Problem updating thermostat Setpoint
lastofthejediknights
Domoticz version: 2021.1
Post by lastofthejediknights »
I have made a smart thermostat (among other things), all works, bar one aspect, I cannot set a new setpoint for the thermostat via scripting, when using a variable.
If I change the setpoint, via the web interface, it all works as expected.
In DzVents, I am wanting to modify the setpoint, dependant on who is at home.
I have a preferred temperature virtual thermostat setpoint, as does my wife, there is a third, for nobodyhome.
In Dzvents, if i write
                  averagePreferredSP = ((domoticz.devices('Nigel Preferred Temperature').setPoint) + (domoticz.devices('Emma Preferred Temperature').setPoint))/2
                 emmaSP = (domoticz.devices('Emma Preferred Temperature').setPoint)
                 nigelSP = (domoticz.devices('Nigel Preferred Temperature').setPoint)
                 nobodySP  = (domoticz.devices('Nobody Home').setPoint)
      --            emmaSP = 23.00
      --            nigelSP = 21.00
      --            nobodySP  = 17.50
                     domoticz.devices('Living Rm Thermostat').updateSetPoint(22) -- this works
                     domoticz.devices('Living Rm Thermostat').updateSetPoint(23.50) -- this works
                    domoticz.devices('virtualthermostat').updateSetPoint(nigelSP) --created virtual thermostat for testing, this works / updates
                    domoticz.devices('Living Rm Thermostat').updateSetPoint(nigelSP) -- this doesn't work / update
I have written the values out to log, and all seems fine, I then created a virtual thermostat, just so I could use it for testing, and that works fine.
Am I doing something wrong, or is what I wish to do unsupported?
Re: Problem updating thermostat Setpoint
lastofthejediknights wrote: Thursday 03 January 2019 16:29 I have made a smart thermostat (among other things), all works, bar one aspect, I cannot set a new setpoint for the thermostat via scripting, when using a variable.
This should work. Please show the complete script so that forum users can test / check and add a couple of
domoticz.log(" var1:  " .. tostring(var1),domoticz.LOG_FORCE)
lines to the script to see what happens and see value of the various variables.
		devices = {
			'Nigel At Home' , 'Emma At Home', 'Emma Preferred Temperature', 'Nigel Preferred Temperature'
	--	timer = {
	--	    'every 10 minute'
      --            emmaSP = 23.00
      --            nigelSP = 21.00
      --            nobodySP  = 17.50
            if ( (domoticz.devices('Emma At Home').state == 'On') and (domoticz.devices('Nigel At Home').state == 'On' ) ) then
                    domoticz.log('both Emma and Nigel home ' )
                    domoticz.log('Living Rm Thermostat ' .. averagePreferredSP .. ' SHOULD be Set', domoticz.LOG_INFO)
                    domoticz.devices('virtualthermostat').updateSetPoint(averagePreferredSP) --virtualthermostat
                    domoticz.devices('Living Rm Thermostat').updateSetPoint(averagePreferredSP)
                    domoticz.variables('WhoisHomeVar').set(3)
                --    domoticz.devices('WhoisHome').updateSetPoint(3)
            elseif ( domoticz.devices('Emma At Home').state == 'On'  and domoticz.devices('Nigel At Home').state == 'Off'   ) then
                    domoticz.log('Just Emma home ' )
                  domoticz.log('Living Rm Thermostat ' .. domoticz.devices('Emma Preferred Temperature').state .. ' SHOULD be Set', domoticz.LOG_INFO)
                  domoticz.devices('virtualthermostat').updateSetPoint(emmaSP) --virtualthermostat
                    domoticz.devices('Living Rm Thermostat').updateSetPoint(emmaSP)
                    domoticz.variables('WhoisHomeVar').set(2)
              --      domoticz.devices('WhoisHome').updateSetPoint(2)
