For those interested, Logitech has issued a firmware update that breaks the remote access API, thus Domoticz was not able to communicate with the Logitech Harmony Hubb, here is a link to fix it :
https://community.logitech.com/s/questi ... rabilities
Logitech hub
- StanHD
Re: Logitech hub
@smartel
Thank you very much, working again now.
Looks like Logitech may be realising the amount of customers they made unhappy.
Sent from my SM-T820 using Tapatalk
Python:- Broadlink RM2, Sonos
JCLB
Re: Logitech hub
A topic already reference Harmony Hub evolution
http://www.domoticz.com/forum/viewtopic ... &start=140
poudenes
- Domoticz version: 3.8993
Re: Logitech hub
Hello all,
Logitech have updated firmware to 4.15.250 and enable the xmpp again for all users.
But since my hub is updated Domoticz can't connect to it anymore.
Searched on internet and you need enable XMPP:
Menu > Harmony Setup > Add/Edit Devices & Activities > Remote & Hub > Enable XMPP
Then everything work again
HSR3
- Domoticz version: V2022.1
Re: Logitech hub
I've been using the Harmony Hub for some time now with XMPP enabled after the firmware update to 4.15.250. All was working fine until the latest firmware update to 4.15.264 mid March. Although the XMPP option is still enabled Domoticz cannot connect to the hub. I scanned the ports of the hub but no open ports have been found. Switching the XMPP option OFF and ON doesn't help either.
Anybody with the same problems and possible solution?
krizzz
Re: Logitech hub
Sorry to hear about your problems, but thanks for posting your issues! I will definitely not update than!
jelleeelco
Re: Logitech hub
I have the same version on my hub (4.15.264) and I have no issues connecting to it, so I doubt anything is broken in the hub software...krizzz wrote: Tuesday 05 May 2020 14:25 Sorry to hear about your problems, but thanks for posting your issues! I will definitely not update than!
On a different topic, just a couple of days ago someone created a 'server' that imitates a Roku device and makes it possible to capture ALL buttons pressed from the remote. So you can actually change lights based on pauze/play, and not just in Kodi with the Kodi plugin, but in all activities. I haven't been able to test this out myself yet (it requires the Harmony hub which I have, but also a remote that you can sync over USB, as that step is needed for initial installation to find the Roku Server as a device- I don't have a remote like that yet) but it's very promising. It's in early stages and he's refining the code and installation (I hope he makes it work without the need for a remote with USB)...
His project is called Harmony Span, see links below:
https://github.com/AShifter/harmony-span/
https://www.youtube.com/watch?v=W59Ae5jUl2w
