I have got a LUX sensor which is show "nan" in Domoticz when it's too dark.
The idea is to switch the light when the value is below 5 or equal to "nan".
I'm having difficulties to detect when the sensor value is "nan".
Can some help me with the script?
NaN comparison
- waaren
Re: NaN comparison
[EDIT] 20190301 08:17 changed state to rawData[1]
Check this and if not yet giving the results needed send output of dump() command via PM to help me understand what the idea behind nan of NaN is.
devices = {
79 -- change to your Lux device idx
ogging = {
level = domoticz.LOG_DEBUG,
marker = "Lux 2 light"
execute = function(dz, item)
local light = dz.devices(1488) -- change to idx you want to switch on / off
if tonumber(item.rawData[1]) < 5 or tostring(item.rawData[1]) == "nan" then
light.switchOn().checkFirst()
dz.log("On: " .. item.state,dz.LOG_FORCE)
light.switchOff().checkFirst()
dz.log("Off: " .. item.state,dz.LOG_FORCE)
-- item.dump() -- This will dump all relevant information from your lux device to log. Can be removed when not needed anymore
}Debian buster, bullseye on RPI-4, Intel NUC.
iganin
- Domoticz version: 2020.2
Re: NaN comparison
Getting error:
2019-03-01 18:45:27.390 Status: dzVents: Info: Handling events for: "Corridor Lux", value: "-nan"
2019-03-01 18:45:27.431 Status: dzVents: Info: ------ Start internal script: Light 1nd floor Test forum: Device: "Corridor Lux (Main)", Index: 536
2019-03-01 18:45:27.432 Status: dzVents: Error (2.4.7): An error occured when calling event handler Light 1nd floor Test forum
2019-03-01 18:45:27.432 Status: dzVents: Error (2.4.7): ...dzVents/generated_scripts/Light 1nd floor Test forum.lua:16: attempt to compare nil with number
2019-03-01 18:45:27.433 Status: dzVents: Info: ------ Finished Light 1nd floor Test forum
Forgot to mention: I2C sensor TSL2561 Illuminance
- waaren
Re: NaN comparison
Can you try this ?iganin wrote: Friday 01 March 2019 18:46 Getting error:
devices = {
logging = {
dz.log("item.rawData[1] ===>> " .. tostring(item.rawData[1]),dz.LOG_DEBUG )
if ( tonumber(item.rawData[1]) or 6 ) < 5 or tostring(item.rawData[1]) == "nan" then
iganin
Re: NaN comparison
I see no error but nothing happens.
2019-03-02 09:33:18.278 Status: dzVents: Info: Handling events for: "Corridor Lux", value: "-nan"
2019-03-02 09:33:18.279 Status: dzVents: Info: Lux 2 light: ------ Start internal script: Light 1nd floor Test forum: Device: "Corridor Lux (Main)", Index: 536
2019-03-02 09:33:18.280 Status: dzVents: Debug: Lux 2 light: Processing device-adapter for Corridor 1st Floor Light: Switch device adapter
2019-03-02 09:33:18.280 Status: dzVents: Debug: Lux 2 light: item.rawData[1] ===>> -nan
2019-03-02 09:33:18.281 Status: dzVents: Debug: Lux 2 light: Constructed timed-command: Off
2019-03-02 09:33:18.281 Status: dzVents: !Info: Lux 2 light: Off: -nan
2019-03-02 09:33:18.281 Status: dzVents: Info: Lux 2 light: ------ Finished Light 1nd floor Test forum
- waaren
Re: NaN comparison
That is because the script is designed to react on the string "nan" but your sensor produces the string "-nan". If you change line 19 toiganin wrote: Saturday 02 March 2019 9:34 I see no error but nothing happens.
if ( tonumber(item.rawData[1]) or 6 ) < 5 or tostring(item.rawData[1]) == "-nan" then Debian buster, bullseye on RPI-4, Intel NUC.
iganin
Re: NaN comparison
It now works. Super!!
Thank you for the help!!
