How to install Domoticz on a Synology NAS
Re: How to install Domoticz on a Synology NAS
thx, I changed the ports with your update
Have been running domoticz 4.9700 on ds1813+ (DSM 6.2.1) for long time and works fine except for the errors below when starting.
Starting Domoticz ...
insmod: ERROR: could not insert module /lib/modules/usbserial.ko: File exists
insmod: ERROR: could not insert module /lib/modules/ftdi_sio.ko: File exists
insmod: ERROR: could not insert module /usr/local/domoticz/modules/cp210x.ko: File exists
insmod: ERROR: could not insert module /usr/local/domoticz/modules/pl2303.ko: File exists
insmod: ERROR: could not insert module /usr/local/domoticz/modules/ch341.ko: File exists
insmod: ERROR: could not insert module /usr/local/domoticz/modules/ti_usb_3410_5052.ko: File exists
ln: failed to create symbolic link ‘/lib/udev/rules.d/60-synocommunity.domoticz.rules’: File exists
How do I fix that since cannot use USB/Serial port in domoticz now.
- oudoulj
- Domoticz version: 3.0.5877
I have Domoticz v3.0.5877-7 up and running on my DS212 (MARVELL Kirkwood 88F6282)
(I think that's the most recent version available for a DS212 - please correct me if I'm wrong)
Frequently the package stops by itself and I have to relaunch it manually from the Package Center.
Is there a way to check logs somewhere on the NAS ? Because I have no clue why it stops all the time for apparently no reason...
Thanks !
PS : I have a RFXCom plugged to my NAS and Domoticz on there to help me automate my blinds
Thanks !
DS212 (MARVELL Kirkwood 88F6282) with Domoticz v3.0.5877-7
- waaren
On my Synology system the location of the logfile is defined inoudoulj wrote: ↑Friday 04 January 2019 19:26 Hi all,
Thanks !
/var/packages/domoticz/scripts/start-stop-status
LOGFILE="${INSTALL_DIR}/var/domoticz.log"
/usr/local/domoticz/var/domoticz.log
Bonsoir, j'ai un DS418 et j'avais installé pour faire l'essai du NAS Domoticz via un centre de paquet et tout fonctionnais a la perfection le RFXCOM homebridge etc
j'ai du le réinitialiser pour mettre une plus grosse capacité de disques il a donc fais la dernière mise a jour DSM 6.2.1-23824 update 4 et quand je veux ajouter le centre de paquet "http://jadahl.dscloud.me/sspks/" il me donne un message d'emplacement incorrect
dois je effectuer une installation manuelle?
dois je downgrader ma version de DSM ?
HI I got a DS418 it was working with domoticz from a package source who was working with
but it was only a test Now I re-initialized it and want to add package source again and it doesn't work
should I manually install?
does it need to downgrade ?
- jumbotroll
You find my packages here: http://www.jadahl.comguyroh wrote: ↑Saturday 05 January 2019 19:34 Bonsoir, j'ai un DS418 et j'avais installé pour faire l'essai du NAS Domoticz via un centre de paquet et tout fonctionnais a la perfection le RFXCOM homebridge etc
Beta packages is only manual update now. Download and install.
Try to do an update DS418 use arch-rtd1296 packages.
http://www.jadahl.com/domoticz_beta_6.2/
https://paypal.me/Jumbotroll
Jumbotroll
Jumbotroll
Thank Ujumbotroll wrote: ↑Saturday 05 January 2019 21:39You find my packages here: http://www.jadahl.comguyroh wrote: ↑Saturday 05 January 2019 19:34 Bonsoir, j'ai un DS418 et j'avais installé pour faire l'essai du NAS Domoticz via un centre de paquet et tout fonctionnais a la perfection le RFXCOM homebridge etc
I wasn't able to know which one I need with my DS418. U gave to me the good one , it work fine
Hi Jumbotroll,
I have a DS212j with DSM 6.2 but on your site I don't see my DS212j in the list of Domoticz version 4.9, is my NAS too old now or can you do some magic?
I'm currently running Domoticz 3.5 so thought it is time for an update I have to say that this version is running very stable for a few years now, really great. Your work is much appreciated!
