Disable Kodi shutdown function Topic is solved
Holland
Domoticz version: Beta Ch
Post by Holland »
I have seen the discussion in that users would like to be able to shutdown possibility for Kodi.
But just wondering if it's possible to make the shutdown function configurable.
The Kodi machines (OSMC installed on a raspberry pi) in my house are configured to be always on. (they should never shutdown/power off). So what happens now is that ones in a while that one of the users accidentally touches the Kodi icon on the Kodi medio player button, which results in a shutdown of Kodi.
Is it possible to disable this shutdown functionality?
Kodi OFF.JPG (16.62 KiB) Viewed 19351 times
Kodi ON.JPG (15.77 KiB) Viewed 19351 times
Egregius
Domoticz version: v2024.7
Re: Disable Kodi shutdown function
Post by Egregius »
Why do you need a switch if they are always on?
Hide it by putting a $ in front of the name, or mark it as protected.
Holland
Post by Holland »
I use the remote control icon on this button.
Thanks for reminding me of the Protect option. I have enabled that and that's good enough for me.
JeroenL
Domoticz version: 2023.2
Re: (Disable) Kodi shutdown function on timer
Post by JeroenL »
Dear all,
Is there a way to make Kodi shut-down based on a timer. The timer option on the switch is missing.
I tried adding Kodi to a Group, and have the group shutdown on a timer, but that does not work unfortunately.
Any clever idea's ?
Thanks a lot - Jeroen
Dnpwwo
Post by Dnpwwo »
@JeroenL,
Are you using the native support or the python plugin? If you are using the plugin turn on debugging and post the log.
JeroenL
Post by JeroenL »
Dear Dnpwwo,
Am currently using the native plugin from Domoticz.
Rgds
Jeroen
Dnpwwo
Post by Dnpwwo »
@JeroenL,
The plugin has more functionality and better debugging. Can you try switching to that and posting a log?