            elseif ( domoticz.devices('Nigel At Home').state == 'On'  and domoticz.devices('Emma At Home').state == 'Off'   ) then
                    domoticz.log('Just Nigel home ' )
                    domoticz.log('Living Rm Thermostat ' .. domoticz.devices('Nigel Preferred Temperature').state .. ' SHOULD be Set', domoticz.LOG_INFO)
                    domoticz.devices('virtualthermostat').updateSetPoint(nigelSP) --virtualthermostat
                    domoticz.variables('WhoisHomeVar').set(1)
              --      domoticz.devices('WhoisHome').updateSetPoint(1)
            else --( domoticz.devices('Nigel At Home').state == 'Off'  and domoticz.devices('Emma At Home').state == 'Off'   ) then
                    domoticz.log('NoOne Home ' )
                    domoticz.log('Living Rm Thermostat ' .. domoticz.devices('Nobody Home').state .. ' SHOULD be Set', domoticz.LOG_INFO)
                    domoticz.devices('virtualthermostat').updateSetPoint(nobodySP) --virtualthermostat
                    domoticz.devices('Living Rm Thermostat').updateSetPoint(nobodySP)
                    domoticz.variables('WhoisHomeVar').set(5)
              --      domoticz.devices('WhoisHome').updateSetPoint(5)
	            	domoticz.log('Living Rm Thermostat ' .. domoticz.devices('Living Rm Thermostat').state .. ' was Set', domoticz.LOG_INFO)
		            domoticz.devices('WhoisHome').updateSetPoint(domoticz.variables('WhoisHomeVar').value)
		--            domoticz.devices('Living Rm Thermostat').updateSetPoint(22)
				domoticz.log(" averagePreferredSP:  " .. tostring(averagePreferredSP),domoticz.LOG_FORCE)
		domoticz.log(" emmaSP:  " .. tostring(emmaSP),domoticz.LOG_FORCE)
		domoticz.log(" nigelSP:  " .. tostring(nigelSP),domoticz.LOG_FORCE)
		domoticz.log(" nobodySP:  " .. tostring(nobodySP),domoticz.LOG_FORCE)
Begin log *******************************************************************************************
2019-01-03 17:21:59.685 (Dummy) Thermostat (Nigel Preferred Temperature)
2019-01-03 17:21:59.729 Status: dzVents: Info: Handling events for: "Nigel Preferred Temperature", value: "21.50"
2019-01-03 17:21:59.729 Status: dzVents: Info: ------ Start internal script: SetTemp on Who is Home: Device: "Nigel Preferred Temperature (Dummy)", Index: 412
2019-01-03 17:21:59.731 Status: dzVents: Info: Just Nigel home
2019-01-03 17:21:59.731 Status: dzVents: Info: Living Rm Thermostat 21.50 SHOULD be Set
2019-01-03 17:21:59.731 Status: dzVents: Info: Living Rm Thermostat 23.00 was Set (this is the existing setpoint on the hardware thermostat, readback)
2019-01-03 17:21:59.732 Status: dzVents: !Info: averagePreferredSP: 22.5
2019-01-03 17:21:59.732 Status: dzVents: !Info: emmaSP: 23.5
2019-01-03 17:21:59.732 Status: dzVents: !Info: nigelSP: 21.5
2019-01-03 17:21:59.732 Status: dzVents: !Info: nobodySP: 17.5
2019-01-03 17:21:59.732 Status: dzVents: Info: ------ Finished SetTemp on Who is Home
End Log ****************************************************************
Many thanks
lastofthejediknights wrote: Thursday 03 January 2019 18:25
Correct me if I am wrong but if you try to read the device setPoints back in the same script as you used to change them it will not give you the expected values. dzVents or Lua ask domoticz to perform the actions after the script finished by handing back an object with all requested changes. So if you change something in domoticz in the script it will only be visible after the script has finished.
You may well be right, however in any event, the actual device isn't updated.
I put the log entries in to see what was happening.
The virtual thermostats (Preferred temperatures) don't get changed in the script, the "Real" thermostat, gets its setpoint modified, dependant on who is home.
