NUT Mini BATTERY SERVICE
All kinds of 'OS' scripts
emme
Domoticz version: latest
Re: NUT Mini BATTERY SERVICE
Post by emme »
ned to check the scanble status....
in nodered console you should get a greed or red dot under the scan node...
if you gets UNAUTHORIZED you need to issue a command in ssh
(I'm looking for it....)
"We always done this way"
Artursd
Post by Artursd »
emme
Post by emme »
looks like noble scan is not installed.....
try to reinstall everything
Artursd
Post by Artursd »
Artursd
Post by Artursd »
Artursd
Post by Artursd »
emme
Post by emme »
...what kind of distro you have?!
you're supposed to get jessie or stretch... aren't you?
try with
sudo npm install bluetooth-hci-socket
basically... if it tells you you miss something, try to
sudo npm install <what-is-missing>
and then retry to install noble.
Artursd
Post by Artursd »
https://yadi.sk/i/tUuN7oX-lKVtZg
put v8 and it worked, but another error came out. Maybe you need to put a friend version? or incorrectly set?
https://yadi.sk/i/8B8AX5sTexD-dg
Artursd
Post by Artursd »
Artursd
Post by Artursd »
Artursd
Post by Artursd »
I don't know much about NodeRed yet. I know how to import a stream, but how to save the stream in NR ???
emme
Post by emme »
as soon as you deploy a flow that is saved and active.
Actually your problem with BLE looks like an issue with the wireless card hardware
try with the adafruit guide....
https://learn.adafruit.com/install-blue ... stallation
Artursd
Post by Artursd »
Artursd
Post by Artursd »
Artursd
Post by Artursd »
Artursd
Post by Artursd »
emme
Post by emme »
try with
sudo setcap cap_net_raw+eip $(eval readlink -f `which node`)
Artursd
Post by Artursd »
Artursd
Post by Artursd »
Unable to start BLE scan. Ada pter state: unknown
Artursd
Post by Artursd »
