Zigate and Xiaomi temp/hum/baro sensors adjustment of temp
mcmikev
Post by mcmikev »
I am trying to adjust the values of my sensors in domoticz with -0.2 C on the TH sensors but that does not work.
Is this all related to this?
https://github.com/domoticz/domoticz/is ... -441357383
Or had this a different reason perhaps?
pipiche
Re: Zigate and Xiaomi temp/hum/baro sensors adjustment of temp
Post by pipiche »
This is a problem related to Domoticz and the Python Plugin Framework. Indeed same problem as https://github.com/domoticz/domoticz/is ... -441357383 and unfortunately the Domoticz owner has closed the issue !
Attached is a short plugin to duplicate the problem.
plugin.py.gz
(1.07 KiB) Downloaded 82 times
Wiki is available here.
Zigbee for Domoticz FAQ
mcmikev
Post by mcmikev »
What a shame. I thought that i was giving the wrong values but it just cannot be done this way
pipiche
Post by pipiche »
@mcmikev I fully share your view. I'm very sad. I'm not expert enought in CC+ to fix that problem in Domoticz and it looks like nobody wanted to make it.
Here is the work I started , but was not success to finish: https://github.com/domoticz/domoticz/pull/2899
mcmikev
Post by mcmikev »
Damn. Really miss this option
Xiaomi sensors are a bit “high” on temp Reading so adjusting with -0.5 or -1.0C would be great.
I turn off/on my heating with these readings.
Now it feels a bit cold because of the 1 degree difference.
pipiche
Post by pipiche »
I'll see if I can do something at the plugin level to compensate it.
pipiche
Post by pipiche »
If you switch to pre-4.1 branche . The adjustement of Temperature Sensor works. You need to have a beta version of Domoticz > 4.10355
In case you are on stable branche, please read with attention the file 00-UPGRADE-FROM-STABLE-4.0
mcmikev
Post by mcmikev »
Great news !! Thank you.
Just did a git pull on the pre-4.1 branche and updated the xiaomi sensors (hum/temp/baro) with -0.3 and -0.5 degrees.
Hope to see the next update that the temp is "down"
pipiche
Post by pipiche »
Did you check that you have Domoticz Beta > 4.10335 ?
mcmikev
Post by mcmikev »
i run v4.10419 so that is fine (build from source)
mcmikev
Post by mcmikev »
domoticz framework change???
pipiche
Post by pipiche »
Yes, and no. I make a workaround in the plugin, but I needed to get access to new parameter now available via the Framework ;-)
So it should work ;-)
pipiche
Post by pipiche »
In any case, let me know the results
mcmikev
Post by mcmikev »
It seems to work however there is a new strange thing now.
All of a sudden the temp reading goes haywire and is very long.
Not constant the same sensor it comes and goes.
Did a new pull just half an hour ago.
pipiche
Post by pipiche »
Just fixed it. So better that you redo the git pull, restart.
Could you let me know what was your adjustement value ? I beleive -/+ xx.yy
mcmikev
Post by mcmikev »
I adjusted -0.3 and -0.5
pipiche
Post by pipiche »
So indeed , now I'm rounding the result of the adjustement
mcmikev
Post by mcmikev »
Looks good so far. Thx
pipiche
Post by pipiche »
BTW, I have also enable adjustement on Baro
mcmikev
Post by mcmikev »
I have tried the temp adjustment on the THB devices that are created and updated the most due to barometric changes, but the THB devices are not using the offset.
The TH devices are, but the THB not. Temp, Humi,Baro can this be applied as well please???