I don't see why your script does not work as expected. Can you please try this one ?
             on =   {
                        timer           =   {   'every minute' },    -- Just during debugging and test
                        devices         =   {   'Nigel At Home',
                                                'Emma At Home',
                                                'Nigel Preferred Temperature',
        logging =   {
                         level          =   domoticz.LOG_DEBUG,
                        marker          =   "setpoint"
    execute = function(dz)
        local NigelSetPoint         = dz.devices('Nigel Preferred Temperature').setPoint
        local EmmaSetPoint          = dz.devices('Emma Preferred Temperature').setPoint
        local nobodySetPoint        = dz.devices('Nobody Home').setPoint
        local averageSetPoint       = dz.utils.round((NigelSetPoint + EmmaSetPoint)/2,1)
        local EmmaAtHome            = dz.devices('Emma At Home').state == 'On'
        local NigelAtHome           = dz.devices('Nigel At Home').state == 'On'
        local virtualThermostat     = dz.devices('virtualthermostat')
        local livingRoomThermostat  = dz.devices('Living Rm Thermostat')
        local whoisHomeVar          = dz.variables('WhoisHomeVar')
        local Emma                  = 2
        local Nigel                 = 1
        local both                  = 3
        local neither               = 5
        local function logWrite(str,level)
            dz.log(tostring(str),level or dz.LOG_DEBUG)
        local function dump2Log()
            logWrite("EmmaSetPoint:             "  .. tostring(NigelSetPoint)  )
            logWrite("NigelSetPoint:            "  .. tostring(EmmaSetPoint)   )
            logWrite("averagePreferredSetPoint: "  .. tostring(averageSetPoint))
            logWrite("nobodySetPoint:           "  .. tostring(nobodySetPoint) )
            logWrite("EmmaAtHome:               "  .. tostring(EmmaAtHome)     )
            logWrite("NigelAtHome:              "  .. tostring(EmmaAtHome)     )
        local function setSetPoints(setPoint, home)
            virtualThermostat.updateSetPoint(setPoint)
            livingRoomThermostat.updateSetPoint(setPoint)
            whoisHomeVar.set(home)
            return tostring(setPoint)
        dump2Log()
        if EmmaAtHome and NigelAtHome then
            logWrite('Both Emma and Nigel home, setpoints set to ' .. setSetPoints(averageSetPoint,both))
        elseif EmmaAtHome and not NigelAtHome then
            logWrite('Just Emma home, setpoints set to ' .. setSetPoints(EmmaSetPoint,Emma))
        elseif NigelAtHome and not EmmaAtHome then
            logWrite('Just Nigel home, setpoints set to ' ..  setSetPoints(NigelSetPoint,Nigel))
            logWrite('NoOne home, setpoints set to ' .. setSetPoints(nobodySetPoint,neither))
Many thanks for this.
I created the new script, the log output is as below.
Begin Log *************************************
2019-01-03 20:30:30.657 (Dummy) Light/Switch (Emma At Home)
2019-01-03 20:30:30.655 Status: User: Admin initiated a switch command (410/Emma At Home/On)
2019-01-03 20:30:30.700 Status: dzVents: Info: Handling events for: "Emma At Home", value: "On"
2019-01-03 20:30:30.701 Status: dzVents: Info: setpoint: ------ Start internal script: settemp trial: Device: "Emma At Home (Dummy)", Index: 410
2019-01-03 20:30:30.701 Status: dzVents: Debug: setpoint: Processing device-adapter for Nigel Preferred Temperature: Thermostat setpoint device adapter
2019-01-03 20:30:30.701 Status: dzVents: Debug: setpoint: Processing device-adapter for Emma Preferred Temperature: Thermostat setpoint device adapter
2019-01-03 20:30:30.702 Status: dzVents: Debug: setpoint: Processing device-adapter for Nobody Home: Thermostat setpoint device adapter
2019-01-03 20:30:30.702 Status: dzVents: Error (2.4.6): setpoint: An error occured when calling event handler settemp trial
2019-01-03 20:30:30.702 Status: dzVents: Error (2.4.6): setpoint: .../var/scripts/dzVents/generated_scripts/settemp trial.lua:21: attempt to index field 'round' (a function value)
2019-01-03 20:30:30.702 Status: dzVents: Info: setpoint: ------ Finished settemp trial
lastofthejediknights wrote: Thursday 03 January 2019 21:32 Hi,
Corrected the error please reload my posted script.
