Nefit / Buderus data/control via Arduino / ESP8266 to Domoticz (directly without OpenTherm module or Easy)
Re: Nefit / Buderus data/control via Arduino / ESP8266 to Domoticz (directly without OpenTherm module or Easy)
@bbqkees and @proddy: Great work, I much appreciate it!
I'm looking for support of the thermostat Buderus RC310 .
@bbqkees: Could you please add a Buderus RC310 to your nice thermostat list in Github as a starting point? The RC310 picture looks like it is same as Nefit Moduline 3000.
Has anyone else already experience with this equipment and/or EMS+? I have proddy's software running on a Wemos D1 mini (Arduino IDE) and can provide telnet telegram records, but need guidance to adjust the software for my RC310.
Last edited by suncarver on Wednesday 02 January 2019 14:44, edited 1 time in total.
corrected last entry
Last edited by suncarver on Wednesday 02 January 2019 14:45, edited 1 time in total.
- bbqkees
- Domoticz version: 4.1x
EMS+ seems nearly the same as EMS its just that the third byte is 0x99 or something similar.
What boiler do you have?
It is a Buderus GB172-14, so sender/receiver Messages from and to Type 0x08 look plausbile.
My main working point are thermostat messages. Below a log picture, where I seperated telegram types which have 0xFF .
For those I applied the EMS+ ( EMS plus ?) rules as described in EMS wiki https://emswiki.thefischer.net/doku.php ... telegramme.
The EMS+ 2 Byte telegram types are unfortunately not documented yet. Since same telegram types are shown with different data length, I assume the principle EMS+ telegram interpretation is still wrong.
Added: I noticed that EMS+ telgrams with same type and different data length have different offset (19 and 0D in the example below).
10 00 FF 19 01 A5 01 04 FF EB 00 00 FF 64 4B 00 3C 01 FF 01 02 (CRC=EC, #data=17)
10 00 FF 0D 01 A5 01 20 (CRC=7A, #data=4)
Last edited by suncarver on Saturday 05 January 2019 12:48, edited 2 times in total.
- bbqkees
You have to upload image elsewhere in order it to show here.
You can also add a text log here if you use the 'code' tags.
Thermostat related logs below: - you can see types with 0xFF.
Example:
(00:00:45) Thermostat -> all, type 0xFF telegram: 10 00 FF 00 01 67 00 00 (CRC=AB, #data=4)
according https://emswiki.thefischer.net/doku.php ... telegramme for EMS+:
Sender : 0x10 // RC35 (my RC310) assumed
Receiver 0x00 // all
type : EMS+ Marker: 0xFF
Offset : 0x00
type High Byte: 01
type Low Byte: 67
daty bytes
CRC
data length
Example:
Offset : 0x00
type High Byte: 01
type Low Byte: 67
daty bytes
CRC
data length
(00:00:20) Thermostat -> me, type 0xA7 telegram: 10 0B A7 00 (CRC=FB)
(00:00:20) Thermostat -> me, type 0x06 telegram: 10 0B 06 00 12 0C 11 1E 0D 2E 06 00 10 FF 00 (CRC=B8, #data=11)
(00:00:32) Thermostat -> all, type 0xA2 telegram: 10 00 A2 00 00 00 00 00 00 (CRC=CA, #data=5)