Synology NAS with stable release, AEON Z-wave, RFXCOM, Toon, Echo Dot, HAbridge, HarmonyHUB, Dashticz.
- jumbotroll
DS212j use arch-88F6281 and use very old gcc version and old toolchain from synology.Ingmar wrote: ↑Monday 07 January 2019 23:27 Hi Jumbotroll,
I have stopped building new domoticz versions for arch-88F6281.
The latest build for DS212j (DSM6.2) is domoticz_88f6281-6.2_3.0.9483-7.spk
Download here:
http://www.jadahl.com/domoticz_beta_6.2 ... 9483-7.spk
Jumbotroll
Jumbotroll
Ok thank you! So i should really get a new NAS if i understand correctly :pjumbotroll wrote: ↑Tuesday 08 January 2019 10:31DS212j use arch-88F6281 and use very old gcc version and old toolchain from synology.Ingmar wrote: ↑Monday 07 January 2019 23:27 Hi Jumbotroll,
Download here:
- jumbotroll
The NAS you have is great, but I'm not able to build domoticz for arch-88f6281 anymore.Ingmar wrote: ↑Tuesday 08 January 2019 12:19 DS212j use arch-88F6281 and use very old gcc version and old toolchain from synology.
Download here:
Keep the NAS and maybe buy a Raspberry Pie to run domoticz on, I think that is much cheaper
Jumbotroll
Jumbotroll
Ok thanks!
I just installed version domoticz_cedarview-6.2_4.0.10327-8.spk on my Syno. After some minutes, it crashes. The previous beta version worked perfect. Would it be possible to download it again so I can downgrade?
Many thanks in advance.
- jumbotroll
You can't downgrade, but you can reinstall.
Test latest beta
Python version uploaded
http://www.jadahl.com/domoticz_beta_6.2_python/
Jumbotroll
Jumbotroll
Many thanks. I tried the new version but still have the same problem.
It's actually possible to downgrade. Is there some way to download the previous beta version (with Python)?
Thanks,
Thanks,
Adding below the last lines of the domoticz.log file in case someone can imagine what's going on... no changes done since last beta update, just the domoticz upgrade.
2019-01-11 16:22:30.438 Error: Domoticz(pid:9358, tid:9440('PluginMgr_IO')) received fatal signal 11 (Segmentation fault)
2019-01-11 16:22:30.438 Error: siginfo address=(nil), address=(nil)
2019-01-11 16:22:30.478 Error: Failed to start gdb, will use backtrace() for printing stack frame
2019-01-11 16:22:30.479 Error: #0 /usr/local/domoticz/bin/domoticz() [0x6874f0]
2019-01-11 16:22:30.479 Error: #1 /usr/local/domoticz/bin/domoticz : signal_handler(int, siginfo_t*, void*) + 0x295 [0x688255]
2019-01-11 16:22:30.479 Error: #2 /lib/libpthread.so.0 : + 0x101c0 [0x7f45ee6aa1c0]
- jumbotroll
It's deleted, but if you know what version you had, I can rebuild it for you.
Did you upgrade from a non python version to python version?
What version python 3 did you install before you installed domoticz?
BTW I have the latest beta with python installed and do not have this error...
Check your hardware and plugin script..
Jumbotroll
Jumbotroll
I think it was around 4.10320 but I'm not sure of the exact version number.
I've been running the python version since the last non-beta version with no problems.
Meanwhile, I'm checking the syno config in case I see something changed that could be causing this.
Which plugin script are your referring to?
Thanks,
Thanks,
- jumbotroll
I don't refer to any specific plugin or script, but it seems that this error you have it's related to a plugin.manutremo wrote: ↑Friday 11 January 2019 16:50 I think it was around 4.10320 but I'm not sure of the exact version number.
Thanks,
Try also to reboot your nas if you not have done that.
Jumbotroll
Jumbotroll
I was actually looking into that... and you nailed it. The issue is caused by the Tuya plugin by Tixi. Once I disabled it, domoticz does not crash anymore.
No need to recompile the older version. Many thanks for your help!
