District Heating / City Heating (Stadsverwarming) Mysensor IR sender/Receiver
freijn
- Domoticz version: Stable
Re: District Heating / City Heating (Stadsverwarming) Mysensor IR sender/Receiver
Remko, what type of meter are you using?
remko2000
I use a multical 601
jonathan12
Nice project. I will also try to get the data out of my heating box.
What kind of dummy sensor do we have to create?
This just means that the multical box didn't answer at all ie. there is no active communication.remko2000 wrote: Friday 09 November 2018 10:13 ah you are right. My mistake. When I use:
sudo python /home/pi/domoticz/scripts/pyKamstrup_single.py /dev/ttyUSB1 60 21
I get:Traceback (most recent call last):
File "/home/pi/domoticz/scripts/pyKamstrup_single.py", line 243, in <module>
value = int(value * 1000)
TypeError: unsupported operand type(s) for *: 'NoneType' and 'int'
I currently have the same problem with my multical 602 box. No matter what I do, it stays silent.
Pressing the "play" button doesn't seem to work either. Still it looks like to me that the connector
plug "passes" all the recommended tests.
remko2000
Almost a year later I tried it once. I've fresh install of my raspberry so I thought let's try.
I f I type:
Now I get no error but a value: 156290 (!!)
If I remove the sensor I get a error so it's receive something!
It really doesn't matter which last two digits I type in the command the value is always: 156290
Is this a good thing and what does this digit mean? What can I do next?
I f I type:
sudo python /home/pi/domoticz/scripts/pyKamstrup_single.py /dev/ttyUSB1 60 23If I remove the sensor I get a error so it's receive something!
remko2000
I also see that the value is rising; it's now: 156320.
freijn
Hey Remko
please dump your complete script here and a dump of your output.
Can you find these lines in your output?
Remove the # from every line and check if you see more output when running the command from the cli.
I do not have this kampstup type, so can't test it locally...
#print ("=======================================================================================")
#print ("Kamstrup M402 serial optical data ontvangen op: %s" % heat_timestamp)
#print ("Meter fabrikant/type: Kamstrup M402")
#print ("---------------------------------------------------------------------------------------")
#for i in kamstrup_402_var:
# x,u = foo.readvar(i)
# print("%-25s" % kamstrup_402_var[i], x, u)
#print ("Einde Dataontvangst: %s" % heat_timestamp)
#print ("=======================================================================================")I do not have this kampstup type, so can't test it locally...
remko2000
My complete script is:
If I type
in my (mac)terminal I get only back: 156320
If I type
in my terminal I get only back: 0
That's all the output I get in my terminal. Is there an other way to get more info in my terminal to see what commands do and how?
!/usr/bin/python
# "THE BEER-WARE LICENSE" (Revision 42):
# <[email protected]> wrote this file. As long as you retain this notice you
# can do whatever you want with this stuff. If we meet some day, and you think
# this stuff is worth it, you can buy me a beer in return. Poul-Henning Kamp
# Modified for Domotics and single request.
# Usage: __file__ <ComPort> <KMP_Command_Decimal> <Domoticz_IDX>
from __future__ import print_function
# You need pySerial
import serial
import math
import sys
import json
import urllib2
kamstrup_601_var = {
0x003C: "Verwarming verbruik",
0x0054: "Warm waterverbruik",
# Units, provided by Erik Jensen
units = {
0: '', 1: 'Wh', 2: 'kWh', 3: 'MWh', 4: 'GWh', 5: 'j', 6: 'kj', 7: 'Mj',
8: 'Gj', 9: 'Cal', 10: 'kCal', 11: 'Mcal', 12: 'Gcal', 13: 'varh',
14: 'kvarh', 15: 'Mvarh', 16: 'Gvarh', 17: 'VAh', 18: 'kVAh',
19: 'MVAh', 20: 'GVAh', 21: 'kW', 22: 'kW', 23: 'MW', 24: 'GW',
25: 'kvar', 26: 'kvar', 27: 'Mvar', 28: 'Gvar', 29: 'VA', 30: 'kVA',
31: 'MVA', 32: 'GVA', 33: 'V', 34: 'A', 35: 'kV',36: 'kA', 37: 'C',
38: 'K', 39: 'l', 40: 'm3', 41: 'l/h', 42: 'm3/h', 43: 'm3xC',
44: 'ton', 45: 'ton/h', 46: 'h', 47: 'hh:mm:ss', 48: 'yy:mm:dd',
49: 'yyyy:mm:dd', 50: 'mm:dd', 51: '', 52: 'bar', 53: 'RTC',
54: 'ASCII', 55: 'm3 x 10', 56: 'ton x 10', 57: 'GJ x 10',
58: 'minutes', 59: 'Bitfield', 60: 's', 61: 'ms', 62: 'days',
63: 'RTC-Q', 64: 'Datetime'