(00:00:40) Thermostat -> all, type 0xFF telegram: 10 00 FF 0F 01 A5 02 2A (CRC=56, #data=4)
(00:00:40) Thermostat -> all, type 0xFF telegram: 10 00 FF 0D 01 A5 01 5A (CRC=00, #data=4)
(00:00:44) Thermostat -> all, type 0x06 telegram: 10 00 06 00 12 0C 11 1E 0E 0A 06 00 10 FF 00 (CRC=D9, #data=11)
(00:00:45) Thermostat -> Boiler, type 0x1A telegram: 10 08 1A 00 28 64 64 (CRC=C8, #data=3)
(00:00:46) Thermostat -> all, type 0xFF telegram: 10 00 FF 00 01 A5 00 DB 23 26 28 00 26 1E 01 5A 03 03 01 01 5A 02 2A 00 00 11 01 03 08 90 00 (CRC=8E, #data=27)
(00:00:46) Thermostat -> all, type 0xFF telegram: 10 00 FF 19 01 A5 06 04 FF E2 00 00 FF 64 4B 00 3C 01 FF 01 02 (CRC=50, #data=17)
(00:00:46) Thermostat -> all, type 0xFF telegram: 10 00 FF 00 02 1D 00 00 0A 07 (CRC=02, #data=6)
(00:00:56) Thermostat -> Boiler, type 0x23 telegram: 10 08 23 00 28 64 64 (CRC=73, #data=3)
(00:01:10) Thermostat -> me, type 0x41 telegram: 10 0B 41 00 (CRC=2E)
(00:01:10) Thermostat -> me, type 0xA7 telegram: 10 0B A7 00 (CRC=FB)
(00:01:29) Thermostat -> Boiler, type 0x35 telegram: 10 08 35 00 11 01 (CRC=20, #data=2)
(00:01:38) Thermostat -> all, type 0xFF telegram: 10 00 FF 0F 01 A5 02 2B (CRC=57, #data=4)
(00:01:39) Thermostat -> all, type 0xFF telegram: 10 00 FF 08 01 A5 01 59 03 03 01 01 59 (CRC=ED, #data=9)
(00:01:45) Thermostat -> all, type 0x06 telegram: 10 00 06 00 12 0C 11 1E 0F 0B 06 00 10 FF 00 (CRC=B9, #data=11)
(00:00:19) Thermostat -> me, type 0x41 telegram: 10 0B 41 00 (CRC=2E)
(00:00:56) Thermostat -> Boiler, type 0x23 telegram: 10 08 23 00 28 64 64 (CRC=73, #data=3)Re: Nefit / Buderus data/control via Arduino / ESP8266 to Domoticz (directly without OpenTherm module or Easy)
I am using the software from Proddy https://github.com/proddy/EMS-ESP on a ESP8266 in combination with the EMS interface board from Bbqkees.
My thermostat a Nefit Moduline 300 is nicely recognized as RC20 and I can set and read the room themperature.
So far it is working great, thanks Proddy and Bqqkees
Now I am trying to get my boiler(NEFIT TOPLINE COMPACT HRC 25/CW4) recognized, but it seems that it isn't in the Model_Types[] list
The autodetect command gives me the Product ID 115.
Any suggestions? What willl happen if I change the product ID from the EMS_MODEL_UBA to 115?
Output from the command autodetect:
// various boilers and buderus type devices
{EMS_MODEL_UBA, 123, 0x08, "MC10/UBA3 Boiler"},
{EMS_MODEL_BK15, 64, 0x08, "Sieger BK15 Boiler"},
{EMS_MODEL_BC10, 190, 0x09, "BC10 Base Controller"},
{EMS_MODEL_BC25, 125, 0x09, "BC25 Base Controller"},
{EMS_MODEL_RFM20, 68, 0x09, "RFM20 RC20F Receiver"},
{EMS_MODEL_MM10, 251, 0x21, "MM10 Mixer Module"}, // warning, fake product id!
{EMS_MODEL_WM10, 250, 0x11, "WM10 Switch Module"}, // warning, fake product id!Code: Select all
autodetect
Scanning EMS bus for devices. This may take a few seconds...
