Gateway Aqara Xiaomi V3
stephantasy
Post by stephantasy »
Hi!
I’m new in the home automation world and I’d like to build a heater control system in my home.
I recently bought the Gateway Xiaomi Aqara (V3?) that works with the app Aqara Home (but not with Mi Home).
It works well, but I want to add the gateway in Domoticz (in Windows 7). And of course, it doesn’t work (all the tutorials I found are for the V2).
Has anyone been able to add the last version of Aqara gateway in Domoticz?
Thank you!
johhnny
Re: Gateway Aqara Xiaomi V3
Post by johhnny »
Any luck with that?
Wysłane z mojego SM-G960F przy użyciu Tapatalka
ozon1969
Post by ozon1969 »
Did you get the key? If so, did you try adding it to hassio like this:
xiaomi_aqara:
discovery_retry: 10
gateways:
- mac: XXXXXXXXXX (miss out the ":" )
host: XXX.XXX.XX.XX
key: XXXXXXXXXXXXXXXX
johhnny
Post by johhnny »
I think nobody did because it is not possible to get those infos like with the xiaomi gateway. There is no "about" in app to press
ozon1969
Post by ozon1969 »
The aqara gateway v3 should work in the Mi Home app to my understanding
Use the latest Mi Home app, choosing China Mainland as the server, and update the gateway to the latest version available
johhnny
Post by johhnny »
I didn't say it doesn't work. I said I'm not able to enable local functions like here https://www.domoticz.com/wiki/Xiaomi_Gateway_(Aqara)
ozon1969
Post by ozon1969 »
You need an oolder version of Mi Homethe app in order to do that. Try google or seach function here
ozon1969
Post by ozon1969 »
Migh Still Be notsuccessful if So You have to wait for the new version update expected In The Following months
I have a similar issue with my Aqara gateway camera...
johhnny
Post by johhnny »
ozon1969 wrote:Migh Still Be notsuccessful if So You have to wait for the new version update expected In The Following months
New SW is out and nothing has changed. I can't find any option in mi home to get keys needed for domoticz. Mi home app itself is total misunderstanding.
PetervandePol
Post by PetervandePol »
Should work with the Mi app. I think I have the same "mushroom" here and working. I did have trouble registering the gateway with the app. The solution was (very weird) to change the DNS in my KPN (Netherlands, Telco) router from the default KPN dns to another one, I took 8.8.8.8 (google)
After that I registered, location "mainland China", Language "English" and all's working. I am adding sensors now....
johhnny
Post by johhnny »
PetervandePol wrote:Should work with the Mi app. I think I have the same "mushroom" here and working. I did have trouble registering the gateway with the app. The solution was (very weird) to change the DNS in my KPN (Netherlands, Telco) router from the default KPN dns to another one, I took 8.8.8.8 (google)
How did you add it to domoticz?
PetervandePol
Exactly as described here: https://www.domoticz.com/wiki/Xiaomi_Ga ... o_Domoticz I used my Android phone, no idea if the same procedure works on other platforms like iPhone...
johhnny
Post by johhnny »
PetervandePol wrote:Exactly as described here: https://www.domoticz.com/wiki/Xiaomi_Ga ... o_Domoticz I used my Android phone, no idea if the same procedure works on other platforms like iPhone...
Are you sure you have aqara hub? Please pay attention to the aqara logo in the center of the device. Image
PetervandePol
aaaah. No. I have the "Mi" logo.... excuses.
zxcvyuioooo
Post by zxcvyuioooo »
Were you able to connect your aqara gateway to Domoticz?
arjanm
Post by arjanm »
Does anybody has a v3 gateway working in Domoticz?
I still can't find the password for my gateway.
Ynco
Post by Ynco »
I have the same- there is no About, i also cannot find password to my gateway.
Please help somebody
Users browsing this forum: Varazir and 1 guest
