Set Dimmer/Switch default to percentage
gschmidt
Post by gschmidt »
I have created a Selector Switch/Dimmer for a Yeelight LED Bulb RGBWW lamp.
In dzVents have created a script to dim the brightness of the lamp.
The script works but I want the slider of the Dimmer always to start at 25% when the Lamp is turned on again.
The current script remembers, when the lamp is set to OFF, the last slider location.
I already tried the device.dimTo(25) function, but this triggers strange behaviour, because dimming also to turn on the lamp.
Can somebody help me with this?
    active = true,
        devices = { 'Hoek Lamp 1'}
        port = '55443'
        yeelights = {'192.168.1.57'}
        for ix, ipadress in ipairs(yeelights) do
            if (device.state == 'Off') then
                domoticz.log('Turning light off')
                runcommand = "sudo echo -ne '{\"id\":1,\"method\":\"set_power\", \"params\":[\"off\", \"smooth\", 500]}\\r\\n' | nc -w1 " ..ipadress.." " ..port..""
                os.execute(runcommand)
                domoticz.log('Changing brightness level')
                brightvalue = (device.level - 1);
                runcommand = "sudo echo -ne '{\"id\":1, \"method\":\"set_scene\",\"params\":[\"ct\", 3000, " .. brightvalue .. "]}\\r\\n' | nc -w1 " ..ipadress.." " ..port..""
                -- device.dimTo(25);
Re: Set Dimmer/Switch default to percentage
gschmidt wrote: Monday 31 December 2018 17:11 I already tried the device.dimTo(25) function, but this triggers strange behavior, because dimming also to turn on the lamp.
Did you try this ?
device.dimTo(25).silent()
gschmidt
Post by gschmidt »
I tried several positions in the script, but none of them gave the desired result
When I place device.dimTo(25).silent() in the ELSE part: When I slide to other values, the slider always returns to 25% (and I want the slider to return to 25% after the Lamp is set to OFF.)
When I place device.dimTo(25).silent() in the IF part (where the lamp is set to OFF): The Lamp is off and the slider is set at 25%, this appears to work but the Switch object is not showing off but at 25% and with an ON icon, although the lamp is off???
Anyway, I also found a workaround creating a group (scene)
gschmidt wrote: Thursday 03 January 2019 12:53 I tried several positions in the script, but none of them gave the desired result
Script below works for me.
    active = true,
        devices = { 'Hoek Lamp 1' }
           logging =   {
                         level         =   domoticz.LOG_DEBUG,
                        marker        =   "YL control"
        port = '55443'
				device.switchOff().afterSec(1).silent()
                domoticz.log("brightvalue: " .. brightvalue ,domoticz.LOG_DEBUG)
