I connected two Domoticz servers yesterday for Device Sharing.
I want to share two Wallplugs (switches and kWh usage) and two Dummy switches. I already noticed on the forum that Dummy switches are probably not possible to share currently, however the Wallplugs switches are also not showing up. I can only see the Wallplug kWh utility sensors.
Can anybody help me with that?
Domoticz versions: 4.9700
The user account used for sharing the devices has all the correct devices selected and has User rights
Rebooted the "Sharing" Domoticz environment and afterwards rebooted the Master Domoticz environment without succes
Wesley
Domoticz Shared Devices issue, not all Devices showing up
wlevels
- Domoticz version: V4.9700
Re: Domoticz Shared Devices issue, not all Devices showing up
Actually I solved my own problem.
What I didn't know was that Devices are only updated once they sent an update. So switches weren't added to the Master until you used the switch.
Greets
Greets
