SOLVED: Youless doesn't show gas meter
Wiley
Post by Wiley »
Version: 4.9700
Build Hash: a3a45906
Compile Date: 2018-06-23 16:24:51
dzVents Version: 2.4.6
Python Version: None
Platform: Pi (oldie) / Noobs Raspbian lite
Plugin/Hardware: Youless
Description:
I've installed Domoticz succesfully and got Solar Edge and Youless working. However, the Youless hardware only shows 1 device, for electricity.
It doesn't show the gas meter. Unfortunately that's exactly the one I'm looking for ;-)
Anyone any idea why it's not finding the device? Youless firmware is recent, PVOutput version.
Edit: maybe solved: do you really have to add the Youless hardware twice? I just noticed that you can edit the device and I can select gas there.
So I add hardware twice, then for the second device I choose the gas meter?
Hmm. I thought 1 Youless hardware would show 2 devices (just as the Solar Edge did).
Edit2: nope, when I select Gas it just shows the electric values as m3...
Edit3: It's the Youless PVOutput firmware. It doesn't export gas values since PVoutput doesn't work with it (out of the box). I flashed back to default Enelogic firmware and now the gas meter shows up!
Fiddling with SolarEdge/Youless->Domoticz->PVOutput now, impossible to get decent consumption numbers without a seperate kWh meter.
