Round function - Help needed
areg
Post by areg »
I need to use the round function to round the PM2.5 value to an integer.
I used code:
rreturn {
		devices = {'airly'},
	execute = domoticz.round('PM2,5 Norma',0)
However, it does not work.
Device name: Airly
Value: Pm2.5 Norma
Please, tell me what I'm doing wrong.
jvdz
Domoticz version: 4.107
Re: Round function - Help needed
Post by jvdz »
I would assume the round function needs a value and you are feeding it with a sting which also contains regular characters.
Jos
areg wrote: Sunday 13 January 2019 10:09 I need to use the round function to round the PM2.5 value to an integer.
Please begin with reading the introduction and getting started of the wiki
After that try this
      devices = {
         'airly'}
      if (item.state == 'On') then
         domoticz.log('Hey! I am on!')
         domoticz.log('rounding now 2.23435 to 2 decimals .... : ' .. domoticz.utils.round(2.23435,2))
         domoticz.log('Hey! I am off! ; No rounding today')
areg
Post by areg »
Thank you I will try!
areg
Post by areg »
Holy crap, doesn't work :)
Can anyone help?
areg wrote: Sunday 13 January 2019 18:36 Holy crap, doesn't work :)
Can anyone help?
Can you show what's in the log ? And try this one.
   on = { devices = { 'airly'}},
         domoticz.log('rounding now 2.23435 to 2 decimals .... : ' .. domoticz.utils.round(2.23435,2),domoticz.LOG_FORCE)
         domoticz.log('Hey! I am off! ; No rounding today',domoticz.LOG_FORCE)
areg
Post by areg »
Script
and logs
it doesn't show any errors but it doesn't work
I will add that data from airly is sent via http to the Nextion display.
areg
Post by areg »
I need the data from the first row (25,0)to be sent in the second row as a whole number (25).
This is the way values without rounding are displayed.
areg
Post by areg »
Is it possible to do?
areg wrote: Monday 14 January 2019 12:33 Is it possible to do?
It is not clear to me what you want to do based on the information you provided. Is this value that you want to round in a device or in a variable and where do you want the converted value. In the log, -in a device or in a uservar.
Please elaborate.
areg
Post by areg »
I want the percentage value of PM2.5 (airly, unit 11)to be sent after rounded via http. Currently it is eg 32.00 and I need 32.
