I want to:
1. I have 2 Sensors in my water tank placed at different levels in the Water tank ( At 100% and Water Pump Intake Pipe for checking if water is getting pumped into the tank to avoid a dry run) and a Switch for Water Motor.
2. I have connected above sensors to my Raspberry Pi to GPIO pins so they trigger the following named switches in Domoticz - 'Tank_Full" and "Dry_Run"
3. I want the water Motor to start daily from 6 AM to 7 AM and 6 PM to 7 PM only when it's the time for the Public Water Supply timings (ie. from 6-7 AM and 6-7 PM) and if Tank is not in a Full condition (i.e. Tank_Full is giving input that Tank is not full) AND to avoid a dry run - Motor should run at above times for atleast 5 minutes and after that script should check if Dry_Run condition is there, if YES then stop the motor and re-run the above schedule after say 3 minutes within the water time slot of 6-7 AM / 6-7 PM
I have tried Blocky and DzVents but had limited success. I even posted in below Domoticz forum but still stuck.
Looking at Forum members to help me out
viewtopic.php?f=59&t=26227&p=201371#p201371
