Script for IoT air freshener  [Solved]
QSKONE
Post by QSKONE »
Hi , Can you help me? Need script for my IoT air freshener.
https://www.youtube.com/watch?v=gjjP781KOzw
When I try double click - spray it twice action (spray-pause-spray) then everything I make is a loop.
Re: Script for IoT air freshener
QSKONE wrote: Tuesday 08 January 2019 22:13 Hi , Can you help me? Need script for my IoT air freshener.
What are the device ID's of button and sprayer ?
and what is types and subtype of the activator for the sprayer ?
What should be the pause ?
QSKONE
Post by QSKONE »
Spray is switch idx is 90 , button idx is 9 and pause 2 seconds.
Re: Script for IoT air freshener  [Solved]
QSKONE wrote: Tuesday 08 January 2019 22:20 Spray is switch idx is 90 , button idx is 9 and pause 2 seconds.
Can you test this ? You have to add a uservariable type string with name spray first.
-- sprayer
 local sprayVariable = "spray"        -- create this variable with name spray as type string
            on = {  variables =     { sprayVariable },
                    devices     =   { 9             }},
    logging =   {   level   =   domoticz.LOG_DEBUG,
                    marker  =   "sprayer" },
    execute = function(dz,item)
        local sprayer           = dz.devices(90)
        local sprayTrigger      = dz.variables(sprayVariable)
        local pause = 2
        local function spray(cycles)
            if cycles == 2 then
                sprayTrigger.set(os.date("%x %X")).afterSec(pause)
            sprayer.switchOn()
            sprayer.switchOff().afterSec(1)
        if item.isDevice then
            local buttonState       = item.levelName
            if      buttonState == "Click" then spray(1)
            elseif  buttonState == "Double Click" then spray(2) end
            spray(1)
QSKONE
Post by QSKONE »
Thanks you very much warren. Script works like a charm.
https://www.youtube.com/watch?v=V5Ll-xLg5LQ