Requesting type Version(0x02) from dest 0x08
Requesting type Version(0x02) from dest 0x09
Requesting type Version(0x02) from dest 0x0B
Requesting type Version(0x02) from dest 0x10
Requesting type Version(0x02) from dest 0x11
Requesting type Version(0x02) from dest 0x17
Requesting type Version(0x02) from dest 0x18
Requesting type Version(0x02) from dest 0x21
(00:50:51) 0x08 -> all, type 0x34 telegram: 08 00 34 00 3C 01 6A 80 00 21 00 00 03 00 02 BB 3F 01 54 EB 00 (CRC=3D), #data=17
(00:50:51) 0x08 -> all, type 0x18 telegram: 08 00 18 00 55 02 2F 23 23 09 01 25 62 01 6A 80 00 01 9C 01 17 0E 2D 48 00 C8 00 02 00 (CRC=C8), #data=25
(00:50:52) Sending read of type 0x02 to 0x08: telegram: 0B 88 02 00 63 (CRC=FF), #data=1
(00:50:52) 0x08 -> me, type 0x02 telegram: 08 0B 02 00 73 03 05 (CRC=BD), #data=3
<--- Version(0x02) received
Unrecognized device found. Product ID 115, Version 03.05
(00:50:52) 0x08 -> all, type 0x07 telegram: 08 00 07 00 0B 80 00 00 00 00 00 00 00 00 00 00 00 (CRC=47), #data=13
(00:50:53) Sending read of type 0x02 to 0x09: telegram: 0B 89 02 00 63 (CRC=F7), #data=1
(00:50:53) 0x09 -> me, type 0x02 telegram: 09 0B 02 00 72 01 03 (CRC=FB), #data=3
Unrecognized device found. Product ID 114, Version 01.03Re: Nefit / Buderus data/control via Arduino / ESP8266 to Domoticz (directly without OpenTherm module or Easy)
We have a Moduline 300 thermostat with an 0x10 identifier, so it always using RC20 because of the identifier?
Or should it be RC30, because it is an Moduline 300?
I am asking because when setting the thermostat temperature via the "Service Key", the target temperature on the thermostat isn't updated(Checking by turn the large button on the thermostat).
Thanks and regards,
Rick
Thanks and regards,
Rick
- bbqkees
I recently got notified that the thermostat page on my Github is not completely correct.
The RC30 is the Moduline 400 and the Moduline 300 is the RC20. I still have to do some updates.
You should have a look at the Github repository from Proddy, although its for the ESP8266 he has built in full support for several EMS thermostats like your Moduline 300 (even with auto-detect etc).
following the link mentioned in ems plus wiki "Gedankenstütze/Externer Link", https://emswiki.thefischer.net/doku.php ... telegramme, I found a hint in https://www.mikrocontroller.net/topic/3 ... 25#3928825 from
Autor: Frank S. (blaueslicht) Datum: 17.12.2014 23:48: for a RC200, which is also an EMS+ telegram.
Thanks to Frank S. for bringing me a step ahead!
I searched for a similar "pattern" in my RC310 telegram log and found EMS+ telegram type 0x01A5 In the upper part are my telegrams, one is the 0x01A5 telegram, in the middle part an explanation of the 0x01A5 telgram interpretation and in the lower part the RC200 example from Frank S.
My interpretation is still in state "guesswork".
I do not understand why 0x01A5 telegrams have different data length, but whenever the yellow highlighted byte is 0x00, I get the data bytes which seem to match my temperature values.
So the meaning and use of the yellow highlighted Byte is unclear to me.
Since I do not want to change thermostat values for the moment, I'll monitor if my assumptions are correct:
proddy's MQTT Messages to a MOSQUITTO broker running on a Raspberry PI -> MQTT client forwards selected topic values to an rrd database -> rrd time series diagrams.
Any further help, confirmation or comment is welcome
Hi Bbqkees,
The auto-detect returns RC20 and it is working, but I was unsure if RC20 was right.
The Boiler isn't found with an auto-detect. I think because the productID is not yet added to the boiler_types array. I know my boiler is an UBA3 with ID 0x08 and ProductID 115. I am going to add it to the array and see what happens after an auto-detect.
I also saw messages from with the ID 0x09 with ProductID 114. Is it used for setting boiler parameters?
Regards,
RickM
Regards,
RickM
ivovangastel
- Domoticz version: 3.8153
has anybody converted the program of Proddy to fit Domoticz?