Revised script log file
Begin Log **********************************************
2019-01-03 21:07:03.748 (Dummy) Thermostat (virtualthermostat)
2019-01-03 21:07:03.131 Status: User: Admin initiated a switch command (410/Emma At Home/Off)
2019-01-03 21:07:03.177 Status: dzVents: Info: Handling events for: "Emma At Home", value: "Off"
2019-01-03 21:07:03.177 Status: dzVents: Info: setpoint: ------ Start internal script: settemp trial: Device: "Emma At Home (Dummy)", Index: 410
2019-01-03 21:07:03.178 Status: dzVents: Debug: setpoint: Processing device-adapter for Nigel Preferred Temperature: Thermostat setpoint device adapter
2019-01-03 21:07:03.178 Status: dzVents: Debug: setpoint: Processing device-adapter for Emma Preferred Temperature: Thermostat setpoint device adapter
2019-01-03 21:07:03.178 Status: dzVents: Debug: setpoint: Processing device-adapter for Nobody Home: Thermostat setpoint device adapter
2019-01-03 21:07:03.179 Status: dzVents: Debug: setpoint: Processing device-adapter for Nigel At Home: Switch device adapter
2019-01-03 21:07:03.179 Status: dzVents: Debug: setpoint: Processing device-adapter for virtualthermostat: Thermostat setpoint device adapter
2019-01-03 21:07:03.179 Status: dzVents: Debug: setpoint: Processing device-adapter for Living Rm Thermostat: Thermostat setpoint device adapter
2019-01-03 21:07:03.179 Status: dzVents: Debug: setpoint: EmmaSetPoint: 21.5
2019-01-03 21:07:03.179 Status: dzVents: Debug: setpoint: NigelSetPoint: 23.5
2019-01-03 21:07:03.179 Status: dzVents: Debug: setpoint: averagePreferredSetPoint: 22.5
2019-01-03 21:07:03.179 Status: dzVents: Debug: setpoint: nobodySetPoint: 17.5
2019-01-03 21:07:03.180 Status: dzVents: Debug: setpoint: EmmaAtHome: false
2019-01-03 21:07:03.180 Status: dzVents: Debug: setpoint: NigelAtHome: false
2019-01-03 21:07:03.180 Status: dzVents: Debug: setpoint: Constructed timed-command: 21.5
2019-01-03 21:07:03.180 Status: dzVents: Debug: setpoint: Just Nigel home, setpoints set to 21.5
2019-01-03 21:07:03.180 Status: dzVents: Info: setpoint: ------ Finished settemp trial
2019-01-03 21:07:03.232 Status: EventSystem: Script event triggered: /usr/local/domoticz/dzVents/runtime/dzVents.lua
2019-01-03 21:07:03.266 Status: Set UserVariable WhoisHomeVar = 1
End Log ************************************************************************
The setpoint has indeed updated, and been transferred as "normal" to the thermostat hardware. Thank You.
Fundamentally, what is the difference between your script and mine? i.e. why does your script work, and my (clumsier) script not?
I see that there is a timed aspect to this, as intimated by the log, but I don't see where this is in the script.
Many thanks Nigel
lastofthejediknights wrote: Thursday 03 January 2019 22:15 Fundamentally, what is the difference between your script and mine? i.e. why does your script work, and my (clumsier) script not?
The timed aspect is a standard message from dzVents. I see that also if I use your initial script. The only remaining fundamental difference that I see is that I don't do a domoticz.devices('WhoisHome').updateSetPoint(domoticz.variables('WhoisHomeVar').value) but the syntax of this command should not cause problems.
If I create the same variable, devices and sensors on my test-system and execute your original script I don't get an error and the setpoints do change as expected.