# Byte values which must be escaped before transmission
escapes = {
0x06: True,
0x0d: True,
0x1b: True,
0x40: True,
0x80: True,
# And here we go....
class kamstrup(object):
def __init__(self, serial_port):
self.debug_fd = open("/tmp/_kamstrup", "a")
self.debug_fd.write("\n\nStart\n")
self.debug_id = None
self.ser = serial.Serial(
port = serial_port,
baudrate = 1200,
timeout = 2.0)
def debug(self, dir, b):
for i in b:
if dir != self.debug_id:
if self.debug_id != None:
self.debug_fd.write("\n")
self.debug_fd.write(dir + "\t")
self.debug_id = dir
self.debug_fd.write(" %02x " % i)
self.debug_fd.flush()
def debug_msg(self, msg):
self.debug_id = "Msg"
self.debug_fd.write("Msg\t" + msg)
def wr(self, b):
b = bytearray(b)
self.debug("Wr", b);
self.ser.write(b)
def rd(self):
a = self.ser.read(1)
if len(a) == 0:
self.debug_msg("Rx Timeout")
return None
b = bytearray(a)[0]
self.debug("Rd", bytearray((b,)));
return b
def send(self, pfx, msg):
b = bytearray(msg)
b.append(0)
b.append(0)
c = crc_1021(b)
b[-2] = c >> 8
b[-1] = c & 0xff
c = bytearray()
c.append(pfx)
for i in b:
if i in escapes:
c.append(0x1b)
c.append(i ^ 0xff)
else:
c.append(i)
c.append(0x0d)
self.wr(c)
def recv(self):
b = bytearray()
while True:
d = self.rd()
if d == None:
return None
if d == 0x40:
b = bytearray()
b.append(d)
if d == 0x0d:
break
c = bytearray()
i = 1;
while i < len(b) - 1:
if b[i] == 0x1b:
v = b[i + 1] ^ 0xff
if v not in escapes:
self.debug_msg(
"Missing Escape %02x" % v)
c.append(v)
i += 2
else:
c.append(b[i])
i += 1
if crc_1021(c):
self.debug_msg("CRC error")
return c[:-2]
def readvar(self, nbr):
# I wouldn't be surprised if you can ask for more than
# one variable at the time, given that the length is
# encoded in the response. Havn't tried.
self.send(0x80, (0x3f, 0x10, 0x01, nbr >> 8, nbr & 0xff))
b = self.recv()
if b == None:
return (None, None)
if b[0] != 0x3f or b[1] != 0x10:
return (None, None)
if b[2] != nbr >> 8 or b[3] != nbr & 0xff:
return (None, None)
if b[4] in units:
u = units[b[4]]
else:
u = None
# Decode the mantissa
x = 0
for i in range(0,b[5]):
x <<= 8
x |= b[i + 7]
# Decode the exponent
i = b[6] & 0x3f
if b[6] & 0x40:
i = -i
i = math.pow(10,i)
if b[6] & 0x80:
i = -i
x *= i
if False:
# Debug print
s = ""
for i in b[:4]:
s += " %02x" % i
s += " |"
for i in b[4:7]:
s += " %02x" % i
s += " |"
for i in b[7:]:
s += " %02x" % i
print(s, "=", x, units[b[4]])
return (x, u)
if __name__ == "__main__":
import time
comport = sys.argv[1]
command = int( sys.argv[2], 0)
index = int( sys.argv[3], 0)
foo = kamstrup( comport )
value,unit = foo.readvar( command )
# We're sending an integer value to Domoticz, so with two digits, muliply by 100
# Use Domiticz setting to devide by 100 again.
print( int(value) )
sudo python /home/pi/domoticz/scripts/pyKamstrup_single.py /dev/ttyUSB1 60 24If I type
sudo python /home/pi/domoticz/scripts/pyKamstrup_single.py /dev/ttyUSB1 84 25That's all the output I get in my terminal. Is there an other way to get more info in my terminal to see what commands do and how?
remko2000
I'm a little further now. I get values back on the follow registers:
68- 1064400
60-156420
72-1039950
86-58770
87-36120
88-180000
89-22650
97-79048000
98-101000
Which fails me to sent for example value 60 to domoticz. I switch the print rule in my pyKamstrup_single.pyscript for
I only change in this part only the IP tot the IP of my domoticzserver. Nothing else. I also made one rule in crontab:
The IDX (23) and sensor-USB-adress are correct. In domoticz I made a dummyswitch(IDX23) of the type: gas. Is this correct?
68- 1064400
60-156420
72-1039950
86-58770
87-36120
88-180000
89-22650
97-79048000
98-101000
requestPost = urllib2.Request( "http://127.0.0.1:8080/json.htm?type=command¶m=udevice&idx=" + str(index) + "&svalue=" + str(value) )
resultPost = json.load(urllib2.urlopen(requestPost))Code: Select all
1 1 * * * /home/pi/domoticz/scripts/pyKamstrup_single.py /dev/ttyUSB1 60 23- Attachments
- IMG_6592.jpg (366 KiB) Viewed 8449 times
freijn
First of all, did you allow a local login without a user_id and password?
