Alexa text to speech Topic is solved
- Domoticz version: BETA
Re: Alexa text to speech
i nideI need DE Account
Hi All
For people having cookie/captcha issues on headless systems, you could try https://github.com/jonferreira/node-red ... exa-remote
This node (for node-red) allows you to send speech to alexa and works fine.
To fill in the cookie window in the node config, do the following.
Connect to your alexa web page.
right click somewhere on the page and click inspect.
Click on the network tab.
Press f5
pick one of the name in the list
click on the header tab
scroll down to cookie ( if you do not see it click on another name)
copy all what is in here and paste it in the cookie section of the node-red node.
( note host : alexa.amazon.com (or whatever country link you use) and paste it to ''amazon page '' field of the node-red node
Press f5
Just installed the script - wow great job. In my case I'm using spanish alexa at alexa.amazon.es. Everything seems to be working fine regarding launching the script, but whatever I ask it to say, alexa always says (in spanish) "Sorry I can't find an answer to your question".
If however I make her speak something like "Alexa connect bluetooth" she will respond as if I had given the order by talking.
In summary she seems to be taking the phrase after the -e speak: command as an order instead of as something she could just convert into speech and repeat.
My settings are:
LANGUAGE='es-ES'
AMAZON='amazon.es'
ALEXA='alexa.amazon.es'
Any idea?
My settings are:
LANGUAGE='es-ES'
AMAZON='amazon.es'
Any idea?
the same here in italy...it looks like an order...
Great approach, would be perfect for e.g. temperature alerts or so. After a bit of fiddling the login issues were tackled and everything seems to in order, but the sound is missing.
When I do e.g.:
I get as an output:
But no sound from any of my devices! Any ideas and/or advice how to solve this? Same applies to traffic announcements, TuneIn radio and so forth.
When I do e.g.:
sudo ./alexa_remote.sh -d Echo -e speak:'Test'
sending cmd:speak:Test to dev:ALL type:XXX serial:XXX customerid:
Sequence command: Alexa.Speak
{"message":null}
Solved. It was a cookie/login/whatever issue anyway: I used an extension called cookies.txt to copy the cookie into /tmp/alexa.cookie and now it's suddenly working.
I got the same when I was using a cookie from Chrome, once I used a cookie from Firefox, everything worked!johansson wrote: ↑Friday 04 January 2019 21:40 Great approach, would be perfect for e.g. temperature alerts or so. After a bit of fiddling the login issues were tackled and everything seems to in order, but the sound is missing.
When I do e.g.:I get as an output:Code: Select all
But no sound from any of my devices! Any ideas and/or advice how to solve this? Same applies to traffic announcements, TuneIn radio and so forth.Code: Select all
sending cmd:speak:Test to dev:ALL type:XXX serial:XXX customerid: Sequence command: Alexa.Speak {"message":null}
- Domoticz version: 4.9700
Hi!
It works perfect in Spanish in my raspberry pi.
Thanx for share your workwithus. It’s great!
Greetings from Spain.
- Domoticz version: Stable
I still have the problem that cookies expire after a while ( something like 2 weeks ? )
Anybody found this as well and know a solution?
Very unreliable announcements from Alexa
- EdddieN
Anyone managed to get all the Alexa devices to speak at once?
From the documentation this should work:
Also changing the volume before speaking?
./alexa_remote_control.sh -d ALL -e speak:'hello'
11101101 - www.machinon.com
- Domoticz version: 3.8153
I get them speaking in sequence, but timeout after 3 or 4 of them (I have about 10 devices around). Your options are correct
- philchillbill
In the Alexa app you can setup 'routines' that can be triggered either by a custom voice command or by a smart home event. The result can be another smart home event or it can be a TTS action from Alexa (and these ones don't need cookies). There's an option to have it spoken from any of your echos. Might be worth checking out for people currently trying the Loetzimmer script and struggling.
They only work for devices correctly exposed as being of type CONTACT_SENSOR or MOTION_SENSOR and that proactively report state-changes. HA-Bridge exposes everything as a dimmable light as it fakes Philips Hue, so it won't work with HA-Bridge.
Last edited by philchillbill on Thursday 17 January 2019 9:29, edited 1 time in total.
Alexa skills author: EvoControl, Statereport, MediaServer, LMS-lite
- EdddieN
Yes I got HA working fine. It is more I like to anoche things in all of the Alexa via the TTS. I got it working for individual ones but when I use the -d ALL does not seem to work, however the script runs ok.
Just wondering if people have this working reliably?
I worked for me for ages at the start.
Then stopped.
I tryed enabling 2 step, and put the code in the the script for the first go - then took the code out - and this worked for a few days, but stopped again.
I’m going to try and fix the cookie thing, but I don’t have a desktop etc on my pi, so it’s a bit of a job. I have a Mac mini running all the time, so I may have a go on that. But if we are having to redo the cookie every couple of weeks , I may Wait for another solution.
Thanks.
Then stopped.
Thanks.
running domoticz 3.4834 on rpi2, with
Hue bridge / bulbs.
lightwave rf sockets, mood controlers, sensors & contacts.
Home bridge / Siri.
Ha bridge / echo Alexa.
Hard wired alarm system - setting home / away status.
Next: harmony hub.
Hue bridge / bulbs.
Home bridge / Siri.
Next: harmony hub.
- EdddieN
It works for me, although a bit slow...
I used the second script and jq
- philchillbill
Works great for a few days until the cookie expires. PITA to have to renew it manually.
For anyone who has abandoned this because of the cookie thing: There is now support for 2 factor authentication, supposedly eliminating the re-logging in.
Check https://blog.loetzimmer.de/2017/10/amaz ... -echo.html
You have to enable 2 factor authentication at amazon and add another app that will do the 2 factor stuff on linux for you.
- emme
- Domoticz version: latest
I use Alexa-Remote2 node in nodered.
works like a charm!!!!!
"We always done this way"