2019-01-03 23:05:19.241  Status: User: Admin initiated a switch command (1286/Nigel At Home/Off)
2019-01-03 23:05:19.254  (Virtual2) Light/Switch (Nigel At Home)
2019-01-03 23:05:19.657  Status: dzVents: Info:  setpoint: ------ Start external script: dumper46.lua: Device: "Nigel At Home (Virtual2)", Index: 1286
2019-01-03 23:05:19.660  Status: dzVents: Debug: setpoint: Processing device-adapter for Nigel Preferred Temperature: Thermostat setpoint device adapter
2019-01-03 23:05:19.662  Status: dzVents: Debug: setpoint: Processing device-adapter for Emma Preferred Temperature: Thermostat setpoint device adapter
2019-01-03 23:05:19.665  Status: dzVents: Debug: setpoint: Processing device-adapter for Nobody Home: Thermostat setpoint device adapter
2019-01-03 23:05:19.668  Status: dzVents: Debug: setpoint: Processing device-adapter for Emma At Home: Switch device adapter
2019-01-03 23:05:19.668  Status: dzVents: Debug: setpoint: NoOne Home
2019-01-03 23:05:19.668  Status: dzVents: Debug: setpoint: Living Rm Thermostat 20.5 SHOULD be Set
2019-01-03 23:05:19.670  Status: dzVents: Debug: setpoint: Processing device-adapter for virtualthermostat: Thermostat setpoint device adapter
2019-01-03 23:05:19.671  Status: dzVents: Debug: setpoint: Constructed timed-command: 20.5
2019-01-03 23:05:19.673  Status: dzVents: Debug: setpoint: Processing device-adapter for Living Rm Thermostat: Thermostat setpoint device adapter
2019-01-03 23:05:19.676  Status: dzVents: Debug: setpoint: Constructed timed-command: 20.5
2019-01-03 23:05:19.677  Status: dzVents: Debug: setpoint: Living Rm Thermostat 20.50 was Set
2019-01-03 23:05:19.678  Status: dzVents: Debug: setpoint: Processing device-adapter for WhoisHome: Thermostat setpoint device adapter
2019-01-03 23:05:19.679  Status: dzVents: Debug: setpoint: Constructed timed-command: 1
2019-01-03 23:05:19.679  Status: dzVents: !Info: setpoint:  averagePreferredSP:  20.5
2019-01-03 23:05:19.679  Status: dzVents: !Info: setpoint:  emmaSP:  20.5
2019-01-03 23:05:19.679  Status: dzVents: !Info: setpoint:  nigelSP:  20.5
2019-01-03 23:05:19.679  Status: dzVents: !Info: setpoint:  nobodySP:  20.5
2019-01-03 23:05:19.680  Status: dzVents: Info:  setpoint: ------ Finished dumper46.lua
2019-01-03 23:05:19.851  Status: Set UserVariable WhoisHomeVar = 5
2019-01-03 23:05:20.468  (Virtual2) Thermostat (virtualthermostat)
2019-01-03 23:05:20.534  (Virtual2) Thermostat (Living Rm Thermostat)
2019-01-03 23:05:20.540  (Virtual2) Thermostat (WhoisHome)
2019-01-03 23:07:18.923  Status: dzVents: Info:  setpoint: ------ Start external script: dumper46.lua: Device: "Nigel At Home (Virtual2)", Index: 1286
2019-01-03 23:07:18.959  Status: dzVents: Debug: setpoint: Processing device-adapter for Nigel Preferred Temperature: Thermostat setpoint device adapter
2019-01-03 23:07:18.978  Status: dzVents: Debug: setpoint: Processing device-adapter for Emma Preferred Temperature: Thermostat setpoint device adapter
2019-01-03 23:07:18.997  Status: dzVents: Debug: setpoint: Processing device-adapter for Nobody Home: Thermostat setpoint device adapter
2019-01-03 23:07:19.014  Status: dzVents: Debug: setpoint: Processing device-adapter for Emma At Home: Switch device adapter
2019-01-03 23:07:19.015  Status: dzVents: Info:  setpoint: Just Nigel home
2019-01-03 23:07:19.016  Status: dzVents: Debug: setpoint: Living Rm Thermostat 21.00 SHOULD be Set
2019-01-03 23:07:19.022  Status: dzVents: Debug: setpoint: Processing device-adapter for virtualthermostat: Thermostat setpoint device adapter
