Somfy telis 4 RTS
Re: Somfy telis 4 RTS
here are my 2 remotes https://ibb.co/jVPMp38
Tried again and again.
Tried switching off longTX
Did exactly as you said (all in rflink)
10;RTSLONGTX;
20;09;RTSLONGTX=OFF;
10;RTSCLEAN;
20;0A;RTS CLEANED;
10;REBOOT; /PREPARATIONS, to check no fault here
20;00;Nodo RadioFrequencyLink - RFLink Gateway V1.1 - R48;
10;version;
20;01;VER=1.1;REV=48;BUILD=04;
10;status;
20;02;STATUS;setRF433=ON;setNodoNRF=OFF;setMilight=OFF;setLivingColors=OFF;setAnsluta=OFF;setGPIO=OFF;setBLE=OFF;setMysensors=OFF;
10;RTS;02FFFF;0412;3;PAIR; //setRF433 ON oK`??
20;03;OK;
20;04;Debug;RTS P1;a465021bf2d7ce; //restartet blinds/Power, and pressed up and down on remote, blinds moved a bit
20;05;RTS;ID=f2d7ce;SWITCH=01;CMD=STOP;
20;06;Debug;RTS P1;a465021bf2d7ce;
20;07;RTS;ID=f2d7ce;SWITCH=01;CMD=STOP;
20;08;Debug;RTS P1;a465021bf2d7ce;
20;09;RTS;ID=f2d7ce;SWITCH=01;CMD=STOP;
20;0A;Debug;RTS P1;a465021bf2d7ce;
20;0B;RTS;ID=f2d7ce;SWITCH=01;CMD=STOP;
20;0C;Debug;RTS P1;a465021bf2d7ce;
20;0D;RTS;ID=f2d7ce;SWITCH=01;CMD=STOP;
20;0E;Debug;RTS P1;a465021bf2d7ce;
20;0F;RTS;ID=f2d7ce;SWITCH=01;CMD=STOP;
10;RTS;02FFFF;0412;3;PAIR; //within 3sec
20;10;OK; //??
10;RTS;0100F2;0;DOWN; // NOTHING HAPPENS!? WHY NOT?
20;11;OK;
20;12;OK;
20;13;OK;
20;14;OK;
20;15;OK;
20;16;OK;
20;17;OK;
20;18;OK;
20;19;OK;
20;1A;OK;
20;1B;OK;
20;1C;OK;
20;1D;Debug;RTS P1;a541021cf2d7ce; /manual press on REMOTE
20;1E;RTS;ID=f2d7ce;SWITCH=01;CMD=DOWN;
20;1F;Debug;RTS P1;a541021cf2d7ce;
20;20;RTS;ID=f2d7ce;SWITCH=01;CMD=DOWN;
20;21;Debug;RTS P1;a541021cf2d7ce;
20;22;RTS;ID=f2d7ce;SWITCH=01;CMD=DOWN;
20;23;Debug;RTS P1;a541021cf2d7ce;
20;24;RTS;ID=f2d7ce;SWITCH=01;CMD=DOWN;
20;25;Debug;RTS P1;a541021cf2d7ce;
20;26;RTS;ID=f2d7ce;SWITCH=01;CMD=DOWN;
20;27;Debug;RTS P1;a541021cf2d7ce;
20;28;RTS;ID=f2d7ce;SWITCH=01;CMD=DOWN;
20;29;Debug;RTS P1;a541021cf2d7ce;
20;2A;RTS;ID=f2d7ce;SWITCH=01;CMD=DOWN;
ok, after hours and hours of trying. now it seems to work.
I paired a remote as described. then I need to use the RTSSHOW and take the address and number from there and add them to the up and down. THOSE numbers that are safed on your arduino work, not those that you add via PAIR command. Strangely only the even numbers worked.
I have 4 blinds. they are stored under positon 0,2,4,6 ... don´t know what the others are good for.
I have not completely understood how I did add them without "overwriting the old ones", however it worked.
only problem I have now is, that when I press up they go down and vice versa (worked better before some resets...). And I am afraid of re-learning my physical remotes because I might loose the connection.
However a big step forward.
secator
- Domoticz version: 4.9701
if your physical remote is inverted:
1 put the blind in middle position
2 press up and down buttons together 5 sec . the blind will go up and down
3 press immediatly the stop button ( my) and wait that the blind go up and down once again.
for information i've 10 shutter roller. for one of them if i press the red button 3 sec the roller shutter don't go up/down but i can pair it anyway.
I have a similar problem, not able to pair the blinds.
Used the instructions step by step found at https://matdomotique.wordpress.com/2016 ... -et-somfy/.
Btw I am using an rflink at the correct somphy frequency.
Here is what I do:
1 I put the screen into programming mode using the button on the back of the telis
2 The screen responds by jogging up and down
3 I send the command 10;RTS;0F0F0F;0412;3;PAIR;
4 RFlink responds OK
5 The screen DOES NOT jog
6 I send RTSSHOW
7 The RFLINK sends the RTS list including the 0F0F0F device at slot 3
8 screen does not respond to any up and down command like 10;RTS;0F0F0F;0;DOWN;
9 after a while the screen exits its pairing mode (jogs up and down)
10 still the screen does not respond to any up/down command
At step 5 the screen should have jogged to confirm pairing. So I think things are wrong somewhere in step 1-5.
Rechsoz reports only even slots should be used, has this been confirmed? (so use 10;RTS;0F0F0F;0412;2;PAIR; during pairing)
Here is what I do:
6 I send RTSSHOW
Got it working, turns out that I was using the wrong RFLINK device (I have two at different frequencies).
One last issue though, hope someone can help me:
I have paired two somphy blinds and added them to domoticz. I am able to control both blinds, so far so good.
But for one blind, the domoticz controls are reversed but the physical Telis remote for both blinds are OK.
Any suggestions how to fix this?
Bizzarrini
Same problem here, anyone find a solution yet?
- JHO01
- Domoticz version: Stable
Had the same problem
Solution: when you manually add the new switch to Domoticz make sure you select unit 1. See screenshot When you choose unit 2, I got the reverse operation...
RPI-3, Z-stick Gen5, RFlink, Zigbee2mqtt, 1-wire DS18B20, Fibaro switches, various RF-433 sockets, BMP018, Somfy, Wemos, Tradfri.
