: RPI3+ (With SSD)Ewaldharmsen wrote: ↑Tuesday 26 March 2019 16:16 Can you post your version info?
Domoticz 4.10572
Python 3.5.3
OS: Raspbian GNU/Linux 9 (stretch) - last update yesterday
Other (external) plugins:
- Domoticz-Tuya-SmartBulb-Plugin
- Zigbee2MQTT
Update:
I see also increasing number of PluginMgr processes started / running when I have the problem.
Strange I have the same versions. Can you try disabling the other plugins and removing and reinstalling the Chromecasts plugin?wvries wrote: ↑Tuesday 26 March 2019 16:23HW: RPI3+ (With SSD)Ewaldharmsen wrote: ↑Tuesday 26 March 2019 16:16 Can you post your version info?
Domoticz 4.10572
Python 3.5.3
- Zigbee2MQTT
Update:
- Domoticz version: Beta 4.1
@Ewald
Reinstalled the plugin and now it is running like never before. Thanks a lot.
Verstuurd vanaf mijn ONEPLUS A6003 met Tapatalk
Hi ,
I have installed the chromecast plugin and I get the error below. In this chat about this topic, I saw the advice to de-install and re-install, but it does not help unfortunatelly.
Does anybody has an idea to solve this problem?
2019-03-27 08:01:09.328 Status: (Chromecast devices) Started.
2019-03-27 08:01:09.612 Error: (Chromecast) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/ChromecastPlugin/:/usr/lib/python35.zip:/usr/lib/python3.5:/usr/lib/python3.5/plat-arm-linux-gnueabihf:/usr/lib/python3.5/lib-dynload'.
2019-03-27 08:01:09.612 Error: (Chromecast devices) Module Import failed, exception: 'ImportError'
2019-03-27 08:01:09.613 Error: (Chromecast devices) Module Import failed: ' Name: requests'
2019-03-27 08:01:09.613 Error: (Chromecast devices) Error Line details not available
Version info:
Domoticz v.9700 on Raspberry pi
Python 3.5.3
Version info:
Python 3.5.3
sudo pip3 install requestspeterenderest wrote: ↑Wednesday 27 March 2019 8:10 Hi ,
Version info:
Python 3.5.3
@Ewaldharmsen thanks for your reply!, I tried this, but get the following message: Requirement already satisfied: requests in /usr/lib/python3/dist-packagesEwaldharmsen wrote: ↑Wednesday 27 March 2019 8:24sudo pip3 install requestspeterenderest wrote: ↑Wednesday 27 March 2019 8:10 Hi ,
Version info:
Python 3.5.3
Do I have to include this in the python path? And if yes, how do I do this?
You should update to the latest Domoticz beta version
Thanks! It works now smoothly!Ewaldharmsen wrote: ↑Wednesday 27 March 2019 20:16 You should update to the latest Domoticz beta version
Keep getting this error. It is like the attribute start has been removed or something?
2019-04-01 19:15:54.807 Status: (Chromecast) Found these chromecasts: 'Google Home Mini', 'Chromecast'
2019-04-01 19:15:54.808 Error: (Chromecast) Error on line 556 Error is 'Chromecast' object has no attribute 'start'
Domo version V4.10590 (I beleive I'm on beta?
Any ideas?
Any ideas?
you have to update PyChromecast:Tobbo wrote: ↑Monday 01 April 2019 19:18 Keep getting this error. It is like the attribute start has been removed or something?
Domo version V4.10590 (I beleive I'm on beta?![]()
Any ideas?
sudo pip3 uninstall PyChromecast
sudo pip3 install PyChromecast
First of all, thank you for a very quick answer.Ewaldharmsen wrote: ↑Monday 01 April 2019 20:04you have to update PyChromecast:Tobbo wrote: ↑Monday 01 April 2019 19:18 Keep getting this error. It is like the attribute start has been removed or something?
Any ideas?Code: Select all
So after following your instructions and also restarting the domoticz service, things started to work, BUT, I'm getting some new errors regarding spotify it seems.
- Spoiler: show
