Report this post (! button) ends up in a 404 Topic is solved
- waaren
When I tried to report a post using the [!] button I ended up in a 404 screen. (404 Not Found)
Solved by using https://www.domoticz.com/
- EdwinK
- Domoticz version: BETA
Re: Report this post (! button) ends up in a 404
I think that has to do with moving to another server.
- gizmocuz
No problem when i just tried... still an issue ?
- waaren
Yes still get a 404 on http://www.domoticz.com/forum/app.php/p ... 407/report (even after clearing cache )
- Varazir
I still have same and I get the same when I click on the Solved button as well
Raspberry PI 4 with RaZberry Controller 2016 ZWave+ and CC2531(zigbee)
Several IKEA devices/z-wave devices
- Egregius
- Domoticz version: v2024.7
Report button works fine here on https, maybe http is causing the issue?
freijn
- Domoticz version: Stable
I think you tried to report something which was deleted while you were reading it..
- Egregius
Just tested in another browser, my thought was good
When connected thru http and clicking the report button results in a 404
app.php/post/203111/report
But when connected thru https it works fine
https://www.domoticz.com/forum/app.php/ ... 111/report
The main issue here is that there should be a rewrite rule so all traffic passes over https and none of the users type their user/pass over plain text http connection.
For example for a Apache server:
RewriteEngine On
RewriteCond %{HTTPS} off
RewriteRule ^ https://%{HTTP_HOST}%{REQUEST_URI}
RewriteRule ^ https://%{SERVER_NAME}%{REQUEST_URI} [END,NE,R=permanent]- Varazir
Confirm works over https
