I have domoticz installed on my Synology DS916+.
I am using DSM 6.0.2-8451 Update 9
and Domoticz V3.6694 installed from the jadahl package server.
I have connected the P1 smart meter and the RFXCom on ttyUSB0 and ttyUSB1
I want to add an other device the HGI80 to control my EvoHome system.
I am not getting a new serial port for this device.
Do I need a new driver on my synology and if so how do I install this driver.
USB Driver for Honeywell HGI80
- EdddieN
- Domoticz version: 4.9700
Re: USB Driver for Honeywell HGI80
Not sure if the attached will help. I use it for the Pi to include it on the firmware libraries
- ti_3410.fw.zip
- extract the fw file
- (8.28 KiB) Downloaded 199 times
11101101 - www.machinon.com
mschut
- Domoticz version: V3.5613
Out of curiosity, I assume you have:EdddieN wrote:Hi
- Domoticz
Raspberry Pi
Evohome
HGI80
- EdddieN
Yes that is what i have, the Evohome wifi version.
So far so good, there are a few error logs from time to time, like not able to retrieve parameters or corrupted data but in general I don't notice it and works well.
I also had it running in the past with a synology box. The key thing is making sure the drivers are working.
GJvdP
- Domoticz version: 2022.1
hello there,
I have the same setup: RPI3, domoticz, Evohome and the HGI80
I don't seem to get the hgi80 working. If I want to add the hgi80 as a usb device I do not get a new usb port.
rfxcom is at usb01.
I see that you have a driver, but I have not a clue on how to install it. Or is the HGI80 just a DOA. (see no light or anything coming on after I plug it in)
do you have any advice for me?
Thanks, GJ
rfxcom is at usb01.
Thanks, GJ
GJvdP
It is working. Wiki on Evohome helped me a lot. Even after that it wasn't working. Started to work after I entered the controller id.
