New Domoticz Events design
ak97
Domoticz version: latest
Re: New Domoticz Events design
Post by ak97 »
StasDemydiuk wrote: Sunday 06 January 2019 9:48 Could you please explain what do you mean by "trigger mechanism". Currently I don't understand what are you asking for.
https://www.domoticz.com/wiki/Events
StasDemydiuk
Post by StasDemydiuk »
ak97
Post by ak97 »
StasDemydiuk wrote: Wednesday 09 January 2019 21:15 Now should be better
https://github.com/domoticz/domoticz/pull/2948
ThomasTelos
Post by ThomasTelos »
Missing the "Save as" possibility, so if you want to make a new Event from the Old one you have to type all info new again.
Export to ..? => Can I set a directory for this (export to...) and then import this info in a new Event
SweetPants
Post by SweetPants »
This is not true, open your existing type ctrl-A, ctrl-C, create a new one and type ctrl-V
ThomasTelos
Thnx for your quick response, I tried this but Nope, if things where that simple ;-)
Someone else with a useful suggestion??
Indeed Export and then Import? How/Where directory to Copy to too select?
ThomasTelos
Hey SweetPants, you are in the wright way.
This is how I have done it:
1. Open your Event
2. Click Export => a text screen with code will appear
3. => Select all this code, and click then Ctrl+C
4. Open a new event and Click Import
5 Click then: Ctrl+V
6. Your copied Event will appear and can be saved under an other name
SweetPants
ThomasTelos wrote: Monday 25 March 2019 17:19 Hey SweetPants, you are in the wright way.
1. Open your Event
My Method also works, i use it all the time when modifying a script i copy with Ctrl-a/Ctrl-c, open a new one and Ctrl-a/Ctrl-v