2019-01-03 23:07:19.023  Status: dzVents: Debug: setpoint: Constructed timed-command: 21
2019-01-03 23:07:19.027  Status: dzVents: Debug: setpoint: Processing device-adapter for Living Rm Thermostat: Thermostat setpoint device adapter
2019-01-03 23:07:19.027  Status: dzVents: Debug: setpoint: Constructed timed-command: 21
2019-01-03 23:07:19.029  Status: dzVents: Debug: setpoint: Living Rm Thermostat 20.50 was Set
2019-01-03 23:07:19.032  Status: dzVents: Debug: setpoint: Processing device-adapter for WhoisHome: Thermostat setpoint device adapter
2019-01-03 23:07:19.033  Status: dzVents: Debug: setpoint: Constructed timed-command: 5
2019-01-03 23:07:19.033  Status: dzVents: !Info: setpoint:  averagePreferredSP:  20.75
2019-01-03 23:07:19.033  Status: dzVents: !Info: setpoint:  emmaSP:  20.5
2019-01-03 23:07:19.033  Status: dzVents: !Info: setpoint:  nigelSP:  21
2019-01-03 23:07:19.033  Status: dzVents: !Info: setpoint:  nobodySP:  20.5
2019-01-03 23:07:19.065  Status: dzVents: Info:  setpoint: ------ Finished dumper46.lua
2019-01-03 23:07:19.285  Status: Set UserVariable WhoisHomeVar = 1
2019-01-03 23:07:19.824  (Virtual2) Thermostat (virtualthermostat)
2019-01-03 23:07:19.908  (Virtual2) Thermostat (Living Rm Thermostat)
2019-01-03 23:07:19.918  (Virtual2) Thermostat (WhoisHome)
2019-01-03 23:07:48.721  Status: dzVents: Info:  setpoint: ------ Start external script: dumper46.lua: Device: "Nigel Preferred Temperature (Virtual2)", Index: 1289
2019-01-03 23:07:48.724  Status: dzVents: Debug: setpoint: Processing device-adapter for Emma Preferred Temperature: Thermostat setpoint device adapter
2019-01-03 23:07:48.726  Status: dzVents: Debug: setpoint: Processing device-adapter for Nobody Home: Thermostat setpoint device adapter
2019-01-03 23:07:48.727  Status: dzVents: Debug: setpoint: Processing device-adapter for Emma At Home: Switch device adapter
2019-01-03 23:07:48.729  Status: dzVents: Debug: setpoint: Processing device-adapter for Nigel At Home: Switch device adapter
2019-01-03 23:07:48.729  Status: dzVents: Info:  setpoint: Just Nigel home
2019-01-03 23:07:48.729  Status: dzVents: Debug: setpoint: Living Rm Thermostat 22.50 SHOULD be Set
2019-01-03 23:07:48.730  Status: dzVents: Debug: setpoint: Processing device-adapter for virtualthermostat: Thermostat setpoint device adapter
2019-01-03 23:07:48.730  Status: dzVents: Debug: setpoint: Constructed timed-command: 22.5
2019-01-03 23:07:48.732  Status: dzVents: Debug: setpoint: Processing device-adapter for Living Rm Thermostat: Thermostat setpoint device adapter
2019-01-03 23:07:48.732  Status: dzVents: Debug: setpoint: Constructed timed-command: 22.5
2019-01-03 23:07:48.733  Status: dzVents: Debug: setpoint: Living Rm Thermostat 21.00 was Set
2019-01-03 23:07:48.734  Status: dzVents: Debug: setpoint: Processing device-adapter for WhoisHome: Thermostat setpoint device adapter
2019-01-03 23:07:48.734  Status: dzVents: Debug: setpoint: Constructed timed-command: 1
2019-01-03 23:07:48.734  Status: dzVents: !Info: setpoint:  averagePreferredSP:  21.5
2019-01-03 23:07:48.735  Status: dzVents: !Info: setpoint:  emmaSP:  20.5
2019-01-03 23:07:48.735  Status: dzVents: !Info: setpoint:  nigelSP:  22.5
2019-01-03 23:07:48.735  Status: dzVents: !Info: setpoint:  nobodySP:  20.5
2019-01-03 23:07:48.736  Status: dzVents: Info:  setpoint: ------ Finished dumper46.lua
2019-01-03 23:09:02.610  Status: dzVents: Info:  setpoint: ------ Start external script: dumper46.lua: Device: "Emma Preferred Temperature (Virtual2)", Index: 1288
