Plugwise Adam
mveldman
- Domoticz version: 4.9700
Plugwise Adam
On my heater i use this device https://www.plugwise.com/en_US/products/adam
Is there anyone who uses this gateway and has succesfully connected it to Domoticz?
I've tried using the Plugwise Anna connector whithout succes.
It would be nice, so i can use the geofence with Domoticz.
akatar
Re: Plugwise Adam
I have the same question, thinking of buying one but i don't know (yet) if i can add it to a ha system.
@mveldman: can you get an xml file out of the adam?
we can do this with the smile and the stretch 2, perhaps also with adam? please check if you want.
akatar
Re: Plugwise Adam
we'll i bought an adam and you can get an xml file out of the adam
<point_log id="60e4d9ac603f425a80e85b75f1c8249e">
<updated_date>2018-12-31T11:46:28.933+01:00</updated_date>
<type>central_heater_water_pressure</type>
<unit>bar</unit>
<last_consecutive_log_date>2018-12-31T11:46:28.932+01:00</last_consecutive_log_date>
<period end_date="2018-12-31T11:46:28.933+01:00" start_date="2018-12-31T11:46:28.933+01:00">
<measurement log_date="2018-12-31T11:46:28.933+01:00">1.60</measurement>
</period>
</point_log>
<point_log id="62183c24621c45f7ae427a7daf386f40">
<updated_date>2018-12-29T19:19:29.313+01:00</updated_date>
<type>maximum_boiler_temperature</type>
<unit>C</unit>
<last_consecutive_log_date>2018-12-29T19:19:29.313+01:00</last_consecutive_log_date>
<period end_date="2018-12-29T19:19:29.313+01:00" start_date="2018-12-29T19:19:29.313+01:00">
<measurement log_date="2018-12-29T19:19:29.313+01:00">73.00</measurement>
</period>
</point_log>
<point_log id="68cdf74391e246de880ecaa2177aa5c3">
<updated_date>2018-12-31T11:47:50.924+01:00</updated_date>
<type>domestic_hot_water_temperature</type>
<unit>C</unit>
<last_consecutive_log_date>2018-12-31T11:47:50.924+01:00</last_consecutive_log_date>
<period end_date="2018-12-31T11:47:50.924+01:00" start_date="2018-12-31T11:47:50.924+01:00">
<measurement log_date="2018-12-31T11:47:50.924+01:00">59.40</measurement>
</period>
</point_log>
etc etc
<unit>bar</unit>
</period>
</point_log>
<unit>C</unit>
</period>
</point_log>
<unit>C</unit>
</period>
</point_log>
etc etc
mveldman
Re: Plugwise Adam
That is something for a start!akatar wrote: Tuesday 01 January 2019 22:38 we'll i bought an adam and you can get an xml file out of the adam
<unit>bar</unit>
</period>
</point_log>
<unit>C</unit>
</period>
</point_log>
<unit>C</unit>
</period>
</point_log>
etc etc
Dr8072
- Domoticz version: 4.10xxx
Re: Plugwise Adam
From what I can see the XML is the same as the Plugwise Anna given it needs to talk to the standard plugwise application.
Can anyone post a full XMl file from http://ip adam/core/appliances?
Might add be able to use it in the Anna Plugin after a few modifications to the code.
Dr8072
Re: Plugwise Adam
If my assumption is correct the software in the gateway/Adam is the same and will support the same API
So I've changed to code of the Anna thermostat, so it has the potential to work with the Adam too.
If someone is willing to try they can see if the Anna thermostat in the upcoming beta will work with the Adam
The code is being pushed to the beta and should hopefully be there later in the week
If my assumsion is correct it should have the same functionality a the ANNA
Pleas let me know if it works
ahattink
- Domoticz version: Stable
Re: Plugwise Adam
@Dr8072
Yes i would like to try and think i am able to.
My installation has an Anna with firmware 3.1.4 and Adam with firmware 2.3.19.
I will set up my test pi to connect to Adam and Anna and let you know about my findings.
Pi 3B, latest stable
RFXCOM, Z-wave, Zigate, Hue, Harmony hub, Netatmo Weather station, Opentherm Gateway, EnOcean,P1 SmartMeter, Plugwise Anna & Adam, Xiaomi Roborock, Sonos One, Google Home, Philips Hue, Homey, D-link and Bitron Video camera.
Dr8072
Re: Plugwise Adam
Keep an eye out for a new beta... The code change is still not merged...
