hi
I have some battery devices conected to domoticz, they report info about battery and radio level.
Is it possible to get info about those lvl to set alarm or using them in scripts in other way?
ty in advance
Battery level info
- waaren
Re: Battery level info
yes, but i cant understand how i read this battery lvl
i try
but w/o success, so im really dont have idea how i can read batterylevel device's test_ds
i try
local test = domoticz.devices('test_ds').batteryLevel
Hello
You can install battery level plugin and the manipulate the level via dzvents
PI 2 - Domoticz 2021.1
RFXCOM - RFXtrx433 USB 433.92MHz Transceiver (5 DIO 54755 + 2 DIO 54756 + 3 DIO 54798)
Z-Wave.Me ZME_UZB1 USB Stick (6 FGSD002 + 2 FGRM222 + 1 FGS223 + 1 FGMS001-ZW5 + 1 FGRGBWM441 + 1 FGBS001 + 2 FGFS101)
6 sondes DS18B20
6 sondes DS18B20
6 sondes DS18B20
6 sondes DS18B20
this plugin works only for z-wave, and i have EasyESP and mysensor nodes
- Domoticz version: V2022.1
I am running this script for getting the battery status and set it to a dummy
Using it for a Xiaomi device, which has the battery inside its open/close status.
Now i can use it for other scripts on each value it has.
you need to fill in IP-address and IDX number of the dummy
I am running json for a local set a local dummy. I should be changing it to a local command and not json.
But it works and at the moment i am working on other things that i still didn't changed it.
updateBatterylevel
devices = { 'Garage poort'} ,
timer = { 'at 10:00' },
httpResponses = { 'setBatterylevel' }
execute = function(domoticz, trigger)
local debug = true
function debug_print(myLine)
if debug then print("***** updateBatterylevel ****** " .. myLine) end
if trigger.isHTTPResponse then
if (trigger.ok) then -- statusCode == 2xx
local setting = trigger.json.status
local batteryDevice = domoticz.devices("Garage poort")
local newBatterylevel = batteryDevice.batteryLevel
local myUrl = "http://xxx.xxx.xxx.xxx:xxxx/json.htm?type=command¶m=switchlight&idx=XXX&switchcmd=Set%20Level&"
myUrl = myUrl .. "level=" ..newBatterylevel
domoticz.openURL({
url = myUrl,
callback = "setBatterylevel"
Thin-client --> Docker Domoticz main environment
Pi3A+ --> Google home (GAssistPi)
Pi3B+ --> Docker (P1monitor, Domoticz test environment, Ubiquity controller)
tyvm!
it works quite nice
it works quite nice
