Domoticz events have delay
pfloryann
Domoticz version: 2025.2
Post by pfloryann »
I use Zigate and motion sensors for switch on the lights with domoticz blockly...but i have 2-3 seconds delay between the moment when i get in the room and lights on. I have same problem with LUA script...when i press the wireless button he turn on the lights after ~2 seconds.
Before to use Raspberry pi with Zigate i had Xioami Hub and I did not have delay.
I use now Domoticz 4.1 and zigate plugin beta version and Raspberry Pi 1 B...it can be from Raspberry Pi because is old model with 700mhz Cpu and 512 ram ?
How can I fix the delay because 2 seconds or more some time is a pretty much?
Domoticz on Raspberry Pi 4 Debian 13 x64
Zigbee2mqtt and zigbee devices (Xiaomi, Ikea,Tuya, Philips, Osram), Broadlink, Solar power Victron Energy, Yeelight, Xiaomi Purifier Pro, Roborock S5
Thorgal789
Re: Domoticz events have delay
Post by Thorgal789 »
You can try too with domoticz + Xioami hub (if you have the good one), it will help you to find the weak link.
If you enable log, you can see when the button is pressed and when the command go to the bulb, check the timestamp.
