Contact temperature sensor ?
midomot
Post by midomot »
Hello
Has anybody found something for this :
a temperature sensor to place/attach/clamp onto the surface of a pipe/radiator etc to report temperature to Domoticz
-> I'd measure surface temperature of pipes in/out of my heating system, of radiators etc
Like the Digoo R8H but with a kind of external probe ?
Digoo R8G: https://www.banggood.com/Digoo-DG-R8H-4 ... 78108.html
Been looking on Banggood and Aliexpress but no luck so far - I maybe have the wrong keywords
At worst I guess I could desolder/add cable/resolder to get the sensor outside the R8H casing, but would rather not..
Thanks !
bjacobse
Re: Contact temperature sensor ?
Post by bjacobse »
Well there are several approaches :-)
1)if you have a few Arduinos + NRF24L01+ modules and some DS18B20
Use Mysensors and create 1 gateway and a sensor/node. The sensors can use DS18B20, this temp sensors you can attache to your pipes with strips
DS18B20 temp node:
https://www.mysensors.org/build/temp
serial gateway:
https://www.mysensors.org/build/serial_gateway
Domoticz Wiki:
https://www.domoticz.com/wiki/MySensors
2)
If you have an ESP8266 wifi, then you can use this approach instead of using mysensors:
https://www.letscontrolit.com/wiki/inde ... as_DS18b20
3)
If you have your RPI with Domoticz close to where you want to measure, then you can cable DS18B20 directly to your RPI
viewtopic.php?f=6&t=25687&p=197575&hili ... 20#p197575
midomot
Post by midomot »
Thanks, I will read up on material you provided me with ! wifi or 433mhz are both good for me
I am just not great with electronics and was hoping I had overlooked a simple battery enabled sensor :)
In fact I'd rather not be dependent on power network because I want to move around the sensors to check different things in the house
b_weijenberg
Post by b_weijenberg »
RFXtrx433, RFXtrx433E, RFXtrx433XL, RFX433XL, RFX868XL
dandanger
Post by dandanger »
Check also NodeMcu with EasyEsp firmware. You can attach which sensor you want, like the mentioned dallas DS18B20. You can put this all together in minutes.