Below the url's from my system to post the values into domoticz.
you must map the registers into the device idx to make this work.
requestPost=urllib.request.urlopen("http://192.168.1.155:8080/json.htm?type ... olume*100))
requestPost=urllib.request.urlopen("http://192.168.1.155:8080/json.htm?type ... ergy*1000))
remko2000
After some reading I guessing this has something to do with a bash script. Is this correct? So I made a simple bashscript:you must map the registers into the device idx to make this work.
#!/bin/bash
# Simple script to batchrun the commands for the Kamstrup 601 Meter.
# Normal Command Usage: python3 kamstrup_single.py [USB device] [Decimal Command] [IDX]
# Heat Energy (verbruik) [60] [148]
python3 /home/pi/domoticz/scripts/pyKamstrup_single.py /dev/ttyUSB0 60 28
I've a crontabtask: 1 1 * * * /home/pi/domoticz/scripts/pyKamstrup_single.py /dev/ttyUSB0 60 28
And I've a bash script called: kamstrup.sh (made it executable)
If I type: ' sh kamstrup.sh' in my terminal I get the follow error:
What can be the problem?Traceback (most recent call last):
File "/home/pi/domoticz/scripts/pyKamstrup_single.py", line 20, in <module>
import serial
ModuleNotFoundError: No module named 'serial'
I've installed pyserial 3.4-4.
My domoticzlog says it's use Python version 3.7.3.
Strange thing is if I type ' python --version' in my terminal it says I've version Python 2.7.16.
remko2000
Finally I get it work. Some mistakes in copy this into my script
Another problem was two versions of python (2 and 3) which uses different urllib(2)libraries.
I also have to set persistant USB-devices because the USB-adresses were changing when I restarted my RB.
But now I can conform that this script is working with a Multical 601 and IR-eye.
resultPost = json.load(urllib2.urlopen(requestPost))I also have to set persistant USB-devices because the USB-adresses were changing when I restarted my RB.
I've got the same heater. I managed to get it working with mysensors en domiticz.
Just got one question regarding the way domoticz can handle the value. MS does not have a 'GJ' value as far as i can see, but i would like it. Is there a trick i can use to at least let domoticz display it as GJ?
freijn
Hi Elm
As far as I know this is not possible
ah thats to bad..
For now im just happy it works. But yeah, i would like to display eventually my power meter and water meters also. But if domoticz cant handle GJ's, i will try perhaps some other tool..
Hi folks,
I know this is an old topic, but I've read through this topic with great interest and can't wait to get started integrating my heating and hot water meter into my smart home. Regarding the software, I think I have plenty to go on from this topic, but I'm getting stuck a little before even getting there, because I can't really figure out what IR cable/transceiver to buy.
Can anyone point me in the right direction for either a USB-cable to plug into a Raspberry Pi, or a cable I can solder onto an ESP32 (or any microcontroller)? Either concrete product links or just better keywords to Google for would be greatly appreciated ("IR transceiver cable" gives me a gazillion IR relays which doesn't seem helpful).
Thanks a lot in advance
Wow.. long time ago indeed
I got it working now with and ESP running ESPHOME in Home Assistant. I could not get my other systems working in here.
I bought mine via:
https://wiki.volkszaehler.org/hardware/ ... b-lesekopf
But that was in 2014 already, so not sure if they are still selling. Good luck!
I bought mine via:
Thanks a lot! Unfortunately they don't seem to sell anymore, I've ordered this one, hope that works
https://de.elv.com/elv-bausatz-lesekopf ... iec-155523
(I will try to remember to report back here to share if it works, just in case the next lost soul comes here wondering what to buy)
Looks good. Hope it works!
So, for anyone coming here, trying to figure out what IR transceiver to buy, the one I linked before works great, *BUT* requires some assembly. I quickly skimmed over the page before purchasing and totally missed that it said "Bausatz", which means as much as "kit".
It seemed a little intimidating at first, but was actually very easy and straightforward (there's a German booklet included, which is easily translated by pointing the camera at it in the Google Translate app).
You need to solder two things (5 pads for the USB cable, 4 wires plus shielding, and the IR emitter), and optionally you can add the debug LEDs for transmitting and receiving (I did), which also requires drilling two 3mm holes in the case in premarked locations.
The kit as it came out of the box:
The IR-emitter just before soldering in:
The cable soldered on and the debug LEDs attached:
It does come with a magnet which attaches easily to the Kampstrup Multical 601 (make sure to check the polarity of the ring magnet, I had to open the thing up again because I got it facing the wrong way).
If you have done any soldering before, you're absolutely not going to have any problems with this.