I have no fixed ethernet close to my boiler, so i like to use an ESP8266. but i am not an experienced programmer. i can understand the programming of Bbqkees, but not what Proddy wrote. or has somebody stripped Proddy's program to the bare essentials (just doing the communication conversion and placing the data in variables)?
Regards,
Ivo
Regards,
Ivo
- bbqkees
Although MQTT is universal, the message contents is specific for each home automation system.ivovangastel wrote: Tuesday 22 January 2019 8:17 Hi,
The code from Proddy is put together very well and it has a lot of functionality that is absent in my Arduino code.
I'm planning to writing some code for the Proddy version for MQTT support for Domoticz. But no time yet.
As far as I know Domoticz cannot handle more than one sensor update per MQTT message.
So you need to have a lot of messages added while the current code of Proddy only needs two.
For the rest its basically just modifying the JSON string that is sent and setting the right topics. That's all.
For Home Assistant there are those YAML configuration files so all sensors are automatically added but for Domoticz you need to create virtual sensors manually.
ivovangastel
hi Kees,
Getting MQTT working is something i can manage. i have 2 ESP8266 controlling my ventilation systems (fan speed and filter feedback) and i am finishing a SK8622 LED strip controller (Mega 2560 with WS5100) all communicating via MQTT+Json with Domoticz.
But these are very simple programs. just a few functions, no seperate header files.
I understand your arduino code (at least how you communicate with Domoticz), but as you mention that is writtten for an ATmega controller.
Because Proddy's code has so much functionality, it is harder for me to understand.
- bbqkees
I had some thought about it and perhaps the easiest (or the least difficult method) would be to install Node-Red and let Node-Red listen to the topics the ESP is publishing the values to and then extract the values from the messages and forward them in the Domoticz JSON format to Domoticz itself.
yes, node-red is the way to go to transform the JSON MQTT boiler & thermostat messages into domoticz/openhab/etc friendly sensor and switch topics. It's on my list to do!
geezerrr
i've made an Node-Red example which is working for me,it isn't finished..
maybe someone can use it or have a better structure? anyhow feel free to modify and let me know your input
just copy to your clipboard and import in Node-Red, make dummy's in Domoticz and fill the idx the flow.
[{"id":"6bbbb18.55cde5","type":"tab","label":"Nefit ESP-EMS-Domoticz","disabled":false,"info":""},{"id":"ae5e5ebe.d561d","type":"mqtt in","z":"6bbbb18.55cde5","name":"","topic":"home/ems-esp/boiler_data/#","qos":"2","broker":"84c04735.540278","x":125,"y":20,"wires":[["c4a72dec.c542a"]]},{"id":"171ba472.1669ec","type":"debug","z":"6bbbb18.55cde5","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":506,"y":20,"wires":[]},{"id":"c4a72dec.c542a","type":"json","z":"6bbbb18.55cde5","name":"","property":"payload","action":"","pretty":false,"x":86,"y":98,"wires":[["171ba472.1669ec","ea326f3a.c08f4","db3d11f2.295bf","fe94ceab.2b7ea","42a64e97.ce9c9","c693eec0.6d2e5","ede21c10.5f766","6db5c7a0.4f1a08","85e6b231.8d4fa","fd309bda.867c68","36ea249d.41781c"]]},{"id":"4b90b832.0610b8","type":"mqtt