2019-01-03 23:09:02.612  Status: dzVents: Debug: setpoint: Processing device-adapter for Nigel Preferred Temperature: Thermostat setpoint device adapter
2019-01-03 23:09:02.614  Status: dzVents: Debug: setpoint: Processing device-adapter for Nobody Home: Thermostat setpoint device adapter
2019-01-03 23:09:02.615  Status: dzVents: Debug: setpoint: Processing device-adapter for Emma At Home: Switch device adapter
2019-01-03 23:09:02.617  Status: dzVents: Debug: setpoint: Processing device-adapter for Nigel At Home: Switch device adapter
2019-01-03 23:09:02.617  Status: dzVents: Info:  setpoint: Just Nigel home
2019-01-03 23:09:02.617  Status: dzVents: Debug: setpoint: Living Rm Thermostat 25.00 SHOULD be Set
2019-01-03 23:09:02.618  Status: dzVents: Debug: setpoint: Processing device-adapter for virtualthermostat: Thermostat setpoint device adapter
2019-01-03 23:09:02.618  Status: dzVents: Debug: setpoint: Constructed timed-command: 25
2019-01-03 23:09:02.620  Status: dzVents: Debug: setpoint: Processing device-adapter for Living Rm Thermostat: Thermostat setpoint device adapter
2019-01-03 23:09:02.620  Status: dzVents: Debug: setpoint: Constructed timed-command: 25
2019-01-03 23:09:02.621  Status: dzVents: Debug: setpoint: Living Rm Thermostat 25.00 was Set
2019-01-03 23:09:02.622  Status: dzVents: Debug: setpoint: Processing device-adapter for WhoisHome: Thermostat setpoint device adapter
2019-01-03 23:09:02.622  Status: dzVents: Debug: setpoint: Constructed timed-command: 1
2019-01-03 23:09:02.622  Status: dzVents: !Info: setpoint:  averagePreferredSP:  23.75
2019-01-03 23:09:02.622  Status: dzVents: !Info: setpoint:  emmaSP:  22.5
2019-01-03 23:09:02.622  Status: dzVents: !Info: setpoint:  nigelSP:  25
2019-01-03 23:09:02.622  Status: dzVents: !Info: setpoint:  nobodySP:  17.5
2019-01-03 23:09:02.623  Status: dzVents: Info:  setpoint: ------ Finished dumper46.lua
2019-01-03 23:09:02.833  Status: Set UserVariable WhoisHomeVar = 1
2019-01-03 23:09:03.332  (Virtual2) Thermostat (virtualthermostat)
2019-01-03 23:09:03.366  (Virtual2) Thermostat (Living Rm Thermostat)
2019-01-03 23:09:03.371  (Virtual2) Thermostat (WhoisHome)
2019-01-03 23:09:13.733  Status: dzVents: Info:  setpoint: ------ Start external script: dumper46.lua: Device: "Emma At Home (Virtual2)", Index: 1287
2019-01-03 23:09:13.735  Status: dzVents: Debug: setpoint: Processing device-adapter for Nigel Preferred Temperature: Thermostat setpoint device adapter
2019-01-03 23:09:13.737  Status: dzVents: Debug: setpoint: Processing device-adapter for Emma Preferred Temperature: Thermostat setpoint device adapter
2019-01-03 23:09:13.739  Status: dzVents: Debug: setpoint: Processing device-adapter for Nobody Home: Thermostat setpoint device adapter
2019-01-03 23:09:13.741  Status: dzVents: Debug: setpoint: Processing device-adapter for Nigel At Home: Switch device adapter
2019-01-03 23:09:13.741  Status: dzVents: Info:  setpoint: both Emma and Nigel home
2019-01-03 23:09:13.741  Status: dzVents: Debug: setpoint: Living Rm Thermostat 23.75 SHOULD be Set
2019-01-03 23:09:13.743  Status: dzVents: Debug: setpoint: Processing device-adapter for virtualthermostat: Thermostat setpoint device adapter
2019-01-03 23:09:13.743  Status: dzVents: Debug: setpoint: Constructed timed-command: 23.75
2019-01-03 23:09:13.745  Status: dzVents: Debug: setpoint: Processing device-adapter for Living Rm Thermostat: Thermostat setpoint device adapter
2019-01-03 23:09:13.745  Status: dzVents: Debug: setpoint: Constructed timed-command: 23.75
2019-01-03 23:09:13.747  Status: dzVents: Debug: setpoint: Living Rm Thermostat 25.00 was Set
