NUT Mini BATTERY SERVICE
All kinds of 'OS' scripts
Artursd
Re: NUT Mini BATTERY SERVICE
Post by Artursd »
Artursd
Post by Artursd »
Artursd
Post by Artursd »
Found a mistake. Now Nut is at home, but the variable does not change to Home
https://yadi.sk/i/iyyMFzR0Flu3Dw
https://yadi.sk/i/tzPvOQXUby5FQA
https://yadi.sk/i/nLZqNIHPnZpOdw
Artursd
Post by Artursd »
emme
Domoticz version: latest
Post by emme »
how did you fix it?
just curious
"We always done this way"
Artursd
Post by Artursd »
Artursd
Post by Artursd »
there was a space in the name, but the space does not understand
Artursd
Post by Artursd »
And now I don’t understand what the problem is, it’s like seeing my NUT, but it doesn’t change the meaning.
emme
Post by emme »
do not use spaces or special chars at all
use the CamelCase to name your variables ;)
call them
nutEgita and
nutAlarm
then deploy the flow and should start (same name in domoticz Variable/switch names)
Artursd
Post by Artursd »
and how to stop the execution of Flow ??
emme
Post by emme »
flow won't stop unless you disable it
simply change and deplay
Artursd
Post by Artursd »
what am I doing wrong? does not find my NUT
emme
Post by emme »
is your nut already configured (paired) with its app?
Artursd
Post by Artursd »
Which application? How configured?
Artursd
Post by Artursd »
Artursd
Post by Artursd »
if I manually correct the variable on HOME, it is corrected automatically on AWAY
emme
Post by emme »
welll... it looks like it does not discover the address
try place a debug node right out the scan BLE anch find the telegram with the correct mac address...
it has to be written EXACTELY in the same way
AA:BB:CC:DD:EE is different than Aa:Bb:Cc:Dd:Ee
Artursd
Post by Artursd »
https://yadi.sk/i/KpbJM4GcnieG8g
I correctly entered the data ???? Malenkte and capital letters differ ???
Artursd
Post by Artursd »
emme
Post by emme »
the last screen is the device that has been turned on by the toggler
I need to see the device telegram... the one who has the macaddress as UUID