out","z":"6bbbb18.55cde5","name":"","topic":"domoticz/in","qos":"","retain":"","broker":"84c04735.540278","x":691,"y":142,"wires":[]},{"id":"ea326f3a.c08f4","type":"change","z":"6bbbb18.55cde5","name":"curFlowTemp","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.curFlowTemp","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":314,"y":142,"wires":[["ac5d6148.d11ac"]]},{"id":"db3d11f2.295bf","type":"change","z":"6bbbb18.55cde5","name":"sysPress","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.sysPress","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":304,"y":96,"wires":[["a2effd65.e6728"]]},{"id":"ac5d6148.d11ac","type":"template","z":"6bbbb18.55cde5","name":"=> idx 698","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{\n\"idx\" : 698,\n\"nvalue\" : 0,\n\"svalue\" : \"{{payload}}\" \n}","output":"json","x":518,"y":143,"wires":[["4b90b832.0610b8"]]},{"id":"fe94ceab.2b7ea","type":"change","z":"6bbbb18.55cde5","name":"curBurnPow","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.curBurnPow","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":316,"y":195,"wires":[["3ee74a86.656126"]]},{"id":"3ee74a86.656126","type":"template","z":"6bbbb18.55cde5","name":"=> idx 699","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{\n\"idx\" : 699,\n\"nvalue\" : 0,\n\"svalue\" : \"{{payload}}\" \n}","output":"str","x":519,"y":194,"wires":[["6ca6014.7dc9f"]]},{"id":"6ca6014.7dc9f","type":"mqtt out","z":"6bbbb18.55cde5","name":"","topic":"domoticz/in","qos":"","retain":"","broker":"84c04735.540278","x":696,"y":195,"wires":[]},{"id":"8b69363e.0dc028","type":"mqtt out","z":"6bbbb18.55cde5","name":"","topic":"domoticz/in","qos":"","retain":"","broker":"84c04735.540278","x":700,"y":251,"wires":[]},{"id":"42a64e97.ce9c9","type":"change","z":"6bbbb18.55cde5","name":"boilTemp","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.boilTemp","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":307,"y":249,"wires":[["dfd57f4e.7357e"]]},{"id":"dfd57f4e.7357e","type":"template","z":"6bbbb18.55cde5","name":"=> idx 700","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{\n\"idx\" : 700,\n\"nvalue\" : 0,\n\"svalue\" : \"{{payload}}\" \n}","output":"str","x":521,"y":249,"wires":[["8b69363e.0dc028"]]},{"id":"c693eec0.6d2e5","type":"change","z":"6bbbb18.55cde5","name":"retTemp","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.retTemp","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":305,"y":302,"wires":[["94e4f746.fc1228"]]},{"id":"94e4f746.fc1228","type":"template","z":"6bbbb18.55cde5","name":"=> idx 701","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{\n\"idx\" : 701,\n\"nvalue\" : 0,\n\"svalue\" : \"{{payload}}\" \n}","output":"str","x":524,"y":301,"wires":[["d69bd943.24a368"]]},{"id":"d69bd943.24a368","type":"mqtt out","z":"6bbbb18.55cde5","name":"","topic":"domoticz/in","qos":"","retain":"","broker":"84c04735.540278","x":703,"y":300,"wires":[]},{"id":"f8cbaab7.cf8ee8","type":"template","z":"6bbbb18.55cde5","name":"=> idx 702","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{\n\"idx\" : 702,\n\"nvalue\" : 0,\n\"svalue\" : \"{{payload}}\" \n}","output":"str","x":524,"y":351,"wires":[["55b4f2d9.0cc7ec"]]},{"id":"ede21c10.5f766","type":"change","z":"6bbbb18.55cde5","name":"pumpMod","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.pumpMod","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":307,"y":351,"wires":[["f8cbaab7.cf8ee8"]]},{"id":"55b4f2d9.0cc7ec","type":"mqtt out","z":"6bbbb18.55cde5","name":"","topic":"domoticz/in","qos":"","retain":"","broker":"84c04735.540278","x":704,"y":351,"wires":[]},{"id":"adaeedaf.eb763","type":"mqtt out","z":"6bbbb18.55cde5","name":"","topic":"domoticz/in","qos":"","retain":"","broker":"84c04735.540278","x":703,"y":403,"wires":[]},{"id":"ec379ef.e0fdb6","type":"template","z":"6bbbb18.55cde5","name":"=> idx 