2x Domoticz on raspberry pi
coene369
Domoticz version: v3.8153
Post by coene369 »
I have Domoticz running on raspberry pi. but i want to install another one on the same raspberry pi.
I want to this because domoticz has only one dahboard.
answer in dutch possible ;)
Thanks !
snellejellep
Re: 2x Domoticz on raspberry pi
Post by snellejellep »
you could install in another folder and edit the webserver to use other ports, that should work i think.
(je zou de installatie nogeens kunnen uitvoeren in een andere map en de webserver andere poorten laten gebruiken denk ik)
EddyG
Post by EddyG »
It depends on what hardware you want to connect to the raspberry pi.
But I failed to see what the benefits will be running 2 Domticz on 1 raspberry pi.