Dr8072
Re: Plugwise Adam
The new beta is up... give it a try. if its not working can you
get me a proper appliances. xml?
run curl http://<username>:<password>@<ipadress anna>/core/appliances i > appliances.xml and up load it here.
ahattink
Re: Plugwise Adam
I updated Domoticz to the latest version.
Then i added the Anna and Adam to Domoticz.
I was under the impression i could see and add the Toms and Lisa's to Domoticz. But they where not in the device list.
1 new device was shown: intended_boiler_temperature
Attached XML files.
1 of the Adam
1 of Anna without decentral heating devices
1 Anna with decentral heating devices.
If you need more info, testing done ore anything, please let me know.
Attached XML files.
1 of the Adam
- Anna.xml
- (30.25 KiB) Downloaded 227 times
- Anna with decentral heat input.xml
- (33.4 KiB) Downloaded 194 times
- Adam.xml
- (63.64 KiB) Downloaded 257 times
Dr8072
Re: Plugwise Adam
Thanks for the Adam list, that will help.
Did on the Adam test show the same devices as the Anna? If it is not to much asked a screen shot of the devices... (here or as a private msg) so I can see what added and to make it 100% correct for the 3 same scenarios run a:
curl -L "http://<username>:<password>@<ipadress anna>//cache/domain_objects;class=Location" >locations.xml
I didn't realize you can add these separate thermostats and knobs ... I hoped you could at least make use of some of the same functionality however no I have some data 'll see what the Adam is reporting and what I can do with it.
Keep in mind... I cannot physical test the Adam part as I do not have physical access to one
ahattink
Re: Plugwise Adam
Attached screenshots of the devices from Adam and Anna.
Attached XML's from Adam.
- locations Adam.xml
- (12.67 KiB) Downloaded 217 times
- Anna.PNG (24.76 KiB) Viewed 12540 times
- Adam.PNG (19.62 KiB) Viewed 12540 times
ahattink
Re: Plugwise Adam
And the Anna xml:
- locations Anna.xml
- (5.99 KiB) Downloaded 204 times
Dr8072
Re: Plugwise Adam
Thanks... I do see the various devices, This will require a little more then I first hoped, I need to restructure the way the appliances are handled...
but I have enough for a few tests
Dr8072
Re: Plugwise Adam
@ahattink Currently I will get the following info for Tom's & Lisa from the Adam, Is that what you would expect?
Ignore the batteries
ahattink
Re: Plugwise Adam
@Dr8072 Yes that is exactly what i expected!
How can i try?
How can i try?
Dr8072
Re: Plugwise Adam
@hattink Just Checking, if this was right... I'll need to merge it with the Anna code so you also have info on your CV system.
I hope to push out a first version of that code by the end of the week.
If it will allow you to update depends if you can you provide me with the url used and form data of an update to a Tom and one for the Lisa? so i can actually make sure the set points work
For this you go (I Assume) to the html page of the Adam
http://<username:password>@<ip adress adam:port adam>
Thn start developer moed in Chrome of firefox
(firefox -> Open Menu -> Web Developer -> Toggle Tools>)
(Chrome ->Open Menu -> More Tools-> Developer tools)
In both the browser usually will split in a top pane ( with the webpage on top) Click on the network tab of the developer pane
Update the setpoint of a Tom. you should see a line appear of the type PUT.
Click on that line and you should get information of that url in a pane on the right
I need the full request URL :
(usually something like <http://ip:port/core/locations;id=70556647adb2a4b82818be0e28d172eb4/thermostat;id=66779bda77b3d45f29ea080811f0f83bd
(From firefox ) the XML info from the param tab
(From Chrome) the XML info from the Form data segment at the bottom of the first pane
(Usually something like this <thermostat_functionality><setpoint>21.5</setpoint></thermostat_functionality> )
ahattink
Re: Plugwise Adam
Hi Dr8072,
I did as you requested and hope this is the correct information.
I updated the Room Slaapkamer. (can not update individual devices in the Plugwise Web interface.)
This updates the setpoint from Tom Slaap and Lisa Slaap.
In Firefox is see the request URL:
http://192.168.2.57/core/locations;id=4 ... 260b9ca7a4
This forum garbles it a bit, so without the http:
192.168.2.57/core/locations;id=4da6f8d44ac042bd922f1effb352b87c/thermostat;id=ad029a06f1824c91886ee6260b9ca7a4
In parameters:
<thermostat_functionality><setpoint>5.5</setpoint></thermostat_functionality>
As you can see i set the room to 5.5 °C
In parameters:
