MultiSensor Gen5 issues
CardboardNinja
Post by CardboardNinja »
I have a Aeon Labs MultiSensor Gen5 and it was a pain to include in my network but it's connected now and I'm struggling to figure out why it seems to be working fine in the Open Z-Wave control panel but not in domoticz itself.
I don't seem to be able to attach screen shots so I'll try and describe what I'm seeing.
So in the OZW control panel for current values on my sensor:
60 BR Routing Slave Routing Binary Sensor Aeotec DSB05 Multisensor
I can see that the current config values are:
Sensor: Off
Temperature: 22.0C
Luminance: 41 lux
Relative Humidity: 39%
Solar Radiation: 0.0
Battery Level: 100%
Yet in Domoticz I have 3 devices showing the following.
127 Gen5_Stick 060 (0x3C) 3C01 0 TempHum Temp + Humidity WTGR800 -17.8 C, 41 % - 100
126 Gen5_Stick 060 (0x3C) 0003C03 255 Lux 2nd Landing Lux Lux 41 Lux - 100
125 Gen5_Stick 060 (0x3C) 00003C00 1 Sensor 2nd Landing Light/Switch Switch Off - 100
It seems like the sensor works fine. Lux seems to be correct but then the TempHum is showing me -17.8c and 41% which to me looks like it's actually the lux value rather than the humidity.
Anyone got any ideas on this before I try excluding and re-including again?
Plantje
Re: MultiSensor Gen5 issues
Post by Plantje »
Currently have some challenges with a sensor like this.
For two of them I switched from USB powered to battery powered. As I understood they work like battery powered anyway...
How did you connect it? I think you should be close to the main controller and push the include button twice or just have some luck.
I have currently removed one and added it again in order to, hopefully solve some of my issues.
After doing that I almost immediately saw the new device in the "Devices" of Domoticz. The temperature of -17.8c is something I have seen a lot as well.
