Like many I have installed Domotics on a raspberry pi/raspbian and just followed the default installation procedure. With succes: everything is working. Now that I have a working environment I am worried about using Domoticz from "outside": it would be great to see if the kids are home, if all windows are indeed closed, that the lights are on / off etc. but I do not want others access to this data: very handy for burglars for instance.
I also plan to set up a alarm system.
This means that the installation needs to be tough enough to be connected to the open internet (with ssl/portforwarding etc.)
I have a few worries here:
1) Domoticz is by default running as user "pi" (or the user who installed the system) this user has way too much rights I think: is usually a member of the sudo group etc. Why not install Domoticz as a user domoticz with a group domoticz?
2) A computer directly connected to the Internet should be hardened more than a system on a private LAN. I am thinking about firewalling, Intrusion dection and that sort of thing.
3) I mistrust the raspberry's performance and especially the SD card which is (IMHO) a recipe for failure in the long run. I am considering bying a cheap micro pc (like this one: https://bit.ly/2swecFy) to run the system on.
4) If I would be truly paranoid I would install the OS on multiple partitions and make some read only (the grand majority) and a writable partition(s) for e.g. /var/log/* /home/*, the Domoticz database etc.
5) Why is installing Domotics in /home/pi (or for that matter /home/$user) recommended? I have installed domotics in /opt to keep things separated and to make sure I do not do something stupid when cleaning out my home dir...
6) directory/file rights/ownership: everyting in /opt/domoticz (my location) has owner/group pi:pi with rights 755 This is way too much I think. Almost everyting can be 444 or 644 I guess...
etc. etc. As you can see I have many questions/ideas and I am looking forward to your reactions!
Suggestions for a more secure Domoticz installation
- PetervandePol
ben53252642
Re: Suggestions for a more secure Domoticz installation
Setup an OpenVPN server, install the OpenVPN app on your phone and use that to access Domoticz on your home network.
- PetervandePol
Excellent suggestion. I saw you suggested https://en.wikipedia.org/wiki/Btrfs when installing on a (mini) pc Why not use this on the raspberry's as well?ben53252642 wrote: Thursday 17 January 2019 11:54 Setup an OpenVPN server, install the OpenVPN app on your phone and use that to access Domoticz on your home network.
ben53252642
You can and I personally do use BTRFS in all my Raspberry Pi projects.
It requires work to get a Pi running on BTRFS though as the Raspbian developers for some reason have refused to implement BTRFS support despite many people requesting it. Search for a guide, there are many available.
My experience is that my BTRFS Pi's are much more resilient against file corruption. That said these days I think buying a NUC and using a SSD is by far the better way to go.
ben53252642
Actually if I recall Berryboot supports easily setting up the BTRFS file system.
If you are absolutely going to use a Pi and want BTRFS, do the setup using Berryboot.
https://www.berryterminal.com/doku.php/berryboot
- PetervandePol
Thank you, Ben. I am actually going to move to a mini PC with 4GB and a SSD, see my initial post. Should make things easier, faster and more reliable. I read the SuSe is using BTRFS on their server; might be interesting to have a look at that; I used a lot of SuSE versions in the '90iesben53252642 wrote: Thursday 17 January 2019 13:35 Actually if I recall Berryboot supports easily setting up the BTRFS file system.
ben53252642
Good idea. Almost every major distro except Raspbian obviously supports BTRFS I'd suggest picking an os that's either Debian or Debian based, eg Ubuntu.PetervandePol wrote: Thursday 17 January 2019 13:43 I am actually going to move to a mini PC with 4GB and a SSD
I am sure you could get Domoticz up and running on Suse but just be aware I don't know of anyone else running Domoticz on that OS.
