I'm trying on a specific time set the setpoints of multiple devices at once to a certain value. I notice only the first device is changed after executing the script, the other ones are unchanged. The setpoints are on Popp thermostats.
timer = {
'at 20:55'
execute = function(domoticz)
domoticz.devices('Radiator Setpoint N1').updateSetPoint(12)
domoticz.devices('Radiator Setpoint N2').updateSetPoint(12)
domoticz.devices('Radiator Setpoint N3').updateSetPoint(12)
domoticz.devices('Radiator Setpoint W1').updateSetPoint(12)
domoticz.devices('Radiator Setpoint Z1').updateSetPoint(12)
I also tried using a wild-card, but it doesn't recognize the device this way: domoticz.devices('Radiator Setpoint*').updateSetPoint(12).
As I understand it I cannot use group or scene, because scene is for lights (right?) - at least I do not see the Popp devices when creating group or scene in the add devices dropdown.
Anyone can give me a hint?
Rs3b
dzVents script - Execute setting multiple devices [Solved]
- waaren
Re: dzVents script - Execute setting multiple devices [Solved]
Can you try this and look at the log ?Rs3b wrote: Saturday 19 January 2019 21:44 I'm trying on a specific time set the setpoints of multiple devices at once to a certain value. I notice only the first device is changed after executing the script, the other ones are unchanged. The setpoints are on Popp thermostats.
timer = { 'at 23:25' },
logging = {
level = domoticz.LOG_DEBUG,
marker = setSetPoints
execute = function(dz)
local function logWrite(str,level)
dz.log(tostring(str),level or dz.LOG_DEBUG)
local N1 = dz.devices('Radiator Setpoint N1')
local N2 = dz.devices('Radiator Setpoint N2')
local N3 = dz.devices('Radiator Setpoint N3')
local W1 = dz.devices('Radiator Setpoint W1')
local Z1 = dz.devices('Radiator Setpoint Z1')
local setPoints= { N1,N2,N3,W1,Z1}
for i = 1,#setPoints do
setPoints[i].updateSetPoint(12)
local rawData = ""
for j = 1,#setPoints[i].rawData do
rawData = rawData .. setPoints[i].rawData[j] .. "; "
logWrite(setPoints[i].name .. "; type: " .. setPoints[i].deviceType .. "; subtype: " .. setPoints[i].deviceSubType .. "; nvalue: " .. setPoints[i].nValue .. "; rawData: " .. rawData)
Rs3b
Hello waaren,
Many thanks for your example code, it works perfectly!
The log:
It also pointed my to an error in my code, first time I ran the script it got:
Turns out I named the setpoint "Radiator SetPoint N2"...I put in a capital P only in this setpoint name. It was the second one in my script, so I tested my original script, and this also ran fine after changing the P into p. Lua is case-sensitive... silly me!!! Still in the learning lua phase...
I may be overasking, but if I want to use domoticz.devices().forEach(..) using an arry, how would the syntax be in that case?
Thanks,
rs3b
The log:
2019-01-20 11:17:00.209 Status: dzVents: Info: ------ Start external script: test.lua:, trigger: at 11:17
2019-01-20 11:17:00.229 Status: dzVents: Debug: Processing device-adapter for Radiator Setpoint N1: Thermostat setpoint device adapter
2019-01-20 11:17:00.230 Status: dzVents: Debug: Processing device-adapter for Radiator Setpoint N2: Thermostat setpoint device adapter
2019-01-20 11:17:00.231 Status: dzVents: Debug: Processing device-adapter for Radiator Setpoint N3: Thermostat setpoint device adapter
2019-01-20 11:17:00.231 Status: dzVents: Debug: Processing device-adapter for Radiator Setpoint W1: Thermostat setpoint device adapter
2019-01-20 11:17:00.232 Status: dzVents: Debug: Processing device-adapter for Radiator Setpoint Z1: Thermostat setpoint device adapter
2019-01-20 11:17:00.232 Status: dzVents: Debug: Constructed timed-command: 12
2019-01-20 11:17:00.232 Status: dzVents: Debug: Radiator Setpoint N1; type: Thermostat; subtype: SetPoint; nvalue: 0; rawData: 20.00;
2019-01-20 11:17:00.233 Status: dzVents: Debug: Radiator Setpoint N2; type: Thermostat; subtype: SetPoint; nvalue: 0; rawData: 20.00;
2019-01-20 11:17:00.233 Status: dzVents: Debug: Constructed timed-command: 12
2019-01-20 11:17:00.233 Status: dzVents: Debug: Radiator Setpoint N3; type: Thermostat; subtype: SetPoint; nvalue: 0; rawData: 20.00;
2019-01-20 11:17:00.233 Status: dzVents: Debug: Radiator Setpoint W1; type: Thermostat; subtype: SetPoint; nvalue: 0; rawData: 20.00;
2019-01-20 11:17:00.233 Status: dzVents: Debug: Radiator Setpoint Z1; type: Thermostat; subtype: SetPoint; nvalue: 0; rawData: 20.00;
2019-01-20 11:17:00.233 Status: dzVents: Info: ------ Finished test.lua
2019-01-20 11:04:00.601 Status: dzVents: Debug: Processing device-adapter for Radiator Setpoint N1: Thermostat setpoint device adapter
2019-01-20 11:04:00.601 Status: dzVents: Error (2.4.6): There is no device with that name or id: Radiator Setpoint N2
Thanks,
rs3b
- waaren
I am not sure what you want/ The example code I posted does iterate over the array of devices.Rs3b wrote: Sunday 20 January 2019 11:41 If I want to use domoticz.devices().forEach(..) using an arry, how would the syntax be in that case?
Thanks,
rs3b
If your intention is to set the setPoints of all relevant devices in your domoticz environment you could this.
timer = { "every 1 minutes" }
logging = {
level = domoticz.LOG_ERROR,
marker = "filter "
execute = function(dz, item)
spaces = " " ; for i=1,25 do spaces = spaces .. " " end
dz.devices().filter(function(dv) -- Chain filter and forEach
return (dv.deviceType == "Thermostat" and dv.deviceSubType == "SetPoint" )
end).forEach(function(dv)
logWrite((dv.name .. spaces ):sub(1,25) .. dv.setPoint,dz.LOG_FORCE)
-- dv.updateSetPoint(12) -- Setting all setPoints in your system to 12
end)
}Debian buster, bullseye on RPI-4, Intel NUC.
