No SetPoint command Topic is solved
coen17st
No SetPoint command
Post by coen17st »
Hi, for some reason the block for adjust temperature of my Tado thermostat no longer work for all the rooms except living room. I get a red cross at mouseover. The status and values ​​of that block wont change.
At first I thought it was my script but I started all over again and now I have the base of the CONFIG.js file but even then it does not work. while it has worked before, i also removed and added the hardware again
Someone an idea where to look for the problem?
I have it running on windows server 2016, Apache24, php Version 5.6.39 and I can access Dashticz via the Web server.
var config = {}
config['domoticz_ip'] = 'http://192.168.1.10:8080';
config['user_name'] = 'XX';
config['pass_word'] = 'XX;
config['room_plan'] = '0';
config['default_news_url'] = 'http://www.nu.nl/rss/algemeen';
config['news_scroll_after'] = '7';
config['theme'] = 'default';
config['background_image'] = 'img/bg2.jpg';
config['standby_after'] = '0';
config['auto_swipe_back_to'] = 1;
config['auto_swipe_back_after'] = '10';
config['auto_slide_pages'] = '';
config['slide_effect'] = 'slide';
config['standard_graph'] = 'hours';
config['language'] = 'nl_NL';
config['timeformat'] = 'DD-MM-YY HH:mm';
config['calendarformat'] = 'dd DD.MM HH:mm';
config['calendarlanguage'] = 'nl_NL';
config['calendarurl'] = '';
config['boss_stationclock'] = 'RedBoss';
config['gm_api'] = '';
config['gm_zoomlevel'] = '';
config['gm_latitude'] = '';
config['gm_longitude'] = '';
config['speak_lang'] = 'en-US';
config['wu_api'] = '';
config['wu_city'] = 'Amsterdam';
config['wu_name'] = '';
config['wu_country'] = 'NL';
config['idx_moonpicture'] = '';
config['switch_horizon'] = '';
config['host_nzbget'] = '';
config['spot_clientid'] = '';
config['sonarr_url'] = '';
config['sonarr_apikey'] = '';
config['sonarr_maxitems'] = '';
config['garbage_company'] = '';
config['garbage_icalurl'] = '';
config['google_api_key'] = '';
config['garbage_calendar_id'] = '';
config['garbage_zipcode'] = '';
config['garbage_street'] = '';
config['garbage_housenumber'] = '';
config['garbage_housenumberadd'] = '';
config['garbage_maxitems'] = '';
config['garbage_width'] = '';
config['loginEnabled'] = '0';
config['no_rgb'] = '0';
config['auto_positioning'] = 1;
config['use_favorites'] = 1;
config['disable_googleanalytics'] = 1;
config['last_update'] = 1;
config['hide_topbar'] = '0';
config['edit_mode'] = '0';
config['hide_seconds'] = '0';
config['hide_seconds_stationclock'] = '0';
config['use_fahrenheit'] = '0';
config['use_beaufort'] = '0';
config['translate_windspeed'] = 1;
config['static_weathericons'] = '0';
config['hide_mediaplayer'] = '0';
config['garbage_hideicon'] = '0';
config['garbage_icon_use_colors'] = 1;
config['garbage_use_colors'] = '0';
config['garbage_use_names'] = '0';
config['garbage_use_cors_prefix'] = 1;
