All,
I bought a Digoo DG-R8S 433MHz sensor to use with Domoticz. I am using a RFXcom as transmitter. But it does not stem to work. Domoticz devices does not show the sensor and on forums I read mixed signals If the sensor works or works not. Can somebody help me out? I have the following questions:
* Does the Digoo DG-R8S 433MHz work with the RFXcom and Domoticz?
* If so what mode should be switched on in the RFXcom menu?
* How do I install the Digoo DG-R8S 433MHz in Domoticz? (I assume via devices menu, but double checking)
Thanks for the help!
RFXcom / Digoo DG-R8S / Domoticz
b_weijenberg
- Target OS: -
Re: RFXcom / Digoo DG-R8S / Domoticz
Digoo DG-R8H is listed as supported in chapter 2.2.2 of the RFXtrx User Guide, DG-R8S is not listed.
Unknown if there is a (big) difference in the protocols. Check with RFXmngr with Rubicson enabled if the sensor is received.
RFX-433, RFX-433EMC, RFX-868
Turio
Thanks for the Quick reply!
Unfortunately with Rubicson enabled I do not see the dg_r8s in the devices.
I Will check the differente between r8h and the r8s.
Anyone else a suggestion?