703","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{\n\"command\": \"switchlight\",\n\"idx\": 703, \n\"switchcmd\": \"{{payload}}\" \n}","output":"str","x":526,"y":403,"wires":[["adaeedaf.eb763"]]},{"id":"6db5c7a0.4f1a08","type":"change","z":"6bbbb18.55cde5","name":"heatPmp","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.heatPmp","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":311,"y":404,"wires":[["ec379ef.e0fdb6"]]},{"id":"a2effd65.e6728","type":"template","z":"6bbbb18.55cde5","name":"=> idx 704","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{\n\"idx\" : 704,\n\"nvalue\" : 0,\n\"svalue\" : \"{{payload}}\" \n}","output":"str","x":516,"y":98,"wires":[["982e3907.a8f6f8"]]},{"id":"982e3907.a8f6f8","type":"mqtt out","z":"6bbbb18.55cde5","name":"","topic":"domoticz/in","qos":"","retain":"","broker":"84c04735.540278","x":687,"y":98,"wires":[]},{"id":"f61a7c03.da212","type":"mqtt out","z":"6bbbb18.55cde5","name":"","topic":"domoticz/in","qos":"","retain":"","broker":"84c04735.540278","x":704,"y":461,"wires":[]},{"id":"8f890fd.c2668f","type":"template","z":"6bbbb18.55cde5","name":"=> idx 705","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{\n\"idx\" : 705,\n\"nvalue\" : 0,\n\"svalue\" : \"{{payload}}\" \n}","output":"str","x":524,"y":460,"wires":[["f61a7c03.da212"]]},{"id":"85e6b231.8d4fa","type":"change","z":"6bbbb18.55cde5","name":"outdoorTemp","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.outdoorTemp","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":321,"y":459,"wires":[["8f890fd.c2668f"]]},{"id":"fd309bda.867c68","type":"switch","z":"6bbbb18.55cde5","name":"spare","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"","vt":"msg"}],"checkall":"true","repair":false,"outputs":1,"x":296,"y":517,"wires":[[]]},{"id":"36ea249d.41781c","type":"switch","z":"6bbbb18.55cde5","name":"spare","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"","vt":"msg"}],"checkall":"true","repair":false,"outputs":1,"x":298,"y":574,"wires":[[]]},{"id":"c725101a.38706","type":"template","z":"6bbbb18.55cde5","name":"=> idx 706","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{\n\"idx\" : 706,\n\"nvalue\" : 0,\n\"svalue\" : \"{{payload}}\" \n}","output":"str","x":526,"y":515,"wires":[["ec10d79.e84a828"]]},{"id":"d83390eb.66fa8","type":"template","z":"6bbbb18.55cde5","name":"=> idx 707","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{\n\"idx\" : 706,\n\"nvalue\" : 0,\n\"svalue\" : \"{{payload}}\" \n}","output":"str","x":528,"y":578,"wires":[["b28add15.985c8"]]},{"id":"ec10d79.e84a828","type":"mqtt out","z":"6bbbb18.55cde5","name":"","topic":"domoticz/in","qos":"","retain":"","broker":"84c04735.540278","x":703,"y":515,"wires":[]},{"id":"b28add15.985c8","type":"mqtt out","z":"6bbbb18.55cde5","name":"","topic":"domoticz/in","qos":"","retain":"","broker":"84c04735.540278","x":706,"y":579,"wires":[]},{"id":"84c04735.540278","type":"mqtt-broker","z":"","name":"MQTT domoticz","broker":"192.168.1.11","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""}]-
Gert
For those interested (this is a Domoticz forum, isn't it...): I have just released an early version of a Python plugin for the EMS-ESP.
It can currently be found as a pull request on Proddy's Github.
- bbqkees
Looks great.Gert wrote: Wednesday 20 February 2019 15:13 For those interested (this is a Domoticz forum, isn't it...): I have just released an early version of a Python plugin for the EMS-ESP.
Hilgert
I have implemented this and it works like a charm!
Does anybody have an STL file for a case where both the bbqkees EMS board and the ESP can live?