2019-01-03 23:09:13.749  Status: dzVents: Debug: setpoint: Processing device-adapter for WhoisHome: Thermostat setpoint device adapter
2019-01-03 23:09:13.749  Status: dzVents: Debug: setpoint: Constructed timed-command: 1
2019-01-03 23:09:13.749  Status: dzVents: !Info: setpoint:  averagePreferredSP:  23.75
2019-01-03 23:09:13.749  Status: dzVents: !Info: setpoint:  emmaSP:  22.5
2019-01-03 23:09:13.749  Status: dzVents: !Info: setpoint:  nigelSP:  25
2019-01-03 23:09:13.750  Status: dzVents: !Info: setpoint:  nobodySP:  17.5
2019-01-03 23:09:13.751  Status: dzVents: Info:  setpoint: ------ Finished dumper46.lua
2019-01-03 23:09:13.951  Status: Set UserVariable WhoisHomeVar = 3
2019-01-03 23:09:14.483  (Virtual2) Thermostat (virtualthermostat)
2019-01-03 23:09:14.516  (Virtual2) Thermostat (Living Rm Thermostat)
2019-01-03 23:09:14.521  (Virtual2) Thermostat (WhoisHome)
2019-01-03 23:10:33.329  Status: dzVents: Info:  setpoint: ------ Start external script: dumper46.lua: Device: "Nigel At Home (Virtual2)", Index: 1286
2019-01-03 23:10:33.333  Status: dzVents: Debug: setpoint: Processing device-adapter for Nigel Preferred Temperature: Thermostat setpoint device adapter
2019-01-03 23:10:33.334  Status: dzVents: Debug: setpoint: Processing device-adapter for Emma Preferred Temperature: Thermostat setpoint device adapter
2019-01-03 23:10:33.336  Status: dzVents: Debug: setpoint: Processing device-adapter for Nobody Home: Thermostat setpoint device adapter
2019-01-03 23:10:33.338  Status: dzVents: Debug: setpoint: Processing device-adapter for Emma At Home: Switch device adapter
2019-01-03 23:10:33.338  Status: dzVents: Info:  setpoint: Just Emma home
2019-01-03 23:10:33.338  Status: dzVents: Debug: setpoint: Living Rm Thermostat 22.50 SHOULD be Set
2019-01-03 23:10:33.340  Status: dzVents: Debug: setpoint: Processing device-adapter for virtualthermostat: Thermostat setpoint device adapter
2019-01-03 23:10:33.340  Status: dzVents: Debug: setpoint: Constructed timed-command: 22.5
2019-01-03 23:10:33.342  Status: dzVents: Debug: setpoint: Processing device-adapter for Living Rm Thermostat: Thermostat setpoint device adapter
2019-01-03 23:10:33.342  Status: dzVents: Debug: setpoint: Constructed timed-command: 22.5
2019-01-03 23:10:33.343  Status: dzVents: Debug: setpoint: Living Rm Thermostat 23.75 was Set
2019-01-03 23:10:33.345  Status: dzVents: Debug: setpoint: Processing device-adapter for WhoisHome: Thermostat setpoint device adapter
2019-01-03 23:10:33.345  Status: dzVents: Debug: setpoint: Constructed timed-command: 3
2019-01-03 23:10:33.345  Status: dzVents: !Info: setpoint:  averagePreferredSP:  23.75
2019-01-03 23:10:33.345  Status: dzVents: !Info: setpoint:  emmaSP:  22.5
2019-01-03 23:10:33.345  Status: dzVents: !Info: setpoint:  nigelSP:  25
2019-01-03 23:10:33.345  Status: dzVents: !Info: setpoint:  nobodySP:  17.5
2019-01-03 23:10:33.347  Status: dzVents: Info:  setpoint: ------ Finished dumper46.lua
2019-01-03 23:10:33.519  Status: Set UserVariable WhoisHomeVar = 2
2019-01-03 23:10:34.058  (Virtual2) Thermostat (virtualthermostat)
2019-01-03 23:10:34.091  (Virtual2) Thermostat (Living Rm Thermostat)
2019-01-03 23:10:34.096  (Virtual2) Thermostat (WhoisHome)
The only way to find out is to switch on the script debug with
        logging =   {
                        marker          =   "setpoint"
Well, Many thanks for the help, I'll muck about some more to try and understand why mine didn't work, but the issue is very well resolved.
Thank you.
Nigel
