Python Plugin : Xiaomi Philips LED Ball Lamp Topic is solved
- Domoticz version: 4.9701
Re: Python Plugin : Xiaomi Philips LED Ball Lamp
If you make a call from the console "bash -c ./MyBulb.py <IpOfBulb> <TokenOfBulb>", will it be successful? You must be in catalog of the plugin and use corresponding IP and token of your lamp.
If you make a call from the console "python ./MyBulb.py <IpOfBulb> <TokenOfBulb>", will it be successful too?
Successful call will print something like that:
<PhilipsBulbStatus power=off, brightness=50, color_temperature=1, scene=3, delay_off_countdown=0>
I have tried. Same problem, "MyBulb.py: error: the following arguments are required: IPaddress, token"
What does it say 'python --version' ?
Python version 3.5.3
I have no linux at this moment but this should work (you must use your own IP and token and be in /home/pi/domoticz/plugins/domoticz-Xiaomi-Led-Lamp):
python MyBulb.py 192.168.10.102 89bedfa9123841a44030fd4ae2a0db09
When I call 'MyBulb.py 192.168.10.102 89bedfa9123841a44030fd4ae2a0db09' under Windows (without python) I get the same error 2. So I suppose that in your environment something is not configured right and command 'bash -c ./MyBulb.py 192.168.10.102 89bedfa9123841a44030fd4ae2a0db09' is failed because bash can not find the python. But I could be wrong. I do not have much experience with Linux.
I tried from Python, but I have received same error.
. Thank you, that you try to help me.
Have you done this?
sudo chmod 777 /home/pi/domoticz/plugins/domoticz-Xiaomi-Led-Lamp/MyBulb.py
Nothing change, same error.
I have found this error now:
File "MyBulb.py", line 11, in <module>
import miio.philips_bulb
ImportError: No module named miio.philips_bulb
Where is the module named miio.philips_bulb? I have not found.
Dear Samael,
You have to install a python-miio lib.
sudo pip3 install python-miio
It is installed as site package into the Python.
People, I see that there are some problems with running under Linux. I will conduct some experiments and make the necessary edits. Please be patient.
You can update plugin now.
And don't forget to change the file permissions.
sudo chmod +x MyBulb.py
sudo chmod +x plugin.py
Dear Samael,
Thanks, thanks... it is working. Nice work!
So this plugin is also for these lights?
€ 10,12 62%OFF | [HOT]riginal xiaomi mijia smart downlight work with mi home app smart remote control white & warm light phone change light
https://s.click.aliexpress.com/e/BOhOXFL
Does someone knows if you can "group" them?
Yes, I think it should work.
To organize the group of lights you better read the manual (http://www.domoticz.com/DomoticzManual.pdf) and https://www.domoticz.com/forum/viewtopic.php?t=14903.
Hi, when I try to update I get this error:
Your local changes to the following files would be overwritten by merge:
MyBulb.py
Please commit your changes or stash them before you merge.
Aborting
Need help.
MyBulb.py
Aborting
Need help.
This means that you have made some changes to the file. Do the next commands inside 'domoticz-Xiaomi-Led-Lamp':salvacalatayud wrote: ↑Friday 01 March 2019 16:52 Please commit your changes or stash them before you merge.
git reset
git checkout .
Worked, thanksSamael wrote:This means that you have made some changes to the file. Do the next commands inside 'domoticz-Xiaomi-Led-Lamp':salvacalatayud wrote: ↑Friday 01 March 2019 16:52 Please commit your changes or stash them before you merge.Code: Select all
git reset
ps: https://stackoverflow.com/questions/140 ... ed-changesCode: Select all
git checkout .
Enviado desde mi Mi A2 mediante Tapatalk
Users browsing this forum: boum and 1 guest
