MQTT -Roller Shutter TASMOTA Dual R2
Everything about esp8266 and more.
skorc11
Post by skorc11 »
i have dual R2 with tasmota FW- stefanbode patch.
Shutters are working and now i would like to send MQTT commands .
I created blinds percentage device .
Default Domoticz command :
10:02:12 MQT: stat/sonoff_dual_R2/RESULT = {"Command":"Unknown"}
10:02:45 Shutter unknown
10:02:45 MQT: stat/sonoff_dual/RESULT = {"Command":"Unknown"}
I have to send the percentage to shutterposition1 as a command- MQTT
Is this possible ?
U
skorc11
Re: Roller Shutter TASMOTA Dual R2 MQTTupdate
Post by skorc11 »
tasmota FW with StefanB patch is now working- based on svalue- slider is ok.
"idx":156,"nvalue":0,"svalue":"56","Battery":58,"RSSI":5
But NVALUE is always 0.
it should be 0,2,1.
nValue 0 and sValue 0 ==>> Closed
nValue 2 and sValue 2-99 ==>> partially opened
nValue 1 and sValue 100 ==>> Opened
Nvalue reads relay it is not as dimmer.. (1 when releay is ON-blind moving 0 when stopped)
Is it possible to change this in any way ?
U
salvacalatayud
Re: MQTT -Roller Shutter TASMOTA Dual R2
Post by salvacalatayud »
I'm interested in this project. But I even don't know how to install this firmware.
Anyone can help?
Thanks in advance
skorc11
Post by skorc11 »
stefanbode is still working on FW.. I will post when it is done. Till now manual control with MQTT position is working perfect.
U
salvacalatayud
skorc11 wrote:Hello,
U
Great news then.
Yesterday I flashed my sonoff touch and worked, after that unpluged it and today plugged again but it doesn't connect to wifi...
Enviado desde mi Mi A2 mediante Tapatalk
salvacalatayud
My sonoff are t1 2ch, can't work for now.
I'll be waitning for it
salvacalatayud
skorc11 wrote: Sunday 11 November 2018 8:12 Hello,
it should be 0,2,1.
U
What kind of blind are you using to send % to the sonoff? I've tried with blinds percentaje and doesn't work
salvacalatayud
I use node red to translate domoticz to tasmota mqtt, it sends a mqtt command, tasmota sends a status position, and node red updates the position back to Domotcz by http, then the shutter moves again to a diferent position, small movements. This happens a few times and then stops.
Any idea of how to deal with this?
AchilleTalon
Domoticz version: 2023.2
Post by AchilleTalon »
Sorry to "revive" an old topic, but apparently I can't send PMs yet.
I use domoticz and Shelly"s 2.5 with tasmota to control blinds, but I wasn't able to find a proper setup for tasmota (the "configure Domoticz" section): I'm still stuck with virtual buttons and a blockly script.
Could you please share the way you setup your tasmota module?
Thanks in advance.
Domoticz version: 2025.1
This plugin supports standard Shelly devices https://github.com/enesbcs/Shelly_MQTT
Tasmoticz perhaps also supports shutters (it is on the roadmap) https://github.com/joba-1/Tasmoticz
AchilleTalon
waltervl wrote: Wednesday 26 May 2021 1:30 This plugin supports standard Shelly devices https://github.com/enesbcs/Shelly_MQTT
Thanks. I'll look into it. Shelly_MQTT seems to work fine for "standard" devices, but I'd like to use an already flashed Shelly 2.5 (already installed, I'd like not to have to take it out, reflash it, then put it back): Tasmoticz will hopefully be the solution.
