I'm using ImperiHome via MyDomoAtHome with Domoticz, and I'm using a dzVents script to update my Hive Heating system whenever I tap on a setpoint widget in ImperiHome.
Trouble is, IH has no 'Set' button, unlike the Domoticz setpoint device, so every time I tap the up or down arrows, it fires the dzVents script. Is there any way of making the script pause and wait for further taps (e.g., max. 2 seconds), so that it only updates Domoticz - and my Hive system - only once (on the last tap)?
dzVents multiple setpoint updates through ImperiHome
- waaren
Re: dzVents multiple setpoint updates through ImperiHome
In theory that is possible but you don't want to implement it like that because the event system in domoticz is single threaded. An implementation with a repeated pause in a script would block the entire event system for the duration of the script. Most likely there are ways to work around that and implement it in a asynchronous way. If you share your current script here I might be able to comment/ help in a more useful way.MikeF wrote: Friday 04 January 2019 19:23 I'm using ImperiHome via MyDomoAtHome with Domoticz, and I'm using a dzVents script to update my Hive Heating system whenever I tap on a setpoint widget in ImperiHome.
MikeF
- Domoticz version: V2022.2
What I've actually done is to create a 'hybrid' lua / python solution. In Domoticz I have the following devices:
- a setpoint ('Setpoint')
- an on / off switch ('Heating boost')
- a selector switch ('Heating mode' - Off / Schedule / Manual)
The lua script checks these devices, and also runs a timer (every minute), and sends arguments to my python script, which does the heavy lifting of updating my Hive system or reading values from it. (This is based on scripts in my 'Read British Gas Hive Heating temperature' thread.)
The lua script is here:
Changing setpoint works fine in Domoticz (as it's only activated once when you click on 'Set' on the Setpoint device), but not in ImperiHome, as each tap on an up /down arrow (to set a significantly different temperature) is read by Domoticz, which causes the dzVents script to be activated multiple times.
- Spoiler: show
- Spoiler: show
- waaren
waaren wrote: Saturday 05 January 2019 0:22Understand. Would it be an option to remove Setpoint from the "on = devices" table and modify the dzVents script in such a way that in the timer part of the script a changed setPoint is recognized and acted upon ? That would be an easy "fix" (see script below) but will cause the setPoint update to be delayed for max. 1 minute for both domoticz GUI and ImperiHome initiated setPoint changes.MikeF wrote: Friday 04 January 2019 23:30 What I've actually done is to create a 'hybrid' lua / python solution. In Domoticz I have the following devices:
If that would be unacceptable for the domoticz triggered part you would have to introduce a virtual setPoint device to register the domoticz initiated changes. Script will become a bit more complex and the exact type of the current setpoint device must be known, as it would be needed to also update it by the script. (virtual setpoint setting -> real setpoint setting)
-- dzVents script to pass Hive heating arguments to python script
local boost = "Heating boost"
local mode = "Heating mode"
devices = { boost,mode },
timer = { "every minute" }
data = {
setPoint = { initial = 0 }
execute = function(dz, item)
local arg = ""
local setPointDevice = dz.devices("Setpoint")
local setPoint = setPointDevice.setPoint
if item.isTimer then
if dz.data.setPoint ~= setPoint then
dz.data.setPoint = setPoint
arg = "set:" .. setPoint
arg = "read:"
elseif item.name == boost then
arg = "boost:" .. item.state
elseif item.name == mode then
arg = "mode:" .. item.rawData[1]
local py_script = 'python /home/pi/devices/hive_heating.py '
local cmd = py_script .. arg
-- print(cmd)
os.execute(cmd)
}Debian buster, bullseye on RPI-4, Intel NUC.
MikeF
Many thanks for this. I'm not sure what you mean by creating a virtual setpoint device? I currently have a setpoint device (called 'Setpoint') in the Utilities tab, and when this is changed in the Domoticz GUI, or in ImperiHome, the lua script calls the python script, which then changes the real Hive thermostat by invoking the Hive JSON API.
- waaren
Sorry for being unclear. What I meant is that if the delay in calling the python code is too long for the domoticz initiated setpoint change, it would be possible to change the behavior of the script.MikeF wrote: Saturday 05 January 2019 17:30 Many thanks for this. I'm not sure what you mean by creating a virtual setpoint device? I currently have a setpoint device (called 'Setpoint') in the Utilities tab, and when this is changed in the Domoticz GUI, or in ImperiHome, the lua script calls the python script, which then changes the real Hive thermostat by invoking the Hive JSON API.
That would require an additional virtual setpoint. The modified script would look at this device and trigger the Python code instantly and update the ImperiHome controlled setpoint at (allmost) the same time. This new setpoint is not to be controlled by InitelliHome. If you want / need that I need to know the type and subtype of your current Setpoint device.
MikeF
OK, I understand. I think that the first option you proposed will be acceptable - after all, when the Hive system initiates changes (schedule / temperature reaching setpoint, etc.), then it can take up to 1 minute before my script reads the updated values. I'll update my script with your changes.
Many thanks.
Many thanks.